6v to 12v conversion honda c90
Alex_
PostPosted: 09:09 - 30 Jan 2011    Post subject: 6v to 12v conversion honda c90 Reply with quote
Hi there I had been told this was possible to change this engine from 6 volt to 12v?
The engine is on a go kart so no need for lights etc
Anyone done this? And what materials do I need
Thanks for looking
Teflon-Mike
tl;dr
PostPosted: 10:47 - 30 Jan 2011    Post subject: Re: 6v to 12v conversion honda c90 Reply with quote
Thanks for looking
If there's no need for it to power lights and accessories ect...
Why bother?
I mean only other thing electrics are doing is running the ignition, in which case what difference does it make?
Alex_
PostPosted: 11:00 - 30 Jan 2011    Post subject: Reply with quote
sorry should of said, my wiring is in such a mess. im not getting a spark on it. rather than buying a replacement loom i thought it would be cheaper doing it this way as thats all im after, ignition.
hope that makes sense. cheers
PostPosted: 11:12 - 30 Jan 2011    Post subject: Reply with quote
Changing it from 6v to 12v won't get you a spark if your wiring is a mess, best to rip all the wiring out and do it from scratch with just the wires you need. Once the lights and horn are ignored, there's very little left.
https://oldmanhonda.com/MC/WiringDiagrams/C90.jpg
nsr_J22_FOXEYE
PostPosted: 11:13 - 30 Jan 2011    Post subject: Reply with quote
Just put a step down before you hit any of the original parts on your own made wiring loom ?
Never Ride Faster Than Your Angel Can Fly
Alex_
PostPosted: 11:36 - 30 Jan 2011    Post subject: Reply with quote
i purchased it this way mate.
here a few pics of how it is...
https://i34.photobucket.com/albums/d129/ll_sarah_ll/IMG_0120.jpg
https://i34.photobucket.com/albums/d129/ll_sarah_ll/IMG_0119.jpg
https://i34.photobucket.com/albums/d129/ll_sarah_ll/IMG_0113.jpg
Alex_
PostPosted: 21:12 - 01 Feb 2011    Post subject: Reply with quote
hi again, i was told i could rig up he 6 volt battery to my wiring the way it is, sorry im not good at reading diagrams so anyone able to tell me what wires i join to the battery?
thanks
finpos
PostPosted: 22:14 - 01 Feb 2011    Post subject: Reply with quote
You need the red wire on the coil to go to battery +ve and the green wire on the coil to go to the points under the cover.
You also need to make sure there is an good earth (battery -ve, engine, coil) and it would be best to add a kill switch (aka, a loose bit of wire connected to the coil green wire which you can touch to the battery -ve to stop the engine)
Finally, you need to make sure you have the thing marked "capacitor" connected between the coil green wire and ground.
Battery won't charge but engine should run.
f.
Alex_
PostPosted: 11:55 - 03 Feb 2011    Post subject: Reply with quote
Mad no wires on this make any to any diagram i can find, i purchased a second hand coil from a c50(are they the same?)
cheers
finpos
PostPosted: 18:50 - 03 Feb 2011    Post subject: Reply with quote
Ok, coil should have two terminals on it, hopefully marked "+" and "-".
+ goes to the battery +ve. convention says this wire is red.
- goes to the points and to the capacitor and also go to your kill switch. Usually all 3 are green wires.
Then everything needs earthed. should spark!
No markings = trial and error Smile
f.
Alex_
PostPosted: 19:35 - 03 Feb 2011    Post subject: Reply with quote
no mate this one doesent Mad just one wire black and white, i thought the c50/c70/c90 6 volt coil were the same?
https://i34.photobucket.com/albums/d129/ll_sarah_ll/IMG_0146.jpg
The last post was made 14 years, 357 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.33 - MySQL Queries: 13 - Page Size: 68.88 Kb
