Has anyone got any tips on cleaning stainless steal exhuasts
hornetmike
PostPosted: 19:48 - 17 Feb 2011    Post subject: Has anyone got any tips on cleaning stainless steal exhuasts Reply with quote
As above really, just bought a bike and the only thing letting it down is the downpipes are stained, what's the best way of cleaning them ?
87 Honda CG 125 - 97 ER5 - SR 50 -81 Z250- 96 CBR 600 F- 94 GPX600R 88- GPX 400R- 87 GS 125 - 2006 Honda CB600F- 2003 ER5 - Honda CBF 1000 2009 - Honda CBR 600 RR 2011
Current BMW R1200GS 2010
Paxovasa
PostPosted: 19:50 - 17 Feb 2011    Post subject: Reply with quote
Autoglym metal polish Thumbs Up
fiveus
PostPosted: 20:46 - 17 Feb 2011    Post subject: Reply with quote
brillo pads
hornetmike
PostPosted: 21:03 - 17 Feb 2011    Post subject: Reply with quote
Probably a school boy comment, but is stainless steal, stainless all the way through or is it a coating ?
Dazbo666
PostPosted: 21:52 - 17 Feb 2011    Post subject: Reply with quote
I tend to use green nylon scouring pads to get the worst of the grit and muck off, then metal polish to get the shiny finish Thumbs Up
As for stainless steel, or stainless coating, I seem to remember reading somewhere on this forum that pure stainless steel is not magnetic??
Word of the day : DILLIGAF
0l0dom0l0
PostPosted: 22:04 - 17 Feb 2011    Post subject: Reply with quote
Brick acid works well.
Spray on with a bottle, or brush on. Leave for 2 mins, rinse off with hose.
I will try to find an old thread I remember where a guy cleaned his hornet exhausts with brick acid. The difference was crazy!
Also, if its high grade stainless it wont be magnetic as above ^, but if its low grade then it will be magnetic. The stainless isn't a coating, its all the way through, so don't worry about taking a bit off!
EDIT: Here is the link, but I have stole the pics. Used Brick acid, then the autosol with scouring pads.
https://www.bikechatforums.com/viewtopic.php?t=200279&postdays=0&postorder=asc&highlight=hornet+exhaust&start=25
Before:
https://i770.photobucket.com/albums/xx346/ThatHornet/51a59ac0.jpg
After:
https://i770.photobucket.com/albums/xx346/ThatHornet/a52fb838.jpg
https://i770.photobucket.com/albums/xx346/ThatHornet/12240d74.jpg
nathandenniso...
PostPosted: 22:10 - 17 Feb 2011    Post subject: Reply with quote
+1 for Brillo Pads, cheap and easy to use and do the job perfectly (if you put in the elbow grease)
Rowey
Stainless steel is not actually un-stainable, it's called stainless as it will not easily oxidise in air. Stainless steel will discolour and dirt will burn onto it.
It's steel typically with chromium and nickel added. Other metals can be added to change it's properties. It resists rusting by forming a layer of chromium oxide over the metal.
Proper stainless is almost completely non-magnetic.
ZX6R C6F.
Rowey
PostPosted: 22:12 - 17 Feb 2011    Post subject: Reply with quote
Oops, and OT. I use those coiled flat steel type brillo pads with a bit of oven cleaner at first then move onto a finer scourer and metal polish.
ZX6R C6F.
Scotsman37
PostPosted: 23:25 - 17 Feb 2011    Post subject: Reply with quote
For removing stubborn burnt on stains I found using extremely fine wet/dry finishing paper does an excellent job of finishing of pipes to make them shine again!
flange
PostPosted: 23:44 - 17 Feb 2011    Post subject: Reply with quote
+2.I use a little bit of Solvo on the Brillo pad Thumbs Up
clancy
PostPosted: 23:58 - 17 Feb 2011    Post subject: Reply with quote
autoglym metal polish Thumbs Up i use auto glym almost everything, brilliant stuff
KLX 300r
Teflon-Mike
tl;dr
PostPosted: 00:45 - 18 Feb 2011    Post subject: Reply with quote
Yes, 'Stainless' steel is a bit of a mis-noma.
