Your thoughts on a fairly common illegal manouvre?
Which Option
Option A
41%
 41%  [ 20 ]
Option B
37%
 37%  [ 18 ]
Option C
20%
 20%  [ 10 ]
Total Votes : 48
Mr Hammers
PostPosted: 23:24 - 07 Feb 2011    Post subject: Your thoughts on a fairly common illegal manouvre? Reply with quote
Hypothetical situation: Following slowish traffic around 30-50mph on a dual carrigeway and the car in the overtaking lane is taking forever to overtake the other, and you're fed up of waiting for him.
https://www.planetash.net/bcf/ott.jpg
Is A, B or C safest?
Before it's pointed out that all three are illegal, and the safest thing to do is be patient and follow, I just want to make clear that is *not* the point of the question.
The point is, if you are going to do it, which is the most relatively safe option?
A Guide To Powerbands
Shaft
PostPosted: 23:32 - 07 Feb 2011    Post subject: Reply with quote
Personally, I don't like the look of B and I very rarely pass on the left, so it would be A for me.
In situation B, it would only take one of them to deviate and you're being squeezed, in C the guy who's just overtaken could do the proper thing and pull back in, he won't be expecting you to be there.
Of course, in any of those situations you would probably be giving it the biggun, so it's likely you'll be clear and gone before anyone else noticed what was going on.
instigator
PostPosted: 23:33 - 07 Feb 2011    Post subject: Reply with quote
Naturally it's going to be A.
When I had a bike with decent power, I would filter up to 90mph usually, doing A, B or C. Unfortunately now I don't have the power to get me out of trouble. Sad
bootsbiker
PostPosted: 23:35 - 07 Feb 2011    Post subject: Reply with quote
It would depend on many things.. eg wind and speed(acceleration ) of my bike..
Prob go for C
but I would overtake the blue car on the right hand side if I had that option.....
edit done
https://justfuckinggoogleit.com/
c_dug
PostPosted: 23:36 - 07 Feb 2011    Post subject: Reply with quote
For me it goes B, A, C.
bikertomm
PostPosted: 23:37 - 07 Feb 2011    Post subject: Reply with quote
For me C is the winner, car on the right will be out the way so you will have to be quick and hope that they aren't going to come straight back into the left lane.
Being patient then waiting for him to move over would be the better & safer option though Razz
Digitalize
Combination of B and C, Do the C manouvure when the cars are positioned in B
1998 CB600F Hornet
c_dug
PostPosted: 23:39 - 07 Feb 2011    Post subject: Reply with quote
C is a terrible choice because of the likely hood of them moving back to the left.
B, neither car is likely to swerve so close to each other to squish a bike, besides you would be through the gap in seconds.
A, Short of deciding to to overtake and pulling back in behind, I would say is the safest.
Still I usually do B over A for some reason.
Noxious89123
PostPosted: 23:41 - 07 Feb 2011    Post subject: Reply with quote
Would be either A or just wait until the blue car has made his move and overtake him properly.
B, neither car will see you / be looking for you there.
C, you're likely to get plowed off the road by the blue car.
Atleast with A, the green car is expecting to be overtaken, and the blue car will see you infront as you move infront of them. So long as your giving it some welly, they (the blue car) shouldn't get anywhere near the back of your bike.
Those that said B or C, what is your thinking for that being the safest move?
EDIT:
Could also say this is the result of rather poor planning; You should be in the right hand lane and passing the green car before the blue car catches up to you.
Ichy
PostPosted: 23:44 - 07 Feb 2011    Post subject: Reply with quote
All have their own risk.
A and C give an option, although limited, to swerve.
In A The blue car could easily not see you and decide to accelerate.
B doesn't really allow the drivers to react, assuming you go fast enough.
C assumes that the green car is going slower and therefore presents less of a risk although the blue car could see you approaching and move into lane 1.
bootsbiker
The green car is moving the slowest...
Vman
PostPosted: 23:45 - 07 Feb 2011    Post subject: Reply with quote
If it's taking ole blue forever to overtake, then you would be hanging around 'forever' for blue to get to B and C, so I would have got away from the situation in A.
TS50X, RM125, DT125, TS125, KH125.....CBF125. It all started with a Puch Magnum from Macro!
Noxious89123
PostPosted: 23:48 - 07 Feb 2011    Post subject: Reply with quote
Agreed 100%
True, but if your on anything with decent poke, I still wouldn't expect them to be accelerating faster than yourself on your bike. If your on a low powered bike, or it's a flash car, I wouldn't attempt the move for that exact reason.
Care to elaborate? Unless your dawdling as much as the fella in the blue car, I can't see any issue?
Shaft
PostPosted: 23:53 - 07 Feb 2011    Post subject: Reply with quote
Of course, for the real suicidal maniacs, there's also options D and E, which are passing the green car on the left and the blue car on the right............... Laughing
Ichy
PostPosted: 23:54 - 07 Feb 2011    Post subject: Reply with quote
To be honest I've done all of them. In real life its easier to read the situation and make a judgement. Drop a gear and open it up, aim to be still on the bike when you get to the clear road ahead.
