Take exhaust off a CB125TDC
Nemo
PostPosted: 12:47 - 16 Feb 2011    Post subject: Take exhaust off a CB125TDC Reply with quote
Does anyone know if they're easy enough to get off?
Previously owned: Kawasaki KH125, Suzuki GP125, Suzuki GX 125, Honda CB125 TDC '83, Honda ntv 600, Kawasaki ER5, Kawasaki ZZR600, Aprilia RSV 1000 Mille
Now own: Ducati 848 evo
Scotsman37
PostPosted: 14:19 - 16 Feb 2011    Post subject: Reply with quote
You could have at hand an impact driver just in case the nuts are corroded and won't budge at first with a spanner. This is just in case to prevent rounding them off so that you can use them again!
As mentioned earlier using the appropriate grease prevents future corrosion on the threading, but having set of replacement exhaust gaskets would also help as to maintain an airtight seal when re-installing the exhaust system.
https://www.wemoto.com/bikes/Honda/CB_125_TDC_TDE_Superdream/82-87/[/url]
Nemo
PostPosted: 15:36 - 16 Feb 2011    Post subject: Reply with quote
The exhausts are in spanking condition, I just don't like the cone style they have going on, want to see if I can get something a little different, but won't destroy the bike.
Scotsman37
PostPosted: 16:01 - 16 Feb 2011    Post subject: Reply with quote
Motad Exhaust
https://www.whitedogbikes.com/item--Motad-Honda-CB125-TDC-to-TDJ-Superdream-Full-System--motad-cb125t-sdream-full-syste.html
https://cgi.ebay.co.uk/HONDA-CB125-TDC-SUPERDREAM-MOTAD-EXHAUST-/150394010272?pt=UK_Motorcycle_Parts&hash=item23042e7aa0
DrDonnyBrago
PostPosted: 16:08 - 16 Feb 2011    Post subject: Reply with quote
As above, if the nuts come off the studs or the studs come out of the head nicely then it is a piece of pi$$ to do. If you snap studs in the head and end struggling to remove the stumps before finally drilling the bolts out at the wrong angle and fooking up your engine it is a slightly different story.
The last post was made 15 years, 257 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.45 - MySQL Queries: 13 - Page Size: 47.8 Kb
