| rmurphy16 |
 rmurphy16 Derestricted Danger
| rmurphy16 |
| Raffles |
 Raffles World Chat Champion
 Posted: 15:43 - 11 Feb 2011 Post subject: |
I wouldn't expect it to work well for cleaning things. A can of brake cleaner would probably be more effective (although I would take care with using it on plastic and rubber components).
If there is just dirt in there then anything will flush it away (including WD40). However if you have dried fuel inside the jets I would doubt that the easy start would stay liquid long enough to have any significant effect dissolving on it.
| Teflon-Mike |
 Posted: 15:49 - 11 Feb 2011 Post subject: |
If your carbs need 'cleaning' as in jets unblocking, then squirting stuff in the choke really isn't going to do much.
Dont know what carb it is, but its no mamoth and complicated task to take the carb off, and wip the float-bowl off, remove petrol residues with deturgent and an old tooth-brush, blow throuh the jets and re-assemble, if needs with a new float-bowl gasket cut from a cornflake packet (DO NOT use squeezee gasket unless you like petrol leaks and more clogged jets and valves!) ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| rmurphy16 |
| rmurphy16 |
The last post was made 15 years, 60 days ago. Instead of replying here, would creating a new thread be more useful? |
