front sprcket gone ???
fireyphoenix1...
PostPosted: 07:08 - 14 Feb 2011    Post subject: front sprcket gone ??? Reply with quote
riding the bike home today i heard a weird noise then lost all drive at first i thought the clutch had gone and pushed the bike home on the way i noticed the chain was really slack so i was hopeing it had just jumped off the sprocket
when i got the bike home i stripped the front sprocket cover off i found the front sprocket was completely gone no marks on the chain or the inside of the cover
i have been back to where the bike broke down with friends and found no pieces of it its like it just vanished the only thing i can think is when the bike was serviced about 100 miles ago the mechanic incorrectly fitted the cirlip holding the sprocket on .bikes being picked up and the guy better fix it or im reporting him
my question is this
does any one know how the hell this can happen as everyone i have spoken to says they have never heard of anything like this
fife
2014 Aprillia dorsoduro 750 factory.
weasley
PostPosted: 08:41 - 14 Feb 2011    Post subject: Reply with quote
It's a known issue on the Thundercat for the sprocket nut to unwind and eventually come off, although the sprocket usually stays in the sprocket cover.
Marmalade
PostPosted: 09:11 - 14 Feb 2011    Post subject: Reply with quote
Was the sprocket replaced when serviced?
Wouldn't be touched otherwise.
Have you tried walking the route you pushed the bike home, sprocket might have come off but not actually fallen out until on the way home, more than likely it's embedded in the side of someone's head, think how fast that thing spins.
PostPosted: 09:27 - 14 Feb 2011    Post subject: Reply with quote
As above, there's no reason to touch it in a service - unless you had a new one fitted. don't blame the fitter you just had some bad luck.
What bike is it anyway?
.Bishbash.
PostPosted: 13:28 - 14 Feb 2011    Post subject: Reply with quote
Wow, that's unlucky it came off completely. I did have this once, thought the same as you, the clutch had gone etc. But my sprocket was still there.
Luckily they are cheap Wink
Current bike - GSX-R1000 k8
andym
PostPosted: 13:40 - 14 Feb 2011    Post subject: Reply with quote
Same thing happened to me quite recently, although I was told it was the clutch or shaft had gone, it was only after posting on here (and stripping the bike down to get at the clutch), did I find it was probably the front sprocket... Luckily the sprocket, washer and nut were all still sitting in the casing.
Because me and a friend replaced the chain and sprockets I put it down to I hadn't tightened up the nut enough. So with the bike on the ground and both brakes applied I tightened it up as much as the weight of the bike would allow and made a mental note to check it after 2 weeks... I checked it yesterday and the nut had started working itself loose again... so if it does it again I'll be using a splash of locktite on there
Anyway as already mentioned walk back the way you came and see if you can find the parts... may want to walk back further than where the bike broke down though as the nut (if it has one), could have come off a couple of miles before the sprocket finally let go.
fireyphoenix1...
PostPosted: 14:32 - 14 Feb 2011    Post subject: Reply with quote
me and a friend walked the route twice yesterday Sad no joy not a sign of it
Yes the bike had a new chain and sprocket kit fitted about 100 miles ago i had checked the bike over before going for a ride chain was just oiled and the tension was correct . its a baimo RSR 125 over 11000 km on the clock with no mechanical issues so im rather annoyed that its playing up right after a full service and having the perishables replaced Sad
the mechanics picking the bike up in the morning
ah well my das soon then i can get my honda Very Happy
fireyphoenix1...
PostPosted: 12:40 - 15 Feb 2011    Post subject: Reply with quote
bike in the garage the lock ring had disintergrated with the sprocket
mechanic found a few very small fragments that i hadnt spotted
its being put down to a faulty component and repaired for free
Cognitive_Faux
PostPosted: 12:46 - 15 Feb 2011    Post subject: Reply with quote
yup happened to me too on my old thundercat.
isnt there a lock tab nut under there that gets twisted?
bike theory (pass) bike test (pass)(4 minors) car theory (pass) car test (pass)(1 minor!!!)
cb125t->sr125->expressII50->xlr125->GS550L & GS550E->XBR500 'chop'->YZF600R->FZS600->GSF650->fantic 212cc->gsf650->kwak GT750->VFR750 ->
HGV class 2 (pass)
fireyphoenix1...
PostPosted: 14:57 - 15 Feb 2011    Post subject: Reply with quote
couldnt see one when the sprocket kit was swaped out
The last post was made 15 years, 258 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.54 - MySQL Queries: 13 - Page Size: 70.05 Kb
