Hayabusa
DXB
PostPosted: 09:13 - 01 Feb 2011    Post subject: Hayabusa Reply with quote
Right gents here's the problem.
When giving it the berries it cuts out, when i open it up slowly it does not seem to bad, now as you can imagine having this thing cutting out and then chiming back in is not a good thing.
Just got back home after a quick shake down and now it wont start.
Any helpful suggestions as to what may be causing this.
superchargers good
Teflon-Mike
tl;dr
PostPosted: 09:17 - 01 Feb 2011    Post subject: Re: Hayabusa Reply with quote
If I hadn't got a nagging idea in the back of my head the busa might be fuel injected, I'd say carburettor diagphrams.
PostPosted: 11:44 - 01 Feb 2011    Post subject: Reply with quote
Fuel pump filters. Clean them out, all in all there are seven of them. Three in the picture and one in the top of each injector. Expect to find them clogged with a brassy coloured goo, especially the small dome filter in the pump and the round plastic screen one. The paper one you can really ignore.
I'm guessing you have an early 'busa with 15-20k miles on it. That's whenn they usually clog up.
PostPosted: 11:52 - 01 Feb 2011    Post subject: Reply with quote
Actually, now I've re-read your post, it souinds more like fuel lines. They are a 4-yearly replacement item so if you have the original then I bet one of them is kinking when it gets hot. Replace them (they are not much to buy) as they are a superceded item, and do the filters while your at it. Also change the fuel pump fuse from 10a to 15 or it'll blow and leave you stranded soon after you do the filters (don't ask me why I have no idea but it catches load out including yours truly).
DrDonnyBrago
PostPosted: 11:56 - 01 Feb 2011    Post subject: Reply with quote
Out of interest, what is the brassy coloured goo?
Stale fuel?
PostPosted: 11:59 - 01 Feb 2011    Post subject: Reply with quote
Bits of fuel pump. Sliding vane pump though so self-compensating, it works fine once cleaned out. The late 2000 bikes got a different part number so didn't suffer it. Trouble is the 'busa wasn't a great early seller due to the price of bikes at the time so a lot of the early 99 bikes got a 2000 plate, like mine.
DXB
PostPosted: 04:35 - 02 Feb 2011    Post subject: Reply with quote
Cheers Pete.
Will rip it apart this weekend and have a look.
superchargers good
PostPosted: 04:39 - 02 Feb 2011    Post subject: Reply with quote
No problems.
Don't rip off the heat shield foam and throw it away like many do, you'll have vapour-locking problems in hot weather if you do.
DXB
PostPosted: 05:11 - 02 Feb 2011    Post subject: Reply with quote
Excellent Gen thanks again, as luck would have it my Son is off sick today so he can fix it, have also got him fixing the jetski as wading into the cold sea is a sure fire way of fixing his Man flu.
superchargers good
DXB
PostPosted: 08:36 - 15 Feb 2011    Post subject: Reply with quote
This is the bit as per the diagram but i can not see a filter, help.
superchargers good
DXB
PostPosted: 09:00 - 15 Feb 2011    Post subject: Reply with quote
Again as per the diagram.
superchargers good
PostPosted: 09:23 - 15 Feb 2011    Post subject: Reply with quote
That white plastic housng just comes out with a sharp tug using pliers. Watch out though cos the filter is spring loaded behind it.
Inside the rear housing where the fuel pipes are, there's another plastic sleeve you can pull out. In the end of that there is a plastic screen filter that is removable. That is the one that is most likely to be blocked.
Inside that little hole should be a brass gauze dome filter. If it's not there then a previous owner has removed it.
The last post was made 15 years, 260 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.72 - MySQL Queries: 13 - Page Size: 75.23 Kb
