Motorcycle Engine Physics!
Paulington
PostPosted: 01:00 - 04 Feb 2011    Post subject: Motorcycle Engine Physics! Reply with quote
Hey guys, just discussing some stuff in FB chat and thought I'd make a little post, it might interest some of you and I'm sure the videos are reposted!
In this post I will be discussing the physics of the BMW S1000RR engine.
Before reading below, watch these two videos:
Cams & valve springs: https://www.youtube.com/watch?v=8-ymU7ETnnY
Valves: https://www.youtube.com/watch?v=Ed-l2Ot_d9c
Right then, let's get into the nitty gritty, bit of maths to follow!
At 14500 RPM (as far as I know the redline of the S1000RR), the pistons are moving up and down 242 times per SECOND.
This means each valve set is opening 60 times per second.
However!
The most impressive statistic is that per STROKE of each piston in the S1000RR engine (each stroke takes 0.002 seconds or 2 milliseconds, which means that in a blink of an average human eye, a piston has completed a cycle around 100 times!) the piston follows the same timescale:
0 Milliseconds: Bottom dead centre, piston is not moving.
0.001 Milliseconds: Piston begins accelerating.
1.0 Milliseconds: Piston is moving at full speed (roughly 12mph).
1.001 Milliseconds: Piston begins decelerating.
2.0 Milliseconds: Piston reaches top dead centre and has stopped.
WHENEVER the piston is accelerating or decelerating it is moving at 1266G.
1266G Means that for the duration of time the piston is accelerating, it weighs 1266 times its actual weight. The piston on the bike weighs 0.253kg, this means during acceleration/deceleration, it weighs 321kg!
In my opinion, these numbers are astonishing and are a testament to the engineering behind the supersports engines of today. I apologise if I've bored you with a discussion about engine physics but I know some of you may appreciate it.
If there is anything else you would like to know in this kind of area, do let me know and I will do my best!
kestrel
PostPosted: 02:06 - 04 Feb 2011    Post subject: Re: Motorcycle Engine Physics! Reply with quote
Thats kinda slow compared to the Honda 50cc 4 stroke RC116 which produced 16bhp at 21,500 RPM. With a redline of 22,500 RPM, the pistons will have travelled up and down 375 times per SECOND
Paulington
PostPosted: 02:22 - 04 Feb 2011    Post subject: Re: Motorcycle Engine Physics! Reply with quote
Well yes, there is no denying faster revving motorcycles do exist, however take in to account the piston of the RC116 would have been about 2.25 times smaller than that of the S1000RR which a lot less reciprocating mass.
Also, you can be damn sure that engine didn't last long, whereas as far as I know the S1000RR has services intervals of roughly 6000-8000 miles!
kestrel
PostPosted: 02:38 - 04 Feb 2011    Post subject: Reply with quote
There's no doubt that the S1000RR engine would outlast that of the RC116 but engine longevity was hardly the point of your original post, assuming of course that there actually was a point to it. Also bear in mind that the S1000RR is a modern 21st century machine which make use of modern materials and engineering technology, whereas the RC116 was developed 45 years ago.
Paulington
PostPosted: 02:42 - 04 Feb 2011    Post subject: Reply with quote
The whole point of the post was to showcase to people the amazing physics at work inside an engine and how incredible it is the engine can do such things for any extended period of time to make it viable for use in the real world.
Billing
PostPosted: 02:49 - 04 Feb 2011    Post subject: Reply with quote
Except Honda did it over 20 years ago Mr. Green
Thats the same as both of my Honda's do stock, never realised just how much each piston moves! I worked out that in the year that I had my 50, the piston had covered some crazy distance (it used to average 8000rpm, for 2 hours a day, for about 250 days)
I'd like to hook a cutaway engine up and see just what a 14.5k piston looks like, a blur, but an impressive one!
DrDonnyBrago
PostPosted: 08:32 - 04 Feb 2011    Post subject: Reply with quote
I can give you S1000RR valves at 14.5k... but no pistons I'm afraid.
https://www.youtube.com/watch?v=QuWiZ5nVKzA
Frost
PostPosted: 08:55 - 04 Feb 2011    Post subject: Reply with quote
The little bikes have a shorter stroke so the piston speed is lower.
hmmmnz
PostPosted: 09:49 - 04 Feb 2011    Post subject: Reply with quote
what an exceedingly geekish topic,
i love engines and i love they work but id never dedicate a thread to
how fast a piston moves,
but hey it would be a boring world if we were all the same..
unless all you fuckers were me
the humans are dead
I kick arse for the lord
DrDonnyBrago
https://www.youtube.com/watch?v=sEf8va1S7Sw&feature=related
This is cool. An 'in cylinder' view of a 4t engine in slow motion.
sickpup
Old Timer
PostPosted: 10:48 - 04 Feb 2011    Post subject: Reply with quote
Have they managed to exceed 25metres per second average piston speed?
