Piaggio Zip 2009 2T Question
nlel1975
PostPosted: 15:07 - 15 Feb 2011    Post subject: Piaggio Zip 2009 2T Question Reply with quote
The battery in my Piaggio Zip 50 2009 2T is totally dead as in it will not hold any charge.
When you turn on the ignition normally the oil and fuel lamps light up briefly then go out if the battery is holding a charge.
With my bike the oil and fuel lamps are staying lit and they are sort of flickering ie they never go out.
I presume this is because the battery is not holding charge. At first I thought the oil was genuinely low but when I tried to fill it up I overfilled it and oil went everywhere.
In other words the oil is def not low. Is it definetely the battery causing this behaviour?
nlel1975
PostPosted: 15:32 - 18 Feb 2011    Post subject: Reply with quote
I took the Zip out for a long ride today and the oil and fuel lamps went out after awhile and now the battery is holding a charge. It is still knackered though and will need replacing but at least I know it was the battery causing the lights to stay on.
The last post was made 15 years, 145 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 3.36 - MySQL Queries: 13 - Page Size: 35.33 Kb
