| dgo1212 |
 dgo1212 Brolly Dolly
 Posted: 21:09 - 13 Feb 2011 Post subject: Kicking bad habits |
Yesterday I did a days training in preparation for my bike test, mod 1 is booked for next week, didn't go well .Instructor says my riding is pretty good however I've picked up a few bad habits that will cost me my test if I don't kick them, apparently this is because I have done my cbt 4 times and never took my test.My biggest problem is the lifesaver, I tend to do it as I set off rather than before, and I occasionally change up gears without clutch and only use 2 fingers to brake, I try my best not to do these things and start off quite well but end up slipping back into the habit in no time, and to top it off I rode through a stop sign as I didn't notice the 12ft high giant red 50p or the 2 foot painted letters on the floor, I just looked for traffic and rode through as it appeared safe.
Instructor recommends I have at least 2 more training days and book my mod 2 for the same day as my mod 1 if they have a slot, this is so I do my training and test on consecutive days and he insists I don't ride my bike in between.
Any ideas on kicking these habits as I can't have my instructor follow and shout at me every time I do something wrong and I'm now worried about failing my test, I was so confident I would pass I wasn't even going to have any training but now that confidence has long gone |
| Jodie |
 Jodie Crazy Courier
 Posted: 21:16 - 13 Feb 2011 Post subject: |
It is a gamble doing your Mod 2 the same day cos if you forget your lifesavers on Mod 1 they will fail you and that's £80 quid lost.
I did a day training before Mod 1 then a day before Mod 2 which worked out fine for me.
It's up to you but from reading that I'd plan on getting through Mod 1 first.
Good luck  |
| dgo1212 |
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 21:23 - 13 Feb 2011 Post subject: |
OK, life savers and shoulder checks.
A Shoulder Check or Rear-Observation is a full 180 rearward look behind you to check for traffic or other hazards BEFORE doing a manouver.....Turn head, chin to shoulder to be sure its seen as a propper shoulder-check.
A life saver is a 'safety glance' DURING a manouver, to check for any change in circumstances, or other hazards. To be sure its seen as a life-saver not a sloppy shoulder check, or mirror check, move head deliberately past the mirror but not as far as your shoulder.
Only way to drill it is to PRACTICE PRACTICE and PRACTICE...
Shoudler Before, Life-Save during....
Clutchless.... hmm... no biggie, but could be percieved as 'sloppy' if spotted, but of smooth enough possibly wont be noticed.
Two finder praking and not using rear brake, will be being looked for...
But as long as manouvers are under control, not major faults.
ALL I can suggest really is you need to be a bit more conciouse in THINKING about what you are doing, rather than relying on your sub-conciouse, which is ahet you have learned to do riding so long...
But, you mustn't 'over-think' or you will not perform as you really ride, and you'll let nerves get the beter of you panicking about it....
Shoulder-Checks and life-savers, are important, and a bit of discipline well worth getting sorted not just for the test, but every day riding, two finger braking and clutchless... I'd not be so worried about.
end of the day, practice, try thinking your ride a bit more, practice some more, then think sod it..... you ride how you ride, they'll pass you or they wont.... and yes, they are looking for you doing it 'right' and points of technique, BUT mostly whether you are safe and considerate, and aware of everything around you..... like fucking stop signs meaning STOP not give way... plonker!
Its just a bit of showman-ship... DEMONSTRATING doing it rather than just doing it....
Think about your ride as if YOU were the instructor trying to show a newbie what to do...... rather than what your doing and what he expects, or what you should be doing.... just make everything that bit more 'deliberate' and you should do fine. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| Jodie |
 Jodie Crazy Courier
| N cee thirty |
 N cee thirty Banned
| dgo1212 |
| dgo1212 |
| N cee thirty |
 N cee thirty Banned
| Suntan Sid |
 Suntan Sid World Chat Champion
 Posted: 22:05 - 13 Feb 2011 Post subject: Re: Kicking bad habits |
| dgo1212 wrote: | and I occasionally change up gears without clutch and only use 2 fingers to brake |
Is this for real?
What kind of, clueless, morons think up this crap?
WTF does is matter if you do clutchless changes and WTF does it matter how many fingers you use to brake?
Is there something in the highway code that specifies how many digits are required on the brake lever at any given time?
Total and utter bollox, (not aimed at you "dgo1212", by the way),!
Are they saying you're using too many fingers or not enough?
I can't remember the last time I used more than one finger!
I feel for you lot, sometimes, I really do!
Book a flight to Cyprus mate, if you make it to the test center in one piece, and manage a few cones in the carpark, hey ho you've passed.
Send your new, Cypriot, licence to the DVLA and get it changed for a UK one, job done! Probably work out cheaper as well!
Rant over!  |
| dgo1212 |
| Suntan Sid |
| Syris D Indomitable |
 Syris D Indomitable Nitrous Nuisance
 Posted: 22:31 - 13 Feb 2011 Post subject: |
MOD 1 will be easy, don't forget the life savers before performing any manoeuvre even though you are on a car park. They will test you for this, I.E say after the controlled ride at walking speed the examiner will explain the speed swerve test, then say right off you go. “DON'T FORGET THE LIFE SAVER OVER BOTH SHOULDERS” as with the U turn RIGHT SHOULDER CHECK BEHIND YOU and with the bike handling reverse manoeuvre BOTH SHOULDERS BEHIND YOU!...ETC. OTHER STUFF IS JUST 90 DEGREE SHOULDER CHECK
I passed the MOD 2 on an Aprilia RS 125, this has to be the hardest bike to pass your test in terms of life savers and arm ache. Your facing the floor almost having too look to the side and behind you.
