| steven_191 |
 steven_191 Nearly there...
| Frost |
 Frost World Chat Champion
| G |
 G The Voice of Reason
| steven_191 |
| steven_191 |
| G |
| steven_191 |
| chris-red |
 Posted: 22:19 - 06 Feb 2011 Post subject: |
Husaberg AKA Husabang
My mate had a supermoto one, it needed an oil change every 1.5 hours IIRC. He said his was about 70bhp from a 650. ____________________ Well, you know what they say. If you want to save the world, you have to push a few old ladies down the stairs.
WANTED:- Fujinon (Fuji) M42 (Screw on) lenses, let me know if you have anything. |
| G |
| hmmmnz |
 hmmmnz Super Spammer
 Posted: 22:28 - 06 Feb 2011 Post subject: |
ktm is only really taken a foot hold in the uk in the last 5 years,
but here in nz they have been the best selling bike (offroad) for the last 10 years atleast,
there are loads of tuning options,
mostly involving cam changes, carb upgrades, and porting
there is bigbore kits available but you'' only get a few extra cc so basically no one ever uses them,
if you keep up with maintainance they last a fair while, and rebuilds are nice and easy  ____________________ the humans are dead
I kick arse for the lord
Wiring Diagrams BIDNIP it bitches |
| Tristan. |
 Tristan. World Chat Champion
| G |
| steven_191 |
 Posted: 23:23 - 06 Feb 2011 Post subject: |
i would like to lose weight off the bike but really that would cost more than it would be worth to do.
i would aim for better flow and more efficient combustion and utilising the cam and displacement to its potential. not too sure about the carb because from my own research changing the carb isnt always that worthwhile. just the 'right' choice.
and the way i normally view these things is, if KTM thought the carb was shit, why would they put in into a mass produced bike? and this bike sells fairly well and i havent read about the carbs not doing their job right.
it'll be more a case of getting a decent mixture in the the combustion chamber and getting it ready for combustion. considering its only got about 9 inches or so of travel from the carb to the valves, thats why i say the 'right' choice of carb.
ive still got to buy an engine yet though  |
| stevo as b4 |
| binge |
 binge Emo Kiddy
| steven_191 |
| G |
| steven_191 |
| G |
| tahrey |
 tahrey World Chat Champion
 Posted: 00:42 - 08 Feb 2011 Post subject: |
| G wrote: | | Quote: | so would the aim for more torque be better than more horse power be sensible? |
Power=Torque*5252 - so one will reflect the other.
Ah man this old argument... all that really matters at the end of the day is Newtons force where the rear wheel meets the tarmac. Which is a function of your torque vs the gearing (primary reduction, main reduction, chain reduction, and wheel size). Power is the ability for the engine to keep supplying said force as the speed goes up, instead of it all being leeched away just to keep the crank turning at the same pace.
More torque is good, but more torque over a wider rev range, and more power overall, is better. I much prefer my petrol car's 4000rpm-wide spread of 148Nm on frantic gears than a previous turbodiesel hire's 200-and-something (maybe even 300) over about 1500rpm effective with tall, wide gears. (Well, everywhere except cruising at 80 on the motorway)
Just as it's better for everyday stuff but not for ultimate speed vs some very peaky racer which does the same thing, but up near the red line rather than a small but significant distance above idle.
BTW, the actual formula is
Power (in DIN HP) = Torque (in lb*ft) x RPM / 5252
So at 5252rpm, if your engine is turning with a force of 45 lbft (at the centre of the crank) it's also generating 45 HP into the bargain.
Diesels produce more but it's all at low revs, so to do any kind of actual speed you have to gear up, and at the wheels you actually get LESS force, because there's less power. Strange but true. The butt-dyno says otherwise, but the graphs spit out of excel when you run the numbers concur with this and also match the 0-60 times and top speeds.
For a bike, what you want is a good deal of torque everywhere you can get it, but a fair old wedge at the top end to give you screaming power as well (Well OK you want that for a car as well, but the driving styles tend to be a bit different, as does the power:weight vs drag, and the gearing)
(Which is why I like the CGs power curve, except for the complete loss of all oomph on wide throttle at the very bottom which is probably indicative of a carb fault... it'll slog like a diesel truck, slowly uphill in high gear, but it holds that torque enough to high revs to still have a -bit- of power-led pep when you drop a couple of gears; though it follows the description to a T and hates being taken near the limiter)
When in doubt, prioritise the torque. You're unlikely to get in a scrape because you only had 50hp @ 10krpm rather than 60 @ 11krpm, but if it goes off the boil at the bottom end then it's a scramble for the right gear and trying not to stall; or at least, in extremis, an embarrassing moment where you're rapidly losing speed when everyone else isn't because you've reached a flat spot in the engine where the torque's dropped enough to no longer whiz you up the hill but you're still going too quick to change down (more likely to be felt as a lull after changing up, like turbo lag). |
| G |
 Posted: 12:27 - 08 Feb 2011 Post subject: |
Yes, this old argument it would seem . If you read my later post, you will note I DID post the correct formula.
So, what you're saying, is that you want torque spread across a wide range of rpm, going to a high rpm.
So, what shall we call this concept, hmmm, maybe 'quarop'? Hmmm, doesn't sound right, how about, err, 'power'. Yes that sounds quite good!
Having torque figures alone tells you nothing. I could present you with a bike engine that has 1000NM of torque spread across 4/5th it's rev range. But the output shaft is spinning at .1-1rpm. Throw in some sensible gearing and suddenly you've got very little force at the rear wheel.
So we can see that 'torque across the rev range' actually means very little.
To be useful, it needs to be qualified with rpm too. When you include RPM, you are then describing power, not torque.
With RPM/Power you can get a good of the gearing you CAN run. This gives you an idea of the likely force at the rear wheel.
| Quote: |
When in doubt, prioritise the torque. |
What you then go on to describe is 'range of torque', or, more importantly, 'range of power'.
Of course it does also miss the point that not everyone wants this. My GSXR has got a very good range of torque/range of power (far better than the majority of other genres, including cruisers, etc), yet is less exciting for it, for me.
Your example of not being able to accelerate in gear is an excellent example of the fallacy of saying 'prioritise torque' to my mind. Take a NSR125. Open it up in sixth and you probably won't get to the power band. Yet if you look at the torque 'figure' for the NSR, it's quite high. What you should be considering for this case is the range of power (or range of torque across high rpm) - or just using the gears, which is why you've got them .  |
The last post was made 15 years, 63 days ago. Instead of replying here, would creating a new thread be more useful? |
