Clutch
Wilson12345 This post is not being displayed because the poster has bad karma. Unhide this post / all posts.
andym
PostPosted: 03:46 - 03 Feb 2011    Post subject: Reply with quote
[wanders in]...
about 27 quid if it's just the plates.... although I ain't got a clue about anything man
[saunters back out again]
Ichy
PostPosted: 07:50 - 03 Feb 2011    Post subject: Reply with quote
Only other thing is to make sure the cable is adjusted correctly and that the clutch return arm is moving OK.
swanny
PostPosted: 08:48 - 03 Feb 2011    Post subject: Reply with quote
can get the plates from either Paul Smeatons BItz for Bikes or from Wemoto.. if your not sure how to do it yourself might be looking around an hours to hour and half ( most garages will try and milk for that bit extra)..
Prob looking around 80-100 quid for a garage, if you reckon you can do them yourself get a haynes and have a go. all you have to do is basically strip them out, check them, soak some new ones in oil overnight and then replace the exact same way they came out.. (OB bit more to it)...
M SWANNY.. see a sig !
Frost
PostPosted: 09:33 - 03 Feb 2011    Post subject: Reply with quote
Willing to bet quite heavily that the plates are fine, the cable just needs adjusting on the handlebar.
The last post was made 15 years, 167 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 2.33 - MySQL Queries: 13 - Page Size: 47.6 Kb