Its a high Nickel/Tin steel alloy, which is rust resistant, due to the electro-pottentials and a galvanic self healing effect, like zinc plating, as in 'galvanised' after the clever chap that noted the effect of different electro-pottentials between metals.....
Given the right circumstances 'Stainless' will tarnish and even rust, its just not as inclined as mild steel.
And 'bluing' due to heat is one of the things that will discolour it.
Think thats actually the chrome content, becouse single skin chrome plated headers do the same thing when exposed to severe heat...
As do 'stainless' butter knives stuck in a gas-fire in student digs... when used for particular purposes you would NOT expect your mother to recognise, when she turns up with a care package and decides to do the washing up!
You can remove some of the tarnish off them with a brillo-pad and polish, because it is in the surface layer.. its not a coating, but the oxide layer that forms a skin on the exposed surface of the metal, and some of the tarnish is 'crud' coloring the oxide like anodizing is colouring in aluminium oxide surface layer....
The bluing though, you wont remove, because thats actually in the metal.
clancy
PostPosted: 00:48 - 18 Feb 2011    Post subject: Reply with quote
i dont get where people get the idea stainless cant stain. if it couldnt stain it would be could stainproof stell.
its stainless, because it stain-LESS than normal steel
KLX 300r
pits
PostPosted: 00:53 - 18 Feb 2011    Post subject: Reply with quote
#00 gauge wire wool and Autosol metal polish, scouring pads will just scratch it all up and leave scratches Thumbs Up
kestrel
PostPosted: 01:22 - 18 Feb 2011    Post subject: Reply with quote
Brick acid is a good method of removing the hardened road crud prior to polishing.
Most stainless exhaust systems are made from 304 stainless from the 300 series of austenitic stainless steels containing around 18% Chromium and 8% Nickel. The 300 series are non magnetic in the annealed state but become progressively more magnetic as they are cold worked. 304 is a good choice because it is easily fabricated and welded.
Stainless exhaust systems are sometimes found in 409 stainless which is magnetic. The material choice is a bit of a trade off, 409 is better for resisting internal corrosion fron the sulphur in exhaust fumes and 304 is better at resisting external corrosion from the weather and road salt etc. 316 would be the better all round material but is more expensive and more difficult to work with.
If you are doing the final clean up with wire wool then don't use ordinary mild steel wool as it contaminates the surface of the stainless and encourages surface rusting, use stainless wool instead which only costs a few pence more.
PostPosted: 01:24 - 18 Feb 2011    Post subject: Reply with quote
Explain other words that use the suffix 'less' such as 'childless'.
It doesn't mean someone has less of a child, it means they don't have a child at all Wink
Apply it to stainless and your argument has just been blown out of the water.
P.S. I understand stainless steel can be stained, I wasn't arguing that fact.
woodyfjr
PostPosted: 09:42 - 18 Feb 2011    Post subject: Reply with quote
Brick acid... I'll give that a try. Cheers
If you don't pay your exorcist you can get repossessed.
If you have to rev it! Don't Buy it!
CarlosCBR
PostPosted: 10:08 - 18 Feb 2011    Post subject: Reply with quote
Autosol and wire wool.
killa
Won't Shut Up
PostPosted: 12:24 - 18 Feb 2011    Post subject: Reply with quote
If you use a type of scourer pad at first, with some metal polish, what type of cloth or whatever, would you use to finish the job?
owl10
PostPosted: 16:53 - 18 Feb 2011    Post subject: Reply with quote
Hmmm,
Cleaning up stains you've left behind whilst stealing someones exhaust - depends on the stains you've left I suppose.
Cleaning up stainless steel is another matter....
DanceLikeAMonkey says: "An infinte amount of web pages available
Yet I still end up reading crap like that"
clancy
PostPosted: 18:03 - 18 Feb 2011    Post subject: Reply with quote
i know it doesnt work for anything else Laughing but from what i know that is the litteral meaning behind why its called stainless steel
KLX 300r
The last post was made 15 years, 223 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.43 - MySQL Queries: 13 - Page Size: 121.88 Kb
