| spetom |
 spetom Trackday Trickster
| c_dug |
 c_dug Super Spammer
 Posted: 13:23 - 28 Jan 2011 Post subject: |
I may be wrong but I believe I have read on hear before that if there is a layer of paint there is no need to use any sort of primer.
By a layer I mean after sanding, not just paint over the original paint.
There are a few experienced bodywork/painting people on the forums, usually with conflicting opinions, I'm sure they will be along for an argument in a little while  ____________________ I am a bellend, I am a man of constant sorrow, I am a gummy bear, I am a rock. |
| Shaft |
 Shaft World Chat Champion
 Posted: 22:18 - 28 Jan 2011 Post subject: |
OK, I'll bite
For stripping, you've got three options.
1/ Sanding
2/ Paint stripper
3/ Media blasting
Starting in reverse order, media blasting (sand, plastic, glass, walnut etc) is a specialist task, so you'll have to pay someone to do it, unless you want to buy all the kit (not very cost effective).
It's also a bit harsh and, if you use the wrong media or get a bit heavy handed with it, you'll knacker everything beyond repair.
I'm not a big fan of chemical stripping, unless you absolutely have to get back to the base material; it's messy and you have to make sure you get every last trace off, otherwise your new paint will be ruined.
Also, some plastics won't tolerate it, so test a part of the panel that can't be seen and if it starts melting, wash it off quick!
Rather annoyingly, not every piece of plastic is always the same type, so you might test it on a side panel and have no problems, then you slap it on your fairing and get into a great, globby (and expensive) mess.
So, it's rubbing down, either by hand or machine; if you're doing it by hand, invest in a decent rubbing block, or go down the machine route and get yourself a random orbit sander (about 20 quid-ish from Screwfix/Machine Mart) and save yourself a lot of time, although you'll still have to resort to elbow grease, if you've got nadgery little corners to get into.
Wheels I would get blasted, probably by the bloke that was going to powder coat them.
As for the primer question, in your example you've chosen red covered by white; red is notoriously difficult to cover and white is notoriously bad at covering, especially if you're using aerosols, so I would use a light grey or yellow primer, to kill the red and provide a better base for the white.
In any case, if you get down to bare metal, then you should prime that area and, if you end up with a patchwork of colours, you might be as well to prime it anyway, just to give you an even base colour.
There you are, that's my tuppence
(puts on nomex suit and waits to be flamed) ____________________ Things get better with age; I'm close to being magnificent........
| owl10 |
 owl10 Could Be A Chat Bot
| spetom |
 Posted: 13:24 - 29 Jan 2011 Post subject: |
Thanks Shaft.
With the metal tank I reckon its less of a problem, I've resprayed metal before, manually stripped the paint with fine emery + water, I'm thinking chemical is probably a better way to get to the base as there is always a chance you slightly sand down the metal itself (but I've never tried this). Then primer, maybe zinc primer then paint.
It's the plastics I really have no idea about.
Likewise await flame.  |
| gray84 |
 gray84 World Chat Champion
| ZRX61 |
 ZRX61 Victor Meldrew
| tutton |
 tutton World Chat Champion
| stirlinggaz |
 Posted: 00:29 - 30 Jan 2011 Post subject: |
hi all,
been a while since i posted/replied to anything, but i've done a fair bit of re-spraying & offer my opinions/experiences.
there are are a couple of pros on here & can give you some good advice. (such as ZRX61-who may suggest some products which are hard to source in the UK, but well worth listening to & TUTTON, whos also good for advice etc)
anyhow, assuming your not a pro & dont have access to the tools & products that are available to them, heres what i do, with reasonable results.
wet & dry everything. (theres a few on-line guides available, which i have found invaluable)
get good products & get as many different grades as possible of wet & dry.
wheels - give to powder coaters & they will shot/media blast them & powdercoat them in your chosen colour. far easiest option & sometimes cheaper than DIY (30 quid a wheel?), & pretty fast turnaround.
though i have used nitromors on wheels & painted them pretty successfully myself, but its all in the prepping & it can be pretty messy & time consuming but once painted & clearcoated a few times, it seems to be fairly tough.
plastics - wet & dry, grey primer, basecoat (colour) & then lacquer. & polish, im presuming you have a compressor & gun?
if not, well worth getting a small home compressor & half decent guns.
i use a small compressor, which is perfectly adequate for fairings etc, though the bigger the compressor the better, obviously,lol
i use a cheap gun, with slightly bigger nozzle for filler primers, hvlp gravity fed gun for tanks,bigger panels etc. & a small gravity fed gun for touch ups etc.
never had any issues with old colour leeching through.................though sealer has been suggested to me before.....
i have just re-sprayed some plastics white, which were previously red (mito panels) & i just rubbed them as flat as possible, using decent wet & dry, then gave them a good few coats of filler primer (beige?)& then painted as normal (& i've done this a few times) clearcoated a few times, added decals, then clearcoated again.
guess im not saying anything thats not been said before, so i'll stop rambling on,lol
post the pics? before, during & after?
im always interested to see other peoples attempts at re-spraying.
good luck,
cheers,
GAZ
| tutton |
| stirlinggaz |
 Posted: 04:25 - 30 Jan 2011 Post subject: |
looking good.......................
particularly like the mettalic paint.
my results are not quite as good/professional looking, but for jobs done in my spare room look ok,lol
(new pc but will upload a few before/during/after pics of my most recent attempts, once i've set it up properly)
coincidently, im just about to do my r30 & another mito, (both needing damage repair & full re-sprays, a so i'll do a "start to finish" post if anyones interested.
cheers,
GAZ |
The last post was made 15 years, 221 days ago. Instead of replying here, would creating a new thread be more useful? |
