Bearings upgrade!
kingsknight
PostPosted: 17:27 - 16 Feb 2011    Post subject: Bearings upgrade! Reply with quote
Bike failed it's MOT on the head stock bearings needing to be replaced. Ordered some taper headstock bearings as a replacement but I'v just found out that the standard bearings in my headstock are just ball bearings.
https://i302.photobucket.com/albums/nn92/breakingpointltd/09022011%20XR125/CIMG0759.jpg
I take it upgrading the ball bearings to taper bearings shouldn't be a problem?
TS50 (sold) NS125F (sold) NSR125R-K (write off after 2 crashes) CG125 (nicked) XR125L-3 (Sold )-: ) DR125SM '11 (sold yay) XL125V '12 (In love with this bike) XT600E '04 (fun on the dirt)
PostPosted: 17:39 - 16 Feb 2011    Post subject: Reply with quote
Upgrading is not a problem.
Getting the original races out/off in order to fit the new ones can be something of a bastard.
There will be many threads covering this subject.
EDIT: Is that a super wide-angle lens or are both your fork stanchions bent?
kingsknight
PostPosted: 17:41 - 16 Feb 2011    Post subject: Reply with quote
not my forks, found that image on ebay. Any tips on how to get the old ones out?
PostPosted: 17:50 - 16 Feb 2011    Post subject: Reply with quote
https://www.bikechatforums.com/viewtopic.php?t=199292
kingsknight
PostPosted: 18:42 - 16 Feb 2011    Post subject: Reply with quote
you sir, are a star. Karma
Ed Case
PostPosted: 20:41 - 16 Feb 2011    Post subject: Reply with quote
FItted Taper Roller head bearings to my 250RSA 8 years ago, big improvement, no 'indexing' piece of piss to fit and finally actually cheaper than OE cups/balls/etc. No contest. Smile
kingsknight
PostPosted: 21:11 - 16 Feb 2011    Post subject: Reply with quote
nice one thanks mate, I'm just a little worried about the old bearing seats not wanting to come out. I'm looking forward to getting this job out of the way!
Ed Case
PostPosted: 21:17 - 16 Feb 2011    Post subject: Reply with quote
a 'Drift' longish (12 inch) metal bar and a decent hammer, go down through the top for the bottom one and vice-versa for the top one. Dont beat the shit out of it, you'll find it wont take too much belting, work slowly around the bearing tapping it around, it'll soon move and drop out.
PostPosted: 21:18 - 16 Feb 2011    Post subject: Reply with quote
I would be more worried about how difficult it might be to get the taper roller races out of the frame should they need to be replaced.
Teflon-Mike
tl;dr
PostPosted: 21:19 - 16 Feb 2011    Post subject: Reply with quote
HOW To: Overhaul the Head-Stock / Replace & Adjust Steering Bearings
Ed Case
PostPosted: 21:23 - 16 Feb 2011    Post subject: Reply with quote
As long as they're well greased on assembly they should outlive the bike but they come out just the same way, I've done the swap on three bikes, a pleasant half-days work in the shed.
PostPosted: 21:42 - 16 Feb 2011    Post subject: Reply with quote
Personally I wouldn't trust them to last any longer than the ball bearings. The load on the steering head bearing is mainly along the line of the steering head and ball bearings are fine for that.
Had to replace knackered taper roller bearings quite a few times. Trouble is that compared to normal ball bearings they have a very narrow outer race which can sometimes barely (if at all) stand beyond the mounting ridge for the bearings. Makes them pretty much impossible to drift out without grinding away at the frame.
kestrel
PostPosted: 21:56 - 16 Feb 2011    Post subject: Reply with quote
The easiest way i've found to remove inner races from the headstock is to tack weld a short piece of flat bar across the race, drill a hole in the flat bar and use a slide hammer to pull the race.
Ed Case
PostPosted: 22:09 - 16 Feb 2011    Post subject: Reply with quote
Changed taper rollers on a '77 Laverda SF and a 250 that had been laid up outside for some years...........no problem with either.
kingsknight
The bloke at the MOT centre said that they should last at least twice as long as ball bearings and should be a lot easier to replace as well...... Shocked
Ed Case
PostPosted: 22:10 - 16 Feb 2011    Post subject: Reply with quote
There you go !.
