splutter
hellbound
PostPosted: 09:37 - 18 Feb 2011    Post subject: splutter Reply with quote
Suzuki GN250
every now and again I loose all power on the bike, it idles but when I try and accelorate it splutters and backfires, it will do this at random times usually when I try and pull away after riding at 20 to 30 mph.
the only way I have found to cure it is to leave it to idle and try it every now and then or pull the choke out which then makes its splutter and eventually rev up.
Carb has been cleaned several times, it has a new spark plug and it doesn't matter how much fuel is actually in it.
Ideas?
May you always see the road rising up to meet you and your enemies defeated in the mirror behind.
neil.
PostPosted: 10:02 - 18 Feb 2011    Post subject: Reply with quote
Air filter dirty or damaged or blocked? Carb inlet rubber (the big bit that connects carb to engine) cracked/damaged, meaning more air from outside getting sucked in?
hellbound
PostPosted: 10:18 - 18 Feb 2011    Post subject: Reply with quote
Air filter has been replaced
Didn't think of carb rubber but then thought it would do it all the time not once or twice a week, or then be fine for a few months then start again.
neil.
PostPosted: 10:20 - 18 Feb 2011    Post subject: Reply with quote
What about fuel filter being clogged? Depending on the bike, you might have one in the fuel tap and a strainer in the tank, as well as an in-line one somewhere.
Edit: the breather in the fuel cap might also be blocked which creates a vacuum in the tank and restricts flow.
Martay
PostPosted: 10:21 - 18 Feb 2011    Post subject: Reply with quote
Is it points ignition? Sounds a bit like worn contacts?
Eat well, poo hard Very Happy
Drives: Cavalier 2.0 16v
Ichy
PostPosted: 11:01 - 18 Feb 2011    Post subject: Reply with quote
Or a dodgy condenser?
hellbound
PostPosted: 11:46 - 18 Feb 2011    Post subject: Reply with quote
rob yarrr wrote:
quite a few bikes i've ridden do this on start up,have the choke on for about 5 mins of riding and then it should be fine
it does it regardless of distane, it has done it after 30 minutes of motorway, or ten minutes down the road.
electonic ignition so no points etc
no fuel filter as the carb is too lose to the tap to fit one in
cb1rocket
PostPosted: 13:51 - 18 Feb 2011    Post subject: Reply with quote
fuel tank vents blocked possibly, next time it looses power open the filler cap and ride to see if it cures it
hellbound
PostPosted: 17:02 - 18 Feb 2011    Post subject: Reply with quote
I have done this too...had the same problem on the c90, cured it on that...not this time though
cb1rocket
PostPosted: 17:31 - 18 Feb 2011    Post subject: Reply with quote
Is the GN250 a CDI ignition? I think it is, but not sure as I don't have the haynes. If so unlikely to be ignition related.
How did you clean the carb? Thats the bit I want to know. Did you actually take out the jets and clean them?
Also possible water in fuel tank
fiery tupp
PostPosted: 17:33 - 18 Feb 2011    Post subject: Reply with quote
Float hight adjustment too high , getting starved of fuel occasionally ? Neutral
If you can't fix it with a hammer , use your head .
HD
PostPosted: 17:42 - 18 Feb 2011    Post subject: Reply with quote
When my carb rubber split it made the bike tick over excessively high. Well not just tick over but rev everywhere really high.
hellbound
PostPosted: 20:54 - 18 Feb 2011    Post subject: Reply with quote
it is CDI
Cleaned carb with clean petrol and clean rags, cleaned jets by taking them out, didn't adjust float at all I was not sure if it will make it worse
cb1rocket
PostPosted: 21:09 - 18 Feb 2011    Post subject: Reply with quote
check for air leaks, also the float being set too low is another possibilty as been said
Since you mentioned the bike idle fine, it could well be the floats.
Whats the history on the bike? Has it recently started doing this? Or did you buy it like that? If not have you done whatever xxxx miles without problems?
hellbound
PostPosted: 22:55 - 18 Feb 2011    Post subject: Reply with quote
It started doing it about 6 months ago, I do about 300 miles a week to and from work.
I also have to switch the fuel tap off or it stinks of fuel after ten minutes.
cb1rocket
PostPosted: 22:58 - 18 Feb 2011    Post subject: Reply with quote
ahhhh, you have a float valve/float issue. Its simple as the carb is flooding itself with so much fuel that it starts to smell.
Get hold of another carb if you can, or strip the carb again and REPLACE the float needle and adjust the float height according to the haynes.
It def a carb issue. Maybe you should of left it alone! Wink
cb1rocket
PostPosted: 23:06 - 18 Feb 2011    Post subject: Reply with quote
had a look and found this
https://cgi.ebay.co.uk/suzuki-gn250-carburetor-gn-250-carb-/150419103430?pt=UK_Motorcycle_Parts&hash=item2305ad5ec6
didn't even know it was CV type carb! Did you even disassemble the CV/ diaphragm? Its quite easily to split/damage the diaphragm rubber and if so the vacuum will be lost, and the lost of constant velocity air. These carbs are quite delicate.
Anyhow still cheaper to try the new float needle route first, if not its time for a new/different carb.
Ichy
PostPosted: 23:13 - 18 Feb 2011    Post subject: Reply with quote
Might have been a good idea to mention that in the first post.
You should check the needle, valve seat and floats. If you didn't remove the cap off the carb then just leave it alone, most damaged diaphragms I've seen have been caused by someone poking around.
The last post was made 15 years, 139 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.24 - MySQL Queries: 13 - Page Size: 104.75 Kb
