| rikjdee |
 rikjdee L Plate Warrior
| clancy |
 clancy World Chat Champion
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 16:59 - 11 Feb 2011 Post subject: |
Recommend Me a First Bike
Just said in a thread not far away, when choosing a 125 you want a bike that is:-
- Easy to ride
- Easy to live with
- Easy to flog on when you have got your licence 'done' on it.
Demand anything more from it, and you will pay over the odds or sacrifice something in the greater compromise.
Dirt bikes are great fun, but... 125 'trail' bikes tend to be a bit of a pain in the arse. They are a compromised design by nature, neither ful on off-road bikes, nor dedicated dirt bikes, so before you begin you have compromises in them.
Sportsbikes.... in 125 'learner-legal' form, are a joke. They are not quick enough to be 'sporty', having thier performance deliberately restricted to that of any other 125 learner legal. De-Restricted they aren't learner legal, tend to be unreliable, and incredibly high maintenence, so high cost biking, that does not fare favourably to the bang for your buck you'd get with a bigger sportsbike that has an awful lot more performance and reliability for its maintenence demands and running costs.
If you do the regular tests on a 125 you get a restricted licence that lets you ride a 33bhp bike for two years before the restriction lapses and you can have anything you like.
My advice, get a YBR125 or similar, and use it for a couple of months JUST to get your trining and test out the way.
After that, with a 33bhp restricted licence, for the same money as a shit-bag DT125 or a reliable but uninspiring XR125, you can go get something like a DR350, which is a LOT more exiting, a lot more useful, probably more reliable, just as easy to live with, just as cheap to run, and 33bhp complient to run about on until your restriction period lapses.
But, key is getting your licence, and for that just finding a 125 that 'does the job', makes it easy for you, is easy to live with while you have it, and easy to chop in for a bike you really want after.....
YBR is top of the list for bikes that do that really well. 'Good' late model CG125's do it pretty well, for a bit less investment, CBF125 does it for a bit more outlay....
If you really want dirt-wheels, then XR125 is a worthy candidate, but hacking it on the rough will demand more maintenence, risk breaking stuff, and reduce re-sale value, rather defeating the point a bit.... Not using it on the rough, you get a compromised machine, for no real benefits, may as well have a dedicated road-bike, and the easier riding one offers for the short while you need it to get your test.... then you can have propper dirt bike and thrash it about the rough as hard as you like.... you dont have to take a test on it, nor sell it on! ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| rikjdee |
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 17:53 - 11 Feb 2011 Post subject: |
| rikjdee wrote: | thanks for the replys i never really considered the implications of the sporty bikes reliability problems when de-restricted but it makes sense if you've squeezed a bit more power out your gonna have problems, i was leaning towards a DT125 as i had a 50 for a while and that was used and abused every weekend without much problems. I have come across a cheap honda superdream ill have a look at that and if it seems a good deal just use that for getting through the test like you said teflon-mike. |
The Honda 125 Super-Dream, much as I love them...... beware them going cheap, they are horendouse to make work properly if they are sorely neglected... a joy when they work well, but so many are utter sheds!
Look for smoke on start up. Often easy starters, especially if warm, though can only lumber up on one pot to begin with. These motors are killed pretty sorely by oil starvation. They have small oil pump and the filter is in the sump. Hence its out of sight out of mind and rarely gets cleaned. Once clgged oil is starved to the pump, which wears limiting its ability to pump, even more than being starved struggling to suck it through the clogged strainer. Bores wear, allowing oil to be burned, dropping oil level, and eventually the cam-shaft eats through the metal of the cylinder head, due to lack of lubrication, making the motor scrap.
If it sounds a bit rattly, that will as likely be the cam chain tensioner and tappets, being ignored, becouse not easy to get at teh cam-chain tesnioner without removing the carbs, and the rocker cover has to come off to get at the tappets and its a tight squeeze!
Easily sorted though.
Front brake is bludy good, but twin piston job. If rusty or pitted and needing overhaul, its an expensive job.
Rear suspension is often the biggest problem though, they sieze with lack of use, wear with over use, and in either case are prone to 'sag' making the bike lazy, lathargic steering and a tad wobbly. Sorting back ends is a pain and if new bushes and sleeves needed effoff expensive; theres about £150's worth of 'spit' bushes in that linkage!
Front forks and steering easy to sort out though, and most Carburation probs tend to be shit in the bottom of the tank clocgging the fuel tap and float needle valves....
Biggest enemy of these bikes is simply old age and lots of numpty learner owners, but comparitively they tend to suffer less than many other bikes, BUT they aren't the cheap rugged little commuter they look, they WERE designed as a full on four-stroke sportsbike, to go head to head with the RD's and AR's two-strokes in the market place.. hence fact so many still work, and work pretty well, like a CG or whatever is an accolade to thier 'reliability'... but they are still a 125 and a 125 sports-bike and that measure of reliability still has to be rated against other old sportsbikes, and not expected to compare to a three or four year old commuter!
Best of luck, anyway. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| rikjdee |
The last post was made 15 years, 239 days ago. Instead of replying here, would creating a new thread be more useful? |
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.57 - MySQL Queries: 13 - Page Size: 55.31 Kb
