| Hario |
 Hario Derestricted Danger
 Posted: 17:32 - 27 Jan 2011 Post subject: No spark :( |
I was on my way from london to bristol a couple days ago on my 400 superdream when, as i decelerated into a services, my engine cut out
Despite several hours of tinkering i couldnt get her started again because i was getting no spark on either plug, and ended up getting taken back to london in a van.
The RAC guy who looked me over at the scene was of the opinion it was probably my ignition coil, he used a spark tester and it showed a very weak spark on each cylinder (i can see no spark with a plug held against the engine). I had never trusted the cheap coil on there so i was inclined to agree and ordered a replacement, however it arrived this morning and hasn't solved my problem, nor has pouring over every connection and wire between the alternator and ign coil, i also took apart and cleaned the kill switch just in case, but no joy.
Nothing looks obviously wrong with the alternator, and my multimeter registers a good jumping voltage when i bridge the two wires from the CDI to the coil and run the starter motor. Also when i first broke down my battery seemed fully charged and all my lights and starter motor were working fine and continued to do so for some time as i tried get her started again, so i presume the alternator was charging the battery well. The battery is also quite new, about 2 months old.
So now im at a bit off a loss about how to get her running, i would presume that given that it cant be the ign coil, either the alternator or CDI are at fault, or failing that that its a wiring/earth issue. But as far as i can tell all of these things are fine, can anyone think of some testing i can do to try and figure out where the problem is?
If i could afford to i would just replace the CDI and alternator to be sure that all is well, but im out of work at the moment and really cant afford any costs that can be avoided.
Please help!  |
| Paxovasa |
 Paxovasa World Chat Champion
| whitedevil |
 whitedevil World Chat Champion
| Hario |
 Posted: 19:19 - 27 Jan 2011 Post subject: |
the new coil came with new HT leads, and ive been testing with a working plug (one i removed at the bikes last service for no reason other than to be thorough). The boots look fine, and the problem is on both cylinders, so presumably if one were a bit dodgy the other would still work.
I think the coil is earthed ok, it completes a 12v circuit if i put the multimeter between the coil mounting posts and the positive battery terminal.
Im pretty new to debugging electrical problems so im not that experienced with a multimeter, is that the right way to check an earth?
A google search led me to a list of expected resistances for every alternator wire on this model, so i guess my next step will be to check those. Apperently the CDI's on this bike are pretty invincible so im leaning toward a problem at generator/pickup/alternator coil area now. Am i likley to need something like a slide hammer to get the alternator off or will a socket set suffice?
Either way it will need to wait until next week now, im going to make another attempt at reaching bristol tommorow, this time on my old 125, so if your on the M4 tommorow and see someone hanging for dear life onto a lorry radiator that will be me  |
| stinkwheel |
 Posted: 20:40 - 27 Jan 2011 Post subject: |
If it's a twin coil, one bad HT lead, plug cap or plug can make both go bad.
You can test the resistance between the two plug caps which will give you an idea if there is a problem in that area. They have an internal resistor and you can't tell by looking if it's gone bad. Don't know the expected reading though.
I presume you've replaced the plugs?
You can also check the resistance of the pickup coil.
If they're the same as a 125 superdream, there is a seperate coil in the alternator just for the ignition. The battery charging does not mean this is working properly. Again, you should be able to test this.
I had a weak spark on an old kawasaki once. I thought it was all earthing properly but out of frustration, I ran a big, thick wire from the coil earth to the battery negative and it suddenly clattered into life. Maybe worth a try to definatively rule this out.
Also consider the ignition and kill switch wiring. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Hario |
 Posted: 18:56 - 08 Feb 2011 Post subject: |
So i survived my ordeal on the motorway and now im puzzling over this problem again.
So far i have new spark plugs, ignition coil and HT leads. Ive also had a look at my generator setup which looks pretty crappy and old but returns the correct(ish) resistances, although the glue over the coiling of the stator is pretty chipped and there is a bit of rust on the magnets. I disconnected the wiring to the kill switch etc too.
This only really leaves the CDI and possibly the plug boots, i hear that CDI units can only be tested by putting an alternate one and seeing if it fixes the problem :/
As far as the boots are concerned i tested them for resistance and they gave back slightly different values 10.something verses 12.something is this possibly the problem? i cant find any guide values to test against anywhere.
Can anyone think of something im missing before i fork out any more dosh on this?
on a slight side note, i picked up a whole NOS generator setup, including the pickup and flywheel etc. on ebay thinking to replace my dodgy looking one but now it's here it turns out it slightly different to my one. Apparently its from a 400t but they had it up as a 400t/n setup so i figured they were the same.
my old one looks like this: https://www.cmsnl.com/products/acgen-flywheel_31100443005/
the replacement like this: https://images.dk-parts.co.uk/Item12096-2.jpg and https://images.dk-parts.co.uk/Item12096-3.jpg
the wiring etc. look the same and im sure it will fit, but is it likley to work do you think? its going to be next to impossible to find another NOS superdream generator if it doesnt :/
I really appreciate your help, im feeling serious motorbike withdrawal setting in at this point  |
| cb1rocket |
 cb1rocket World Chat Champion
| Hario |
| Gazdaman |
 Gazdaman I did a trackday!!!
| Hario |
| stinkwheel |
 Posted: 23:50 - 08 Feb 2011 Post subject: |
10 and 12 kiloohms seems on the high side for a plug cap.
They are usually 3, 5 or 8K. If it's an NGK one, it'll usually have the resistor value stamped into the plastic moulding somewhere.
Pretty sure a superdream should have a 5K plug caps so yours are reading double what they should be. Not that this is definately the problem but it warrants a closer look. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Hario |
 Posted: 13:13 - 09 Feb 2011 Post subject: |
well i have new plug boots coming so i can hopefully eliminate those in the next few days, i also found an old but working CDI on ebay so i can try that when it arrives too.
Which just leaves me with my alternator dillema, not sure if i should send this one back or try it out
I dont really know enough about them to make a decision on wheter slightly different models will be interchangable or not, my old one could just be an updated but essentially same device. |
| Hario |
 Posted: 16:55 - 17 Feb 2011 Post subject: |
Just for some closure i finally got her running!
Turns out it was the alternator, although im not sure which part as all the resistances checked out, oh well.
Also it was the older model alternator that got her started in the end, i guess they didnt change the timing or output, having said that since she started she is running a tad hot, and is a bit more clattery than usual so im concerned the timing may be off, but it will take more looking into to be sure (i dont have a timing light).
Thanks very much to everyone who contributed in this thread, you have been very helpful!  |
The last post was made 14 years, 355 days ago. Instead of replying here, would creating a new thread be more useful? |
