Removing exhaust full system header. Need gasket?
MarkJ
PostPosted: 14:22 - 08 Feb 2011    Post subject: Removing exhaust full system header. Need gasket? Reply with quote
I've posted this on RSVzone but hopefully someone on here may be able to help me.
I need to remove the swingarm on one of the RSVs (bearing on the bottom of the swingarm has seized, but I have another swingarm with good bearing), and normally you need to remove the rear header pipe to do this as it goes around the swingarm pivot, however I have a Leo Vince full system, which has the usual 3 bolts to hold it onto the head, but the downpipe itself seems to be held against the plate with an exhaust spring.
Standard header:
https://thumbs2.ebaystatic.com/m/mWixxrdfl2kPyVsjzbic4hQ/140.jpg
The Full system is like this, but instead of the header being welded to the plate at the end with the three bolt holes, it's just held against it with a spring.
If I remove the spring to get the downpipe off (leaving the plate on the head) will I need to buy another exhaust gasket, or is the gasket behind the plate and the downpipe just sits metal-to-metal against the plate, like it does further down the full system at the collector area?
Cheers Thumbs Up I can't find any information from Leo Vince, and I haven't seen any RSV's with the full system either.
MarkJ
PostPosted: 15:09 - 08 Feb 2011    Post subject: Reply with quote
Oh aye, I knew there was a better word than plate. I'll try and get a pic tonight. It's a right bugger to get to as it's under the fuel tank & pump, infront of a frame brace, and above the bloody swingarm and rear shock!
DrDonnyBrago
PostPosted: 15:45 - 08 Feb 2011    Post subject: Reply with quote
Plate = what your 'flange' should be holding when she exits the kitchen Thumbs Up .
Sorry mate, no idea...
The last post was made 15 years, 63 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.39 - MySQL Queries: 13 - Page Size: 45.33 Kb
