Car - juddering feeling like an unbalanced tyre - FIXED!
DrDonnyBrago
PostPosted: 14:38 - 11 Feb 2011    Post subject: Car - juddering feeling like an unbalanced tyre - FIXED! Reply with quote
Hi, my car has developed a 'juddering' feeling over 60mph. is fine whilst braking etc but over 60mph you can feel a bumping through the car. Happens about 2 or 3 times a second at 60mph.
Other than unbalanced tyres, what else could be causing it?
MaybeGuy
PostPosted: 14:41 - 11 Feb 2011    Post subject: Reply with quote
drive shaft/wheel bearing?
PostPosted: 14:46 - 11 Feb 2011    Post subject: Reply with quote
Tyre would be my main guess but a buckled wheel would also cause it. And a worn shock will probably make this vibration far worse from just a lightly out of balance wheel.
Would agree with Matt about a drive shaft or wheel bearing being possible, but I would suspect you would hear other symptoms first before the vibration became an issue.
DrDonnyBrago
PostPosted: 15:02 - 11 Feb 2011    Post subject: Reply with quote
Thanks; I have hit a few rather deep pot holes over the winter months so anything is a possibility.
I am hoping I have just lost a wheel weight but will have a proper look at the weekend so need to know what else to look out for.
What sort of symptoms would a duff drive shaft or wheel bearing make? How would I check, spin the wheel and feel/hear for grinding?
PostPosted: 15:07 - 11 Feb 2011    Post subject: Reply with quote
Wheel bearings normally rumble when really bad, but whine when starting to go. You will probably be able to feel play in them.
If you have hot pot holes then a fair chance a wheel is buckled. Check the inside edge (we wrecked a wheel on the 155 on a lump of something on a roundabout, looked OK from the outside by a deep buckle on the inside edge)
DrDonnyBrago
PostPosted: 15:10 - 11 Feb 2011    Post subject: Reply with quote
Cheers Thumbs Up .
tahrey
PostPosted: 15:56 - 11 Feb 2011    Post subject: Reply with quote
Also don't forget the possibility of either something wrong with the tyre (flatspotted somehow?), or a driveshaft balancer having shifted or fell off.
I had the latter once and got through about four garages and an endless parade of wheel rebalancing/swapping around/etc before one of them actually figured it out!
DrDonnyBrago
PostPosted: 19:36 - 25 Feb 2011    Post subject: Reply with quote
Thought I would update for the benefit of future search results:
The problem was a slightly buckled wheel and a tyre that was very damaged. Tyre looked 99% normal with pressure in it, when it was taken off the rim though it it was very badly shaped (dent and twist in the tread), also splits in the rubber with threads exposed could be seen between the tread. I'm lucky it didn't blow I reckon, feckin potholes!
Anyway thanks for the help Thumbs Up .
The last post was made 14 years, 361 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 2.18 - MySQL Queries: 13 - Page Size: 57.55 Kb
