KAWA ZX7R questions
crowe
PostPosted: 18:12 - 07 Feb 2011    Post subject: KAWA ZX7R questions Reply with quote
I've completed my 2-year restriction on my ER-5 and have found a nice 2001 Kawasaki Zx7R for sale. 19K miles. £1,800 (ono) ....ONLY problem is it's very high for me (tip of big toes on floor!!). It's in my budget and in very good condition. I'm a short arse and as the bike is a heavier than most my questions are:
1-what is the best way to lower it a few inches of so? I've read about shortened suspension links, is this a good option.
2-how much may this cost including labour costs (approx) ?
3-Does it seem like a good price for the bike?
for the condition and price i feel that if i could get this bike lowered then it would be a very good step-up from my ER-5 (plus i could always get it 'raised' again if i felt comfortable with its size in the future).
Thanks in advance
PS- please don't suggest "you'll just get used to the height" as i've had my ER-5 for 2 years and i know what i can/can't manage.
Smile
Kawasaki ER-5
Frost
PostPosted: 18:51 - 07 Feb 2011    Post subject: Reply with quote
Often it's not the seat height thats the real problem, but the seat width. The more your thighs go sideways, the less they can reach downwards.
The easiest way to adjust the height would be to remove any preload the current owner has put on the rear chock to try to jack the back end up and make it turn quicker. Once thats done, if it's still to heigh you'll have to think about modified linkages or a shorter spring. Fitting them yourself could be done in half an hour or so. I'd expect a mechanic to charge you an hours labour plus discover pitting on the damper rod, or a leaking seal and either fit a new shock or try to sell you one.
bacon
PostPosted: 19:31 - 07 Feb 2011    Post subject: Re: KAWA ZX7R questions Reply with quote
Thanks in advance
Smile
Like you I'm a short ass, 5ft 6, but with an inside leg about 29 inches or so. I also have a zx7r. Also like you I have both feet down with tip toes, to flat foot I can only manage 1 foot.
1. The zx7r has a built in height adjuster, its quite possible that the 7r you are looking at has had its rear end jacked up so it would be worth checking.
Its a common thing to do to raise the rear ride height adjuster by 25mm to increase steering response, i haven't done this however.
2. If your desperate to lower it, which id suggest against, a set of dog bones is about £15, and all you would need to do this yourself is an abba stand or something similar to get the rear off the ground (axle stands under foot pegs perhaps).
3. price wise seems fine, 19k isn't many miles and the engines if well maintained are pretty bomb proof.
I know you said you don't think you can handle the height of it as it is, but its just about building your confidence with it.
If you do get it, rest assured its one of the best looking kwaks you can buy Wink
oh yeah, and get yourself over to www.redmonkey.com/7r
c-m
PostPosted: 19:57 - 07 Feb 2011    Post subject: Re: KAWA ZX7R questions Reply with quote
The 750 and 7r has quite a stretched riding position. If you are short, make sure you can comfortably reach the bars.
It sounds stupid, but when i had mine my girlfriend could barely reach the bars enough to turn them.
bacon
PostPosted: 20:01 - 07 Feb 2011    Post subject: Re: KAWA ZX7R questions Reply with quote
+1, the clip ons are also rather low which adds to the stretched effect, below the top yoke in fact.
When I took tuttons zx6r A1P for a quick ride up the road I felt like I was on a touring bike as the bars were so close and high in comparison Laughing
crowe
PostPosted: 20:36 - 07 Feb 2011    Post subject: Reply with quote
Bacon, I'm pretty much those exact dimensions (height/leg) Thumbs Up
I'm not sure exactly what the current suspension settings are (i'm guessing default). Do you ride your zx7r with it on default (ie how i think this bike is when im on tip-toes) or do you ride it on a lower setting?
I'm most likely going to pay a mechanic to put shorter links/bones in (i can always change them back).
I think my immediate concern is getting it home plus also 'getting used' to the bike. I really want to be as comfortable on the bike as possible as it's the first sports bike i've owned.
Kawasaki ER-5
Jenks
PostPosted: 21:14 - 07 Feb 2011    Post subject: Reply with quote
Either way, i would try to get the price down - as a guide, i paid £1200 for a 98 2 years ago.. - it was very good condition - only a cracked screen, which was easily sorted.. and the same sort of milage.
1978 MZ TS 250 1 Supa 5
1992 yamaha fzr1000 exup
1998 aprilia af1 sintesi
bacon
PostPosted: 02:25 - 08 Feb 2011    Post subject: Reply with quote
Yes I ride my bike setup as default, i.e the rear ride height at the lowest at the moment. I have dropped the yokes through the forks 10mm though which is an extremely common adjustment to make to increase the steering response
Basically zx7r's are setup a bit lardy as standard compared to the older zxr750's and there are a few simple things that people do to remedy this and sharpen up the bikes steering. One of which is increasing rear ride height, hence me suggesting not lowering lower than stock if possible. But again thats up to you.
Yeah I can see your concern, its significantly heavier than your previous bike and also a very different riding position. But the only way your going to adapt is by riding it.
Slow manouvering is going to be where you will likely notice the most difference. My first ride on the zx7r was picking it up 270miles away up north in Doncaster. Just take your time when setting off, plan ahead, don't rush it etc and I cant see an issue mate Thumbs Up
Drongo
PostPosted: 02:42 - 08 Feb 2011    Post subject: Reply with quote
ZX7 is a sports bike Crowe.
Best advice I can give is try it first for size and comfort.
They aint very comfy lol/
The last post was made 15 years, 283 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.07 Sec - Server Load: 0.96 - MySQL Queries: 13 - Page Size: 65.05 Kb
