Advice
Aerox_50
PostPosted: 13:57 - 12 Feb 2011    Post subject: Advice Reply with quote
hi there i have an aerox 50 54 plate, i have a gainelli exhuast, i have also put i air filter on to replace the old airbox, but i was wondering what needs to be done cos i have added the air filter, i need a new carb so i was wondering instead of upgrading the jets which i think you have to do, can i just put a 17.5 mm or 19mm carb on instead of the standard 12mm would this eliminate the need of new jets,
Syris D Indomitable
PostPosted: 19:36 - 12 Feb 2011    Post subject: Reply with quote
Sounds like a mind-field this one!
Race Pipes kill off Low Speed power, you will get a little spluttering low end as a result of the pipe upgrade, and the air filter change.
Adjusting mixture on the carb may help this.
Low rpm loss can be compensated with by Lighter weight Rollers.
It has the effect of Lower Gearing which lessens the Demand for power. https://www.scootershack.co.uk/viewtopic.php?f=22&t=15614
Aerox_50
PostPosted: 10:36 - 13 Feb 2011    Post subject: Reply with quote
[quote="rob yarrr"] plug chop - whats this mean thank you
jemdna
PostPosted: 11:30 - 13 Feb 2011    Post subject: Reply with quote
Long and short of it is, run the bike up in the higher rev range for a few mins, hit the kill switch, pull clutch in and pull over. Take the spark plug out and take a look at the color of it.
This will tell you if it is running lean or rich (and this will tell you what you need to do to the carb)
https://www.mudinmyblood.net/forum/images/reading_spark_plugs.jpg
Someone with more knowledge will wonder along soon to help out further Smile
Bry
The last post was made 15 years, 13 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.79 - MySQL Queries: 13 - Page Size: 44 Kb