Frost
PostPosted: 23:57 - 07 Feb 2011    Post subject: Reply with quote
I've only done A on a bike with decent power. I've done B but only in near stationary traffic, never done C.
Mr Hammers
PostPosted: 23:58 - 07 Feb 2011    Post subject: Reply with quote
Evil or Very Mad Hand Hey! You can just stop that sort of thinking right now!
MinhDinh
PostPosted: 00:01 - 08 Feb 2011    Post subject: Reply with quote
I do all of then depending on the situation. I would say A is the most dangerous since the car on the right is usually going faster and will turn in.
B is the one I like the most after a few secs to look at the gap.
C is easier to do, and I like it the most.
All on private roads though.
Hit the G spot. Wink
bootsbiker
PostPosted: 00:04 - 08 Feb 2011    Post subject: Reply with quote
the blue car is still accelerating.. so if u do A it can turn into situation B you have little space.. He could be in the wrong gear and wake up.
The prob with C is that he might know you are behind him and pull in to the slower lane and run you of the road....
At the end of the day how long have you been behind them... R they driving in a straight line or R they all over the lanes..
TBH... I don't know... I would try and avoid the problem.
edit
f@#king c#$%t shouldn't be in my way anyway in the 1st place...
J/k
not
Vman
PostPosted: 00:12 - 08 Feb 2011    Post subject: Reply with quote
At what point in A will he turn in - I would conclude by the diagram that you're already 'out of there' before blue has an overlap on green? And it has been stated he is taking forever to overtake.
MinhDinh
PostPosted: 00:15 - 08 Feb 2011    Post subject: Reply with quote
If that is the case then all are safe if constant to each other.
Alex A
Those are illegal? Really, they're just an overtaking manouver of the car on the left. The one on the right is almost irrelevant. Just the same as with filtering (in fact, it is filtering certainly B). Only think you could be charged for is dangerous driving/driving without due care and attention. So, do it in a clear, smooth, controlled, well executed manner, and you should be fine, legally speaking.
I'd choose B every time. That is to say, I would aim to be between the vehicles when they're either closely approaching or already in the B position (when they're overlapped). Why? Because it doesn't matter whether the drivers see you. I'd be through in 1-2 seconds max, and whilst the cars are next to one another, you know neither is going to change lane as they'd collide with one another.
A is next safest. It's unlikely, but there is still potential for either car to change lane. And if they don't see you, and do it at the wrong time, you could be fooked.
C I would avoid. Either car is in a position where they would potentially want to change lanes, especially the overtaking car. And if they don't see you, you could likely be fooked.
Still, the quicker you do it, the safer it is. The sooner you're through, the smaller the narrower of opportunity for you to be mullered.
Hetzer
PostPosted: 00:25 - 08 Feb 2011    Post subject: Reply with quote
A or B, no way C.
Dave McCool
PostPosted: 00:47 - 08 Feb 2011    Post subject: Reply with quote
B is the clear winner for me, as neither car will be likely to attempt to change lanes at this point, so hard on the power and squeeze through before either of them even realise what happened.
A is also a possibility, although thinking about it I probably wouldn't go for that until the overtaking car was beyond the point of no return, so it's basically an early B.
C looks like a poor move overall; there's a good chance that the overtaking car will have noticed you there and will be considerate enough to pull over to the inside lane to allow you through as soon as they complete the overtake, especially as they may feel, having waited that long, that you're too cautious to be splitting lanes at that speed.
As an aside I would say that, for me at least, your proposed angle of approach is wrong, by positioning yourself in the middle of the road on the white line you'll get a better view of the gap and how constant it is, you'll be in neither car's blind spot so with even a quick glance in their wing mirror they'll hopefully spot your headlight, and with being positioned there they stand a much better chance of being able to second guess your actions and possibly even leave you a little extra room.
Coming from the middle and driving straight through would also give you the advantage of being able to react more effectively if one of the cars does something stupid; instead of being committed to a line that crosses both of their paths and could potentially cause you problems if one of them does choose to brake or accelerate quickly (this does happen) you can power straight through the middle, only having to concern yourself with ensuring the gap remains consistently wide enough for you and your bike. If you aim to go straight until your back wheel is past the front bumper of the car in the lane you want to be in (ideally this would be wichever one you got past first) then pull into that lane, not mad hard like an emergeny avoidance, but fairly quickly to get you out of harms way.
Please note, all of the above is advice based on experience both of riding around busy areas, and watching bikes filter around London whilst I'm stuck in the van, none of this has been verified as good advice by any sort of authority on the subject, but it has worked for me so far.
In all honesty I'd have to say that if the gap isn't wide enough to do this, then don't pull any of these manoeveurs.
McGee - "When I go to the mall and see all the high school girls, I have to have DO NOT TOUCH THE GIRLS written on my hand. Every time I go to grope I see it and stop."
K7 GSXR750
The last post was made 15 years, 283 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.10 Sec - Server Load: 0.24 - MySQL Queries: 15 - Page Size: 139.02 Kb
