| hmmmnz |
 hmmmnz Super Spammer
| Pete. |
 Pete. Super Spammer
 Posted: 12:53 - 13 Feb 2011 Post subject: |
Overheating can cause this. Open it up and check the fans are all turning. Clean out any dust & fluff by brushing with a clean paintbrush, DON'T use a hoover on the boards.
If it's clean and the fans are turning remove all but one of the memory modules. If it still does it swap that module. If it still does it re-fit the memory coz it's not that. ____________________ a.k.a 'Geri'
| Hetzer |
 Hetzer Super Spammer
| Syris D Indomitable |
 Syris D Indomitable Nitrous Nuisance
| chris-red |
 Posted: 19:00 - 13 Feb 2011 Post subject: |
I agree with Hetz and Pete.
If it is overheating usually it will be easy to notice, it will crap out at about roughly the same time from cold and if you restart it after the crash it will crash again quickly. You could also some utilities such as www.alcpu.com/CoreTemp/ to keep an eye on the CPU temp but it could be the graphics over heating which this will not monitor.
If it is a PSU it will be harder to diagnose best bet is to find another one and test that.
RAM is less likely but the easiest way to test that is to only use one a stick at a time if you find any bad sticks. ____________________ Well, you know what they say. If you want to save the world, you have to push a few old ladies down the stairs.
WANTED:- Fujinon (Fuji) M42 (Screw on) lenses, let me know if you have anything. |
| hmmmnz |
 Posted: 22:52 - 13 Feb 2011 Post subject: |
hey guys cheers for the help,
i had suspected it was overheating as well, so had speedfan installed and was watching it, it would sit under 40'C and would max at about 45'C so probably not the issue,
i have done windows memory test on it and dropped it down to 1 gig of ram (4x1g sticks)
there is no beeps from the bios, i just dies,
its getting to the point now where its luck of the draw if it even gets to stage of running windows,
some times it'll get there and run for a few days then die,
alot of the time it'll just die as it trys to start windows,
psu= power supply i gather, i guess it could be that, what voltages should it be running??
i suppose i should start looking for a new pc, this one has done me 10 years
 ____________________ the humans are dead
I kick arse for the lord
Wiring Diagrams BIDNIP it bitches |
 Posted: 10:14 - 14 Feb 2011 Post subject: |
| Quote: | alot of the time it'll just die as it trys to start windows |
Do you get any error messages when this occurs?
Or does it just die?
Have you upgraded your graphics card recently?
If so it may be dragging too much power, thus affecting the voltage regulator.
Most BIOS systems will tell you the CPU temperature and will actually shut down your PC if the CPU is getting to hot to prevent damage.
Average PC's may run at 95-110 F at idle and playing games, automatic shut down is around 140 F. Worth a look!
Are you drawing any more voltage off the same plug socket or ring final circuit.?
You may be surprised, as soon as the dishwashers switched on the computer dies.!
If you have a lot of appliances on at the same time down stairs, your PSU may struggle to the point that the voltage regulator shuts the PC down.
A clue that the PSU is dead or dying is that when the system boots you may get rapid short beeps repeatedly. (Different to BIOS beeps}, Or when it shuts down you may get 4 BIOS beeps.
You get none and no notification what so ever, so you may either have a power connection issue, or the you just need a fresh operating system install. If you need a fresh O/S install, don't forget all the drivers!
Be careful if you decide to change the PSU, I have read that people have gone 3 or 4 PSU's in as many months then discovered the problem was actually with the motherboard voltage regulator or other issues.
It could even be thermal transfer compound between the CPU's surface and the heat sink which had dryed out, and that your fans are fine.
I would take the PSU out and get it checked over at your local market or computer repair shop, they can't charge much for a quick test, this may save you a fortune and a whole heap of trouble.
This should help to calculate what power PSU you need if you need a new one!
If there have been no changes to your PC and it turns out the PSU is dead, just replace it with the standard PSU.
https://www.tomshardware.co.uk/forum/255016-13-calculate-minimum-power-supply-size
Anyway I would invest in a new one for what it's worth! |
| Scotsman37 |
 Scotsman37 World Chat Champion
| Frost |
 Frost World Chat Champion
| Jenks |
 Jenks World Chat Champion
| hmmmnz |
 Posted: 11:00 - 17 Feb 2011 Post subject: |
ok this is the state of it,
i have tryed running on 1 stick of ram, then when it crashed tryed a different stick, then tryed different ram slots,
still kept crashing,
i removed my graphics card and just used the onboard card, still kept crashing,
disconnected the dvd drive and 2nd 2tb hard drive,
still crashing,
installed ubuntu to see if it was the os,
guess what? still crashed,
my win 7 is ultimate 32bit edition
its running at between 30-40'C (86-104'f) all cooling fins clear, all fans running sweet,
no blue screen of death
i know its 10years old but its a p4 3.2Ghz with 4 gig of ram and it used to run sweet as with everything i do,
i don't play games, all i do is watch movies and tv and draw wiring diagrams, its been running win 7 now for over a year
i have bought a new slimline computer which will be delivered in the next day or 2.. but i didnt read the specs properly....
it has no spare sata slots, and only 1x 2.5" solid state drive
so if i can i'd like to keep this one running as my server for my data
i guess the only thing left to try is the power unit ____________________ the humans are dead
| chris-red |
| hmmmnz |
 Posted: 12:12 - 17 Feb 2011 Post subject: |
i did think of doing a bios upgrade, but the program wanted me to save the file to a floppy, who the fuck has a floppy disc these days??
i'll see if i can find a power supply for the dam thing and i'll see if i can buy a floppy some where,
do shops still even sell floppys?? 1.4meg hehe
i havn't used one since windows 3.11,
edit: whats the story of your avatar? its kind of disturbing  ____________________ the humans are dead
| sickpup |
 sickpup Old Timer
| Scotsman37 |
| chris-red |
 Posted: 13:18 - 17 Feb 2011 Post subject: |
| hmmmnz wrote: | i did think of doing a bios upgrade, but the program wanted me to save the file to a floppy, who the fuck has a floppy disc these days??
edit: whats the story of your avatar? its kind of disturbing  |
https://encyclopediadramatica.com/Troll
Lot of cheap crap shops will sell floppys. I needed one to install raid drivers on a laptop, I had to buy a usb floppy drive from maplins, cost £15, that was the only time I used it.  ____________________ Well, you know what they say. If you want to save the world, you have to push a few old ladies down the stairs.
| hmmmnz |
| Hetzer |
 Posted: 20:06 - 17 Feb 2011 Post subject: |
Ha! "Get iiiin there!"  ____________________ "There's the horizon! Ride hard, ride fast and cut down all who stand in your way!" |
| hmmmnz |
| hmmmnz |
 Posted: 11:03 - 21 Feb 2011 Post subject: |
well she's alive again,
resigned now to be my server,
but alive again thanks to a new power supply.. and you guys
hopefully she'll live another 10 years,
pretty monumental if she does, pretty impressive that its made it this long to be fair
thanks again bcf'rs  ____________________ the humans are dead
The last post was made 15 years, 205 days ago. Instead of replying here, would creating a new thread be more useful? |
