| hellbound |
 hellbound World Chat Champion
| Anthony192 |
 Anthony192 Nova Slayer
| Clanger |
 Clanger Stirrer
| P. |
 P. Red Rocket
| hellbound |
| pinkyfloyd |
 pinkyfloyd Super Spammer
| hellbound |
| johnsmith222 |
 johnsmith222 World Chat Champion
| weasley |
 weasley World Chat Champion
| Dave McCool |
 Dave McCool World Chat Champion
| clancy |
 clancy World Chat Champion
 Posted: 22:49 - 27 Jan 2011 Post subject: |
daylight hours only. says it on the visor on most of them, saying that, i have never been pulled for it, or know anyone that has  ____________________ KLX 300r |
| Yarri |
 Yarri Crazy Courier
 Posted: 23:26 - 27 Jan 2011 Post subject: |
I'd say if you use mirrored you will never have a problem, i was using it for as long as i was a biker, been filtering past coppers and even chatting to them on the lights with visor down, trust me they're too busy wanking each other off rather then pulling you for stupid reason like a tinted visor. ____________________ Theory Passed: 23/10/2008 49/74 Bike Test Passed: 05/01/2009 1 minor
Theory Car Passed: 22/07/2009 48/74 Car Test Passed: 22/10/2009 2 minor
Few minutes of life of the biker could be more interesting then the whole lifes of many people |
| Digitalize |
 Digitalize Nearly there...
| Highside_Hilly |
 Highside_Hilly Renault 5 Driver
| andyscooter |
 andyscooter World Chat Champion
| Jim Mc |
 Jim Mc Nearly there...
| Kickstart |
 Kickstart The Oracle
 Posted: 11:10 - 28 Jan 2011 Post subject: |
The visor needs to have the relevant markings to say it complies. Not only for light transmission (50%, which is a very light smoked visor) but also impact resistance and scratch resistance.
Using one that doesn't have the relevant markings is illegal (even if it is a blind pillion using it), and can result in a ticket.
The police seem to go through phases of ignoring them or ticketing them. Most of the time you will probably be fine using one.
A lot of visors have "if tinted for daytime use only" but this doesn't have any legal meaning.
| JamesE90 |
 JamesE90 Renault 5 Driver
| Kickstart |
| c_dug |
 c_dug Super Spammer
| Kickstart |
| Rogerborg |
 Rogerborg nimbA
 Posted: 13:43 - 28 Jan 2011 Post subject: |
First, find a copper who's actually sure what the law is.
Your first gambit should be to suggest that they check with the station, just so you're both clear.
Here's what I've read:
Motor Cycle (Eye Protectors) Regulations 2000
...which adds ECE 22.05 to the list of approved visors in...
Motor Cycle (Eye Protectors) Regulations 1999
Which mentions "transmit 50 per cent or more of the light" only in relation to "those which were first used before 1st April 1989".
There is no mention of light transmission for protectors marked "Grade X in British Standard BS 4110:1979"standard, "Grades XA, YA or ZA in British Standard BS 4110:1979 as amended by Amendment No. 1 (AMD 3368), Amendment No. 2 (AMD 4060) and Amendment No. 3 (AMD 4630)" or ECE 22.05.
If you can find such a visor with a tint, then there's nothing in any Statutory Instrument that I can find which prohibits you from using it.
You probably can't, but you should be clear that light transmission only applies to pre-1/4/1989 items. Post that, you require an appropriate BS or ECE mark - tint is or should be irrelevant, although it'll be what gets your visor checked for the mark.
Anecdotally, here's James May's experience of riding through London without his helmet on his arm, wherein he suggest that the offence carries only a fine, not penalty points. Buggered if I can find the tariff for it though. ____________________ Biking is 1/20th as dangerous as horse riding.
| Kickstart |
 Posted: 14:31 - 28 Jan 2011 Post subject: |
The BS standard applied a min light transmission level. The legislation doesn't apply a level of light transmission because it enforces the visor to comply entirely with a standard that does specify a level of light transmission.
The EU directives mentioned in the UK legislation don't seem to apply any kind of testing, just aiming for testing to be recognised between countries (ie, it isn't a standard that the helmet must reach, rather it is a standard for the standards that are acceptable for a helmet). As such I think it is merely an extension allowing accepted non UK standards.
The relevant one seems to be ECE 22.05:-
https://www.unece.org/trans/main/wp29/wp29regs/r022r4e.pdf
And that does list min light transmission.
The only bit of the legislation that does specify light transmission is the exemption for old prescription eye protection which was first used before 01/04/1989.
So your visor must comply with BS4110 (which specifies light transmission), ECE 22.05 (which specifies light transmission) or is old prescription eye protection which transmit 50 per cent or more of the light.
| Snorty |
 Snorty World Chat Champion
| Rogerborg |
 Rogerborg nimbA
 Posted: 17:39 - 28 Jan 2011 Post subject: |
Ah, the elusive 22.05! Thanks for tracking that down.
| ECE 22.05 wrote: | Visors shall have a luminous transmittance τv $ 80%, relative to
the standard illuminant D65. A luminous transmittance
80% > τv $ 50%, measured by the method given in
paragraph 7.8.3.2.1.1., is also permissible if the visor is
marked with the symbol shown in figure 2 and/or with the English
words ADAYTIME USE ONLY@. The luminous transmittance shall be
measured before the abrasion test. |
And that's about the simplest paragraph in there.
This is why I have my doubts that all helmets actually meet 22.05, rather than the Chinese factory just slapping a sticker on them, then getting back to their stock trade of poisoning baby formula. ____________________ Biking is 1/20th as dangerous as horse riding.
The last post was made 15 years, 8 days ago. Instead of replying here, would creating a new thread be more useful? |
