Worth it? Honda NS125 engine in RS50 frame .....
Jamie S
PostPosted: 19:30 - 28 Jan 2011    Post subject: Worth it? Honda NS125 engine in RS50 frame ..... Reply with quote
I have an old Honda NS125 sat in storage, it needs a load of work doing, has no tax or test, all bearings nackerd, tyres shagged, C&S shagged...... The list goes on.... but , it does have a great running engine.
So , I had a thought, I have a 2001 RS50 rolling chassis sat here, sold the engine ect a while back, So I'm considering fitting the NS engine to the RS chassis.
What do you think ? I'm considering having it for messing about at trackdays, or might even try and flog it on to some 16 year old edjit ...... ?
I never got to ride the RS, so ive no idea what it handled like, should of thought that with a 125 engine it would be good fun though ?
Any one know what power an NS125 engine puts out ?
Jamie
PostPosted: 19:40 - 28 Jan 2011    Post subject: Reply with quote
Stock NS UK engine puts out about 12hp. Derestricted probably high teens power.
How old is the RS? Alloy frame or steel frame? If alloy then frame mods are likely to be far more difficult.
Getting the exhaust to fit will be difficult, and if it is a decent unscuffed exhaust then please don't wreck it!
Suspect the RS chain will stretch like an elastic band with the NS engine.
Doesn't the RS50 6V electrics.
No idea how much space there would be for the NS engine.
Jamie S
PostPosted: 19:50 - 28 Jan 2011    Post subject: Reply with quote
Was hoping you would reply .... Wink
Is that all,12 bhp.... Confused
The RS has an Ally Frame with Steel lower cradle, the exhaust thats on the NS is a chrome "allspeed" if i rememeber correct.
Didn't think about the electics , will have to check what the RS wiring runs on..... Embarassed
Space wise it seems ok.
TBH if it's only going to be 12hp then maybe it's not even worth it... Crying or Very sad
PostPosted: 19:57 - 28 Jan 2011    Post subject: Reply with quote
If it has an Allspeed exhaust then it will be derestricted, so probably high teens power. Honda were very keen on complying with the old 9kW / 12hp learner law. Not much you can do about the lack of ATAC power valve.
However even more so, do not trash a decent Allspeed on the NS.
Jamie S
PostPosted: 20:06 - 28 Jan 2011    Post subject: Reply with quote
Ok, I might look at using a diffirent engine then, and selling the NS on, I know I will never get what I payed for it though, which is why I was considering the transplant, then sell on whats left of the NS.
Jamie
PostPosted: 20:15 - 28 Jan 2011    Post subject: Reply with quote
Advantage of the NS engine is that there is no external power valve electrics or anything.
Jamie S
PostPosted: 20:19 - 28 Jan 2011    Post subject: Reply with quote
True, suppose it all hinges on the RS electrics being 12 volts..... Praying
Will have a look tomorrow.
Jamie
PostPosted: 20:54 - 28 Jan 2011    Post subject: Reply with quote
Just replace the entire RS loom with the NS one, use the NS clocks worse comes to worse you need new bulbs/indicators to fit. That way the tacho, idiot lights etc. will work instantly if you use the NS clocks and loom on the RS. The speedo maybe more difficult.
Teflon-Mike
tl;dr
PostPosted: 21:27 - 28 Jan 2011    Post subject: Re: Worth it? Honda NS125 engine in RS50 frame ..... Reply with quote
Probably not, if you tally the time, effort and expense, and the performance you'll get for it.... but as a 'project'?
Could be fun, and certainly interesting, depending.
For a road bike, though, trouble with stuffing a big motor into a moped frame is mopeds enjoy a lot of Construction & Use 'exemptions' so even though the RS chassis is more than up to it, technically it should be subject to single vehicle approval to get it registered as a motorcycle post mods.
For a track-bike?
I'd be building to some defined and preferably popular class reg, so I could use it for more than track-days if I wanted to, or be able to sell it on more readily.
On either score, think that a 125 MX motor, with more than double the power the NS lump chucks out would make the reward for the effort more worth-while.
Be more inclined to try and sort the NS... as is. I mean, you say it needs new C&S, but fitted to the RS it would too.... and where the NS may need new Headrace bearings, wheel-bearings, suspension bushes, brake pads and stuff.... stuffing even a 15bhp motor into an old chassis designed to take just 3... you're going to be doing plenty of reconditioning to that bike to be sure its up to handling the added!