PostPosted: 22:20 - 16 Feb 2011    Post subject: Reply with quote
Longer lived wouldn't surprise me, although not sure I would expect them to last twice as long. Possibly easier to replace than faffing round with individual ball bearings (especially if those bearings are sold singly like the NS Laughing ) but from experience far more difficult to remove from the frame.
Not saying not to use them (have a set to go into the NS frame when I put it back together), just be aware that there are down sides. Also they seem to be trickier to get adjusted properly.
As an aside, a load of Aprilias use a taper roller bottom bearing but with a conventional caged ball (ie, like a big wheel bearing) top bearing. Bottom one has the near to vertical load while the uppers vertical load is just the weight of the forks and any clamping force from being tightened up.
Teflon-Mike
tl;dr
PostPosted: 22:28 - 16 Feb 2011    Post subject: Reply with quote
Some-one left a Laverda SF OUTSIDE!
do the Laverda Owners Club know about this?
Have they sworn out a Fatwa on him? Laughing
Ed Case
PostPosted: 10:53 - 17 Feb 2011    Post subject: Reply with quote
You'd be surprised just how ambivalent some Laverda owners used to be about looking after their bikes, they aren't these days though, what you could get for £2000 three or four years ago is pulling £9000 now and some idiots are actually paying it.
woodyfjr
PostPosted: 11:21 - 17 Feb 2011    Post subject: Reply with quote
When ever I have done the head bearings I fit tapers but these can fail like any other bearing as they all need greasing but owners dont bother.
If you don't pay your exorcist you can get repossessed.
If you have to rev it! Don't Buy it!
Ed Case
PostPosted: 11:39 - 17 Feb 2011    Post subject: Reply with quote
Well said Woody !.
PostPosted: 13:11 - 17 Feb 2011    Post subject: Reply with quote
Headstock bearings fail because they spend most of their time in one positiong (steering straight forward).
To remove a bearing race from a headstock, simply run a bead of weld around the inside. They will shrink when the weld cools and fall out.
Put a piece of scrap ally in the bottom to prevent the bearing being welded to the headstock.
kingsknight
PostPosted: 17:29 - 21 Feb 2011    Post subject: Reply with quote
Well I done the bearings upgrade and fuck me it was a CUNT. Everything went smoothly until it come to removing the bottom bearing seat. Took me and my grandfather 2 hours to get the old one off and the new one on.
The old one just refused to move not matter how much force we used and once we did get it off the new seat refused to set rightly.
The whole job took about 4 hours. Neither of us ever had done them before so we both learnt something new.
I didn't really know how fucked my old bearings was until I felt the new ones. It's really worth the upgrade as you can feel the difference straight away!
Thanks for your help guys, I knew what I was kinda getting into thanks to you lot! Karma
Job done
PostPosted: 17:44 - 21 Feb 2011    Post subject: Reply with quote
How did you get the bottom seat off? Just trying to lever it off is usually a non-starter.
The way I do it is to cut down one side with my angle grinder, taking care to catch the stem as little as possible. You have to cut at an angle because you can't get quite flat to the stem but the top you can split with a small chisel. They just fall off then or can be prised with a small lever. Bonus is, you can then turn the old one upside down and use it as a drift with a bit of tube to drive on the new one.
Teflon-Mike
tl;dr
PostPosted: 18:33 - 21 Feb 2011    Post subject: Reply with quote
kingsknight wrote:
Job done
Thumbs Up Laughing Thumbs Up
THAT is the important bit!
Does make such a difference doesn't it?
Soooooo many people grumble about the way bikes handle, Soooooo many of them have probably never had thier head-stock bearings even adjusted!
Just remember, give it a week, maybe 100miles or so to 'bed in', and check and tweek the pre-load again, or they'll be as sloppy as your old ones in no time!
The last post was made 15 years, 212 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.89 - MySQL Queries: 13 - Page Size: 134.5 Kb