Anyway what they are looking for is you ability to envisage with forethought what the traffic ahead is about to do before making your life saver, they are looking at your pre-emptive vision and awareness. If you make a life saver to early and you haven’t judge correctly what the traffic ahead is going to do which sometimes happens, just make another life saver before you set off, and more importantly if your not positioned correctly at a junction the examiner will fill in the gap you should have filled to see, if when you make your life saver, you are actually looking back at the the gap you just left at the junction. He/she will be looking at your eyes.
Also watch for the stop signs and stop, don't coast at junctions performing balancing acts which have stop signs, then set off when the junction is clear. I did this and they failed me for it the first time. I didn't technically put my foot down.
And obviously watch for people crossing any junction, don't just pull out even thought the junction is free of traffic, people have failed for this believe it or not even when they slowed down or stopped in the midst of the junction to let them cross. Watch for this is built up areas. |
| evoboy |
 evoboy World Chat Champion
 Posted: 02:12 - 14 Feb 2011 Post subject: |
I did my test using 2 fingers on the brake and clutchless upshifting...
Needless to say i passed.... ____________________ Suzuki GT250 x7------- Fazer 600------CB250RS------Aprilia Rally 70----- Bandit 600
APT Motorcycles |
| outlaw |
 outlaw Renault 5 Driver
| Rogerborg |
 Rogerborg nimbA
 Posted: 13:28 - 14 Feb 2011 Post subject: |
A late (but not missed) rear observation is likely to be a minor unless you cause another road use to take avoiding action. It'll get you killed though. Fix it.
Gearchange and braking technique is at most a minor (as long as you're in control). Don't sweat it.
The missed stop is a test fail. Don't beat yourself up over it - you were concentrating on the actual road, not on the signs or the instructor, which is ultimately the right thing to do. You'll just need to raise your game a bit for the test.
So you know what you need to do: get on with doing it yourself. You don't have an instructor with you before, during or after your test, so you need to be safe on your own. If money is an issue, I wouldn't bother getting more instruction before your test - you can't pass during a training session. But I'd recommend more training after you pass: BikeSafe, IAM, RoSPA, DSA Enhanced Rider.
Best of luck, and make sure you watch the DSA videos on YouTube - they're actually quite helpful. ____________________ Biking is 1/20th as dangerous as horse riding.
| kingsknight |
 kingsknight World Chat Champion
| fiveus |
 fiveus Spanner Monkey
 Posted: 15:56 - 14 Feb 2011 Post subject: |
Examiners also like to see your brake lights showing as soon as you see roundabouts and junctions.Just a little touch of the rear will do.Until you need to stop or slow properly.  |
| G |
 G The Voice of Reason
 Posted: 16:42 - 14 Feb 2011 Post subject: |
Were it me, I would continue riding, but be very careful about doing everything absolutely correctly.
Mentally chastise your self when you doing something wrong.
Was practicing for my truck test in my own vehicle a while ago and I was quite aware of all the things I was doing wrong - didn't need to pay someone to shout at me.
Try and slow it all down a bit if you can - make sure you THINK before every action.
So, going to change lane, STOP (not the bike, just your actions )... think about the official sequence, then do it. |
| colin1 |
 colin1 Captain Safety
 Posted: 17:07 - 14 Feb 2011 Post subject: Re: Kicking bad habits |
| dgo1212 wrote: | I occasionally change up gears without clutch and only use 2 fingers to brake, |
Your instructor wants you to pass, but he also wants to make money out of you. He wants you to do as much training as someone who hasnt been riding for years. For him, getting you to do more training is more likely to get you to pass aswell as him getting more money, so its both people winning.
I had to retake my test due to getting 6 points within 2 years of having my license, I had similar things, including the stop sign. You wont make the stop sign mistake again so it's good that you got caught on it before the test.
In reality, the examiner is probably going to be following you in a car, and will have no idea whether you are using your clutch, and may not even be able to see when you are changing gear.
I'd suggest getting practise in riding around as you would on your test, without an instructor in your ear distracting you with advice. You know what you need to do, you just need to do it enough so it becomes second nature.
You need to take on board what you are being taught, but dont let them sap your confidence. Before my retest, they thought I wouldnt pass due to a few minor things like stop sign, not noticing change in speed limit etc on lessons. But this was because I wasnt riding under normal circumstance, and was having to think not only about what I was doing but what I was being told over the ear piece. This is kind of necessary, as its not always possible to pull someone over and talk over things, but on your test, you just need to keep a cool head, not get too focused on one thing so you miss something else. The main thing is, you wont have a commentary in your ear that you have to pay attention to so you can concentrate on the ride.
You do need to practise riding around the correct way though, so you don't have to think about it, it just becomes second nature. The instructor has done a good job pointing out your bad habits, you just need to practise not doing them. ____________________ colin1 is officially faster than god |
| Davie J |
 Davie J Scooby Slapper
The last post was made 15 years, 262 days ago. Instead of replying here, would creating a new thread be more useful? |
