3 displays
pickettwayne
PostPosted: 11:44 - 04 Feb 2011    Post subject: 3 displays Reply with quote
Hey Guys,
Am I right in thinking I shouldn't of purchased this item XFX HD 5450 512MB DDR2 VGA DVI HDMI Out PCI-E Graphics.. | Ebuyer.com. I ordered it to try and get displays working. One HDMI, The second DVI and the third VGA. Im having trouble getting the third monitor working.
The reason I purchased this card was that it stated it supported ATI Eyefinity. However, im confused and don't know what to try now. What do you guys reckon, or should I send it back and get a card with display port so I can add the VGA by a diplay port vga converter. Im confused.
Any help will be muchly appreciated.
pickettwayne
PostPosted: 11:54 - 04 Feb 2011    Post subject: Reply with quote
Heres the link. https://www.ebuyer.com/product/191533
Frost
PostPosted: 13:46 - 04 Feb 2011    Post subject: Reply with quote
the Eyefinity cards usually just have 3/6 HDMI ports on them. The fact that yours has a port of each type probably means that it's a choice of output methods, rather than being designed to use all 3 through the use of various adapters. That is, it has 3 output ports, but can only display 2 at once max. This is backed up by the maximum resolution of: 2560 x 1600, which would have to be split over the 3 monitors.
The specs of that card show it's crossfire ready which no doubt means you'd need 2 of those cards to support eyefinity. There's a review comment saying:
Ordered a couple of these to replace two mismatched cards in my system to drive three monitors.
Neorion
PostPosted: 14:52 - 04 Feb 2011    Post subject: Reply with quote
Is the 3rd monitor not seen in the ATI control panel?
VFR FI 2000- Shiney Red Thing
"some things man was never meant to know, for everything else there's Google"
el_oso
PostPosted: 23:28 - 04 Feb 2011    Post subject: Reply with quote
try plugging out the dvi port monitor first. see if the third monitor works. are you using the up to date drivers? they were only released a week ago
Duke 390
Car: Jeep Wrangler 4.0L
Bendy
Mrs Sensible
PostPosted: 23:42 - 04 Feb 2011    Post subject: Reply with quote
I'm running a 5450 and there was some weird combo of which outputs you could use and which you couldn't. I think it was that if you wanted 3 monitors, one had to be displayport. It was a while ago so I'm a bit fuzzy, but I definitely bought a displayport monitor for some reason around then!
I ended up with 1 x displayport, 1 x hdmi and (I think) 1 x vga (I'll double check the vga tomorrow, there might be an adaptor involved - the dp and hdmi I'm sure of).
PostPosted: 01:55 - 05 Feb 2011    Post subject: Reply with quote
Dual screen with different screens Sick
Bendy
Mrs Sensible
PostPosted: 10:31 - 05 Feb 2011    Post subject: Reply with quote
Better than chucking the screens away when you buy a bigger one Smile
The last post was made 15 years, 220 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.39 - MySQL Queries: 13 - Page Size: 56.13 Kb
