How to change a exhaust end can
fbmbmx
PostPosted: 22:51 - 11 Feb 2011    Post subject: How to change a exhaust end can Reply with quote
I have just bought a yoshi end can for the gsxr k3 and was wondering if anyone had i guide or just a quick write up on how to change the end can over?
Thanks
Suzuki gsxr 600-2003
potato
PostPosted: 23:02 - 11 Feb 2011    Post subject: Reply with quote
Undo the bolts.
rac3r
PostPosted: 23:10 - 11 Feb 2011    Post subject: Reply with quote
Depends if it's slip on or bolt on type. If it's bolt on just undo bolts, old off then new on and tighten again!
Chequered Flag
kawakid
PostPosted: 23:24 - 11 Feb 2011    Post subject: Reply with quote
Changed my end can on the ER6 last week, not as easy as most bikes as it's an underslung exhaust. Bit of a pain really. Didn't help the exhaust is a few cm from the rear wheel.
But on most bikes, it's just 2 bolts and a clamp that connects where the down pipes meet.. You don't need a stand or anything.
I've a twin and a 4.
The Tot
PostPosted: 12:14 - 12 Feb 2011    Post subject: Reply with quote
Simple case of undoing the 3 bolts, reuse the gasket (preferably get a new one) between the flange and the end can. Tighten up and make sure:
Arrow There isn't any evidence of blowing in the flange joint - quick tip, mine was doing this because the pipe was warped meaning that it wouldn't line up properly. So, it was a simple case of trying to make it fit as much as possible. I used quicksteel/loaded epoxy to make the seal! Works fine!
Arrow All bolts are done up correctly - here's where the new gasket comes into play since the old one maybe overcompressed. Nevertheless, reusing would probably be fine. Last thing you want is the bolt to the link strap coming loose and leaving your can to rattle away!
Never argue with autism
fbmbmx
PostPosted: 19:40 - 12 Feb 2011    Post subject: Reply with quote
Thanks guys Smile went and had a look over it today and now it looks so easy, I didn't realize there was a flange with the bolt holes connected to the link pipe. I though that it was more or a slip on and do up clamp thing.(don't ask me why). But now it just looks simple
The last post was made 15 years, 247 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.31 - MySQL Queries: 13 - Page Size: 47.79 Kb
