The motorcycle dosn't run
John karner This post is not being displayed because the poster is banned. Unhide this post / all posts.
Teflon-Mike
tl;dr
PostPosted: 17:37 - 11 Feb 2011    Post subject: Re: The motorcycle dosn't run Reply with quote
John karner wrote:
the battery burns out if you charge it too long. The guy that fixes mine says they should not charge for more than 4 hours max. Is it better advice….?
Depends on the battery, depends on the charger.
A low amp 'trickle' charger will be putting something like 1/4 Amp into the battery.
If you have a 16Ahr battery, that means it will deliver 16 Amps for one hour, and what comes out, has to have gone in, so to get 16Ah's worth of electric in it at 1/4a you would have to charge it for about three days... and as batteries 'loose' charge with time, maybe even longer.
Charge it with a 2A motorcycle battery charger, 16Ah battery, from flat would take about 8 hours.
With a 4A car battery charger, about four hours.
With a 16A 'boost' charger, about an hour....
16Ah is very big for a bike battery, sort of thing you'd get on a big capacity tourer. 12 or 14Ah would be more normal, and charge times would reduce accordingly.
On a lightweight, may only have a 6 or 8 Ah battery, and charging one of those up on even a regular charger could be like slapping a big bike battery on a boost charge.
Over-charging a battery can boil the acid out of them, or if they get too hot too fast distort the plates, so YES it is adviseable to use the lowest charge rate possible, AND to avoid over-charging by leaving them for prolonged periods on charge, but how much and how long is all dependent on the ratings of battery and charger.
Optimate chargers and battery conditioners are another matter, they (should) measure the voltage accross terminals and only deliver charge when the battery is low, and switch off when its fully charged, though many simply deliver a very small constant trickel current.
doggone
PostPosted: 17:56 - 11 Feb 2011    Post subject: Re: The motorcycle dosn't run Reply with quote
Except it wouldn't be entirely 'empty' when you started, even if it doesn't have enough charge to turn the engine.
A lot of batteries suggest a max charge rate in small print on the side.
For a typical mtorcycle battery it's usually less than 1amp.
A quick boost at higher rate to start it probably won't do any harm.
In any case when the engine and alternator are running it will have far more than going into it.
Batteries are damaged by being allowed to discharge and it's a vicious circle of decline if you are needing to charge it frequently.
doesn't apply to the optimate type as the whole idea of those is to avoid the damaging discharge/charge cycle.
The last post was made 15 years, 61 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.25 Sec - Server Load: 0.25 - MySQL Queries: 13 - Page Size: 44.01 Kb
