| Willson |
 Willson Traffic Copper
| finpos |
 finpos World Chat Champion
| Willson |
| Rockhopper |
 Rockhopper Trackday Trickster
| Vincent |
 Vincent Banned
| Rockhopper |
| Willson |
| Rockhopper |
 Posted: 19:12 - 17 Feb 2011 Post subject: |
Can't have been otherwise you wouldn't have a leak  |
 Posted: 21:33 - 17 Feb 2011 Post subject: |
I usually fit the collets using a pair of tweezers. There is a magic distance to have the spring compressed where they will drop into place but not fall through. Back off the tensioner on the spring compressor a bit at a time until you reach this point. You often need to gently push it over to one side then the other to get them both in
Bench mounted, lever action spring compressors are much better for doing this because you can ease off the pressure you're putting on the spring as you insert the collets. Not so common to have though.
If there is a grey ring all round the valve, they should seal. Is there any pitting on the seat?
EDIT: I was also taught to give the end of each valve a good sharp tap with a hammer after the collets are fitted to make sure everything is seated properly. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
The last post was made 15 years, 8 days ago. Instead of replying here, would creating a new thread be more useful? |