PostPosted: 11:02 - 04 Feb 2011    Post subject: Re: Motorcycle Engine Physics! Reply with quote
Strictly speaking probably not true on the point that piston max speed is reached after 1 millisecond, as that is suggesting it is directly related to the rotation of the crankshaft. Con rod length will change the exact moment that happens.
49.5mm stroke. At 14500rpm it is doing that 241.667 times in each direction a second. So a mean piston speed of 23.925 metres per second.
hmmmnz
PostPosted: 11:10 - 04 Feb 2011    Post subject: Reply with quote
49.7mm stroke
14200rpm redline
so 14200/60=236.666667
236.666667x2 (1 up and 1 down per rev)
473.333334 strokes per second
473.333334x49.7=23 524.6667mm/s
or 23.5m/s or 52.5mph
so no Very Happy
the humans are dead
sickpup
Old Timer
PostPosted: 11:11 - 04 Feb 2011    Post subject: Re: Motorcycle Engine Physics! Reply with quote
So they've kept it to the safe side of 24mps.
Thank you.
PostPosted: 11:17 - 04 Feb 2011    Post subject: Reply with quote
Yep. Just got the revs by shortening the stroke.
DrDonnyBrago
PostPosted: 11:18 - 04 Feb 2011    Post subject: Reply with quote
What happens at 25ms-1 mean piston speed?
Do we make antimatter?
PostPosted: 11:35 - 04 Feb 2011    Post subject: Reply with quote
It is regarded as pretty much the limit of mean piston speed. While revs have increased over the years mean piston speed hasn't massively changed.
Frost
PostPosted: 12:37 - 04 Feb 2011    Post subject: Reply with quote
I think it's likely due to the rate of expansion of the burning fuel inside the cylinder. At > 25m/s the piston is probably travelling faster than the expansion is pushing it, so it'll slow down. So you can get > 25m/s by kicking the bike down a gear when on the redline, but it'll soon slow down Laughing
DrDonnyBrago
PostPosted: 12:48 - 04 Feb 2011    Post subject: Reply with quote
A wee googling suggest that top fuel engines can apparently exceed 30 ms-1 so the rate of burning could make sense Thumbs Up .
The S2000 reaches 25.2 ms-1 Surprised .
PostPosted: 13:28 - 04 Feb 2011    Post subject: Reply with quote
Vaguely relevant object lesson in piston speed, G-force and what that would mean if a piston from a V16 diesel locomotive engine making 4400hp suddenly wasn't attached to the conrod any more.
Clicky
Might be a repost.
PostPosted: 13:58 - 04 Feb 2011    Post subject: Reply with quote
Not sure it is flame speed related. It is mean piston speed, so at times it will be travelling a hell of a lot faster (also happens to be close to the times when the con rod is applying the max turning force on the crank).
Ditto
PostPosted: 16:25 - 04 Feb 2011    Post subject: Reply with quote
I was told on my CBT that a more powerful motorbike is easier to manoeuvre at lower speeds as the movement of the pistons gives the bike more 'weight' so to speak.
As in the centre of gravity is lowered by the movement of the pistons.
If you pull the clutch in when you are moving at 30-40mph you feel the bike become 'lighter' so to speak and harder to move around due to the revs dropping.
It feels strange, like you are on a push bike at 40mph and is probably quite dangerous. I guess its the reason motorbikes are so stable at high speeds.
CG 125 > Bandit 600 > CBR 600 FY > Street Triple R
PostPosted: 16:31 - 04 Feb 2011    Post subject: Reply with quote
Don't think that is the pistons, as on a 4 when one pair is flying down another pair is flying up.
However yo do have a crank in there that is acting like a flywheel
Frost
PostPosted: 16:42 - 04 Feb 2011    Post subject: Reply with quote
Essentially a bike has 3 wheels, in terms of gyroscopic stabilisation anyway, with the crank being the 3rd wheel. Revving a bike when at low speed can help stabilise it a bit. Similarly revving can destabilise the bike causing the front end to go light when accelerating hard. To counter this some GP bikes had the crank spin the other way, or had 2 counter rotating cranks to balance out the force.
The last post was made 15 years, 288 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.08 Sec - Server Load: 0.31 - MySQL Queries: 13 - Page Size: 137.95 Kb
