GZ125 brake cable removal
Zero
PostPosted: 17:44 - 13 Feb 2011    Post subject: GZ125 brake cable removal Reply with quote
Hi BCF workshop,
I've serviced my rear drum brake, new shoes, oiled the moving parts and all of that but it's still binding. I'm 90% that the problem is with the cable but before I fit a new one I want to have a go at taking the old one out and oiling it, the only problem being that I cannot seem to work out how.
Does the cable pull through from the front or the rear? I can't work out how to remove anything from the cable at either end to allow it to be pulled through... or am I doing something totally wrong? I thought re-fitting the shoes would be tricky, but its the simple looking stuff that I'm struggling on!
Thanks,
- Adam
fiery tupp
PostPosted: 18:06 - 13 Feb 2011    Post subject: Reply with quote
You will have to remove the complete cable , it should be held in place with a bracket
& I think you have to remove the exhaust to get at it easier, can't remember for sure ?
Also I dont think you will get away with just oiling THAT get a new one. Neutral
If you can't fix it with a hammer , use your head .
Zero
PostPosted: 18:32 - 13 Feb 2011    Post subject: Reply with quote
That's fine, I might as well get a new cable if I'm taking the exhaust off to get to it. It's probably not something that'll need doing too regularly.
Thanks for your help Rusty Sprocket.
fiery tupp
PostPosted: 18:47 - 13 Feb 2011    Post subject: Reply with quote
Just look underneath a little forward of where the silencer joins, you should be able to work out the best way to do it .
Take the silencer off first & check But i'm pretty sure it's best to remove the full system Neutral
The last post was made 15 years, 10 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.29 - MySQL Queries: 13 - Page Size: 38.45 Kb