Jamie S
PostPosted: 21:41 - 28 Jan 2011    Post subject: Reply with quote
The NS isn't worth spending a penny on, it already owes me £300, ive since lost the key, it needs two new tyres, swing arm bearings, front and rear wheel bearings, new front disk and pads, chain and sprockets, headstock bearings replacing/adjusting, fork seals, and would need a new set of farings which are hard to find, not forgeting painting the frame, tank not to mention an mot tax ect...... the list goes on ,it's a nail thats worth nothing even when done tbh.
Jamie
nsr_J22_FOXEYE
PostPosted: 10:56 - 29 Jan 2011    Post subject: Reply with quote
Yes it is worth doing:
Source of information: I'm the ejit that would be interested in buying it from you
So long as you keep the labour down below £1000 and parts and the bikes don't owe you much then do it... and have fun. I can see many hours of smoking and coffee drinking but the end result would be fun for a track bike. Very Happy
Never Ride Faster Than Your Angel Can Fly
Jamie S
PostPosted: 20:18 - 29 Jan 2011    Post subject: Reply with quote
Might look at somthing equaly as compact and simple, but more power, maybe along the lines of an old CR250 engine..... Cool
stirlinggaz
PostPosted: 02:53 - 30 Jan 2011    Post subject: Reply with quote
personally wouldnt bother trying to transplant the ns engine into the rs...........
although you dont want to spend any time/money on the ns, (i can understand why, when your never going to get much over £500 for a complete bike) i would consider selling the ns parts.
there are plenty of people out there who would pay for the 18bhp ns lump, with a good exhaust (like the allspeed) & set up carb.
i know, i had an old ns which i bought for £300 & then sold it some time later........which i still regret.
i could have sold the engine & exhaust (micron, or gibson iirc) a hundered times over. (they can be fitted to other bikes but no idea about the rs)
great little bikes when looked after, even if they arent the most "trendy", sought after or fastest. the parts are cheap s/h & its a very easy bike to work on, with parts from other hondas from that era which are interchangeable..
mines was good for 80mph, done the 40 mile commute day in/out, no complicated pv's etc to worry about, very reliable 2t 125, not many of those around nowadays.
the rs 50? plenty of s/h engines around that would cost less than you would make from the ns parts...........
cheers,
GAZ
Jamie S
PostPosted: 19:11 - 05 Feb 2011    Post subject: Reply with quote
Haha! I'm not stripping a complete running bike for just a 50 quid barrel..... Also, why bother sending me a pm if you have asked in this thread??? Rolling Eyes
PostPosted: 19:33 - 05 Feb 2011    Post subject: Reply with quote
Jamie
Was the previous owner a guy called Steve?
Jamie S
PostPosted: 19:40 - 05 Feb 2011    Post subject: Reply with quote
No but it's almost as shocking as his !
stevo as b4
PostPosted: 00:10 - 06 Feb 2011    Post subject: Reply with quote
The NS125 in full power form was supposed to be 22bhp at the crankshaft, so figure on 18-19bhp r/w. That's a decent amount for a 125cc even today, and i think that it would make for a very interesting and nippy conversion into the RS50 frame, which is possibly a stronger and more rigid design than the NS chassis. The brakes will probably cope ok, with the power and 85mph potential, but you might need to uprate the suspension to cope with the added weight.
Seeing as you already have a running NS125 engine and a Rolling RS50 chassis, then you should at least offer the engine up to the frame and see how it looks for size, and what needs moving and modifying to allow it to fit before you make a final decision.
Jamie S
PostPosted: 20:46 - 19 Jun 2011    Post subject: Reply with quote
Going to go ahead with this now I'm unemployed and have a bit of time on my hands!
Will start a thread in show and tell in the next week or two!
Jamie
alains
PostPosted: 15:18 - 20 Jun 2011    Post subject: Reply with quote
RIDICULOUS !!!!!!!
Frost
PostPosted: 15:43 - 20 Jun 2011    Post subject: Reply with quote
Stick the engine on some blocks and put the chassis on top of it. If it looks like it'll fit i'd give it a go.
An RS50 frame is worth nothing, the wheels and stuff could be sold, but that remains true even if you attempt it and fail. The same goes for the NS motor. So get a mate who knows how to fabricate to give you a hand and see what you can do.
mysterious_rider
PostPosted: 16:06 - 20 Jun 2011    Post subject: Reply with quote
to be fair, im still halfway going through a two stroke enging convertsion with a pitbike.
engine swaps are HARD.
Lining up of the sprockets, sorting of the electrics, fitting it actually into the frame,
and you still have to sort an exhaust.
IMO bearings cost F ALL, go and fix the ns up. It won't cost that much, and at least at the end of it you will have a nice old school bike.
The last post was made 15 years, 148 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.41 - MySQL Queries: 13 - Page Size: 117.81 Kb
