Aprilia rs125 Problem!!!
knowlezy
PostPosted: 16:51 - 17 Feb 2011    Post subject: Aprilia rs125 Problem!!! Reply with quote
Hello, I own a aprilia rs125 2000 reg i was riding it up untill last week and the bike suddenly lost compression now wont start. How will i find out the cause of the problem ? many thanks
clancy
PostPosted: 16:53 - 17 Feb 2011    Post subject: Reply with quote
did it just cut out and wont start ? what happens when you try to start it? litereally nothing or is there some form of noise etc ? need some more info
KLX 300r
dextersaurus
PostPosted: 17:29 - 17 Feb 2011    Post subject: Reply with quote
This could be a few things...
Reed valve jumps out at me though. If it was absolutely fine then just cut out, i doubt it was a seizure, as you'd feel a drop in power before it happened.
Describe what happened when it stopped - did it just all of a sudden cut out, no loss in power and no funny noises?
Dunc
damongrimshaw
PostPosted: 10:37 - 18 Feb 2011    Post subject: Reply with quote
My old RS did that to me it turned out to be a knackered plug, when I took the plug out it seemed fine sparked well but when I put it back in it arc'd the spark down the side of the plug
Also had a previous problem with my recifier so it wasn't charging the battery and eventually it cut out
Wanted: zx6r J1 fairings cash waiting
clancy
PostPosted: 18:07 - 18 Feb 2011    Post subject: Reply with quote
if the bikes running and the battery dies i doubt it would cut out though, you can use them little bikes without a battery in them if you bump them, well you could on my rieju 50
KLX 300r
lukamon
PostPosted: 19:28 - 18 Feb 2011    Post subject: Reply with quote
lost compression = holed piston? did you put a shiny new exhaust on it not too long ago?
killa wrote: Im an ass man myself
Avora
PostPosted: 20:01 - 18 Feb 2011    Post subject: Reply with quote
You shouldn't need much poking around to decide if the compression is low...as you dont have a kickstart, you should put the bike in gear and give it a little push. Easy option will be if you have a compression tester. But as suggested the RS is known for its siezures. I would just pull the head off and give the engine a quick look...its what all us other stroker fans do. Good luck Smile
Kawasaki AR125 B8 - Getting ready for a summer time soon!
The last post was made 15 years, 144 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 3 - MySQL Queries: 13 - Page Size: 55.51 Kb
