Electric Start Issue
dan3411
PostPosted: 20:41 - 11 Feb 2011    Post subject: Electric Start Issue Reply with quote
Evening guys,
Having a little issue with the electric start on my
Bandit 600 N 1997
The start button seems to be intermittent, I will have to press the electric start button at least 10 times before it will engage and start spinning but it will always eventually start.
Anyone else experienced anything like this before?
Suzuki Bandit 600N
fiery tupp
PostPosted: 21:04 - 11 Feb 2011    Post subject: Reply with quote
Loose connection , bad earth / dirty or damaged starter switch ? Neutral
If you can't fix it with a hammer , use your head .
the grim reaper
PostPosted: 21:12 - 11 Feb 2011    Post subject: Reply with quote
Most likely to be the swich contact themselves, take the starter switch gear apart and clean the contacts. If it's not that, you may have a sticky starter relay. If cleaning doesn't fix it, replace the relay.
Cheers
Grim
The last post was made 15 years, 64 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.72 - MySQL Queries: 13 - Page Size: 35.27 Kb
