Leaving charger connected- updated, new battery
RussG
PostPosted: 19:20 - 01 Feb 2011    Post subject: Leaving charger connected- updated, new battery Reply with quote
If I leave my charger connected to my battery but not powered on at the mains will it drain my battery?
Geek, father, biker
PostPosted: 19:26 - 01 Feb 2011    Post subject: Re: Leaving charger connected Reply with quote
If it's got some indicator lights that light up etc when not plugged in then definitely; depending on how powerful the lights are whether it's noticeable or not. Otherwise, possibly, but probably not I reckon.
PostPosted: 19:29 - 01 Feb 2011    Post subject: Reply with quote
Fail to see why you can't just unplug it?
RussG
PostPosted: 19:32 - 01 Feb 2011    Post subject: Reply with quote
the idea was i could just plug it in for half hour before i leave the house, as bike is kept in a shed at the bottom of the garden and would save me having to get dressed to go out side, connect it up etc. so 50% laziness 50% practicality
Geek, father, biker
PostPosted: 19:35 - 01 Feb 2011    Post subject: Reply with quote
Confused
Why would you need to plug a charger in to your bike 30 minutes before starting it? Knackered battery?
RussG
PostPosted: 19:43 - 01 Feb 2011    Post subject: Reply with quote
it's not been starting well at all recently. borrowed a friends charger, charged it for few hours and it's started on the button. SO guessing the battery is b0rked, but NEED to take the bike to work tomorrow, as wifey needs the car. So really could do with it starting.
So not sure whether to buy my own charger or a new battery.
Geek, father, biker
PostPosted: 19:46 - 01 Feb 2011    Post subject: Reply with quote
Carbs, or FI?
If carbs just bump start it.
Why not just leave it on charge overnight?
RussG
PostPosted: 19:49 - 01 Feb 2011    Post subject: Reply with quote
had a full service and carbs cleaned less than two weeks ago and still not sorting it, have been bumping but didn't want to bump this morning.
I could leave it on charge overnight, but the double glazing we have shuts too tight to close it on the wire and don't really want to leave the window open.
Geek, father, biker
Blue_SV650S
PostPosted: 20:50 - 01 Feb 2011    Post subject: Reply with quote
It will more than likely have a diode in it to ensure no back-feed. So yes it will be fine (unless as G said, it has lights on it when unplugged).
RussG
PostPosted: 21:59 - 01 Feb 2011    Post subject: Reply with quote
Thanks for the help guys
Geek, father, biker
finpos
PostPosted: 22:56 - 01 Feb 2011    Post subject: Reply with quote
Entirely depends on whether it's fitted with a diode to stop it discharging into the charger - the diode costs about 5p but it's sometimes taken out to save money!
f.
RussG
PostPosted: 16:47 - 14 Feb 2011    Post subject: Reply with quote
Thanks for your help previously guys, i'm going to replace the battery.
At present the battery is marked - 12N7-4A ,are these all the same? Is there a brand to avoid/look out for? ican it be fitted with another "uprated" battery?
forgive my ignorance, my bike has had to endure a very shitty winter.
Geek, father, biker
PostPosted: 16:58 - 14 Feb 2011    Post subject: Reply with quote
I'm using a Motobatt gel type battery. They come pre-charged.
My duc is a big twin and needs a good strong battery to spin it up.
Performed well in conprehensive A-B tests.
Check the compatability on the motobatt website, then look on e-bay.
finpos
PostPosted: 17:26 - 14 Feb 2011    Post subject: Reply with quote
The battery designation just tells you the size of the battery and the type and layout of the terminals. What you really care about is the capacity rating stated in Amp/hours (Ah); the more the better. However more Ah usually comes with more size so usually you just get what fits.
Generally you get what you pay for - there's lots of relatively cheap traditional lead acid batteries about which frankly seem a bit crap and fail quickly. Either go for one of the more expensive traditional ones or if you don't mind a sudden price hike (about an extra 50%) you can get an AGM battery which really are very much more robust.
mdsbattery.co.uk is another good place to look around to get an idea.
f.
RussG
PostPosted: 17:27 - 14 Feb 2011    Post subject: Reply with quote
Thanks HT & finpos, i'll check them out
Geek, father, biker
The last post was made 15 years, 148 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 2.29 - MySQL Queries: 13 - Page Size: 84.79 Kb
