Project KTMito
steven_191
PostPosted: 11:44 - 19 Feb 2011    Post subject: Project KTMito Reply with quote
this is carrying on from a thread that started in the workshop section.
So the basic idea of this project was to make the Mito faster. i didnt want to increase the weight while doing so so ive been looking around for a good single to replace the standard engine.
i settled for a KTM LC4 640 4stroke. 55Hp and 45Lbt/Ft of torque (i think). thats almost double the standard Mito power. i saw one on ebay and decided ill have it. the sprocket is on the other side though so i also bought a complete aprilia rs125 front and rear end. and with no measuring the engine went into the frame and swing arm and all fit lovely. now its a case of getting everything to fit and mount and work.
my problems are
-carb hit the top crossmember
-rear shock isnt going to fit without some proper modifications
-general stuff like wiring and pipework
-new exhuast
from the following pictures you will be able to see what im talking about now. im thinking of keeping the rear linkage set up but it means im probably going to have to move both frame crossmembers, which at the same time will give me room for the carb, then fabricate the linkage parts and get it in the right place to mount the sock.
theres an issue with the swing arm as it hits part of the frame as you will see in on of the pictures. bear in mind that the swing arm hasnt been measured up to get it centered but its near enough.
where it hits the frame the lowest part of the frame beneath the pivot is around 33cm from the ground. in the rest of the pictures with my block of wood suspension set up its 44cm off the ground. im not sure how much movement the bike should have at the minute. i think its sitting a bit high but i may be well within my limits to have a good set up depending of if the angle of the swing arm makes much difference. im not an expert of the set up of angle and suspension so i really dont know.
the front end is around 4-5cm higher than the standard Mito so that can come down and will make a bit of difference but as i say, ill need some expert input on that.
ill probably be getting myself a rear shock from Hagon so ill will have all the info i need to get the rear end and linkage mounts in the right place, then its just a case of getting the shock set up.
so anyway thats my main problem but while the top crossmember is moved it'll solve the carb problem too. ill just need to consider the air box, volume, position, intake pipe length etc to make sure i keep that close to standard because im fairly sure changing the intake too much might affect the set up of the carb. but ill look into that.
pictures!!!!
steven_191
PostPosted: 11:48 - 19 Feb 2011    Post subject: Reply with quote
few more pictures
as you can see theres a fair amount of difference between the swing arm being high and low but also the angle when its at full 'compression' and hitting the frame. still and steeper angle than standard and it wont go any lower.
steven_191
PostPosted: 11:57 - 19 Feb 2011    Post subject: Reply with quote
you can see from the picture looking straight down from above the swing arm linkage mount is out of view. and the position of the crossmembers on the frame arent positioned ideally for it. the Mito shock lays at alot more of a horizontal angle but the aprilia doesnt.
if i moved the bottom crossmember lower and forward closer to the engine then i can mount a linkage between the bottom of the swing arm and the crossmember then move the top one down and back then the shock can mount upright. it sound like it will work. im not sure if moving the top crossmember back will mean it'll need more bracing across the top but i dont really remember seeing any bigger heavier bikes with bracing any further forward than the Mito. so i could well be fine. also the front engine mount will inevitable add some strength. and this frame is pretty meaty anyway
steven_191
PostPosted: 01:53 - 22 Feb 2011    Post subject: Reply with quote
heres my crudely drawn idea for the rear linkage. it means possibly adding a mounting point to the frame lower down but it'll look cool and should mean ill be able to use the mount on the swing arm that underneath out the way.
also considering if i can shave a bit of meat off the swing arm where its hitting the frame. i think this one is all cross braced underneath like honeycomb so should still have plenty of strength
Gazdaman
I did a trackday!!!
PostPosted: 20:16 - 20 Mar 2011    Post subject: Reply with quote
Great project, but odds on it gets abandoned before it gets finished.
Gaz
ruck bodgers
PostPosted: 01:59 - 21 Mar 2011    Post subject: Reply with quote
did a wrong post didnt know how to cancel this one see my username for details
i do not think therefore i am . give me a hammer
ruck bodgers
PostPosted: 02:22 - 21 Mar 2011    Post subject: Reply with quote
any chance u could make an adapter to fit inbetween the carb and header to shift it past where its making contact out of a chunk of old carbon car header or something or maybe some rubber hosing might lead to some tuning issues afterwards tho so maybe you are better off just sticking to your plan when i raised the rear end on my bike the chain was obstructed by the pivot point i made a chain roller out of a piece of angle and a skateboard wheel worked find but in comparasom to your frame mines anorexic it doesnt look like you have that as an option and i doubt you would want to do that anyway on a race bike aye thats sure is a strong looking frame you have there im not familiar with these bikes or there parts so i cant offer much help im afraid good luck with it tho man Thumbs Up
Shreddie
PostPosted: 05:38 - 21 Mar 2011    Post subject: Reply with quote
Interesting project, I hope you pull it off!
Is this the longest sentence in history?! Laughing
PostPosted: 12:00 - 21 Mar 2011    Post subject: Reply with quote
Moving the carb further away will bugger up performance I think.
Currently Steve is waiting on a CBR600 swingarm to arrive as he decided the RS125 one was too difficult to mount the rear suspension.
ruck bodgers
PostPosted: 17:34 - 21 Mar 2011    Post subject: Reply with quote
[/quote]
Is this the longest sentence in history?! Laughing[/quote]
haha ye sorry about that officer i dont like to come to a full stop
Damon
PostPosted: 18:31 - 21 Mar 2011    Post subject: Reply with quote
Doesn't the cbr600 run the chain on the left side? Confused
PostPosted: 20:46 - 21 Mar 2011    Post subject: Reply with quote
He reckons it will work... Mr. Green
Damon
PostPosted: 23:09 - 21 Mar 2011    Post subject: Reply with quote
https://www.gogaminggiant.com/wp-content/uploads/2010/07/facepalm.jpg
steven_191
PostPosted: 19:52 - 22 Mar 2011    Post subject: Reply with quote
Got the swing arm. Here's the measurements
Swing overall width 230mm
Swing internal 118mm
Swing length 575-600mm
Rear wheel width 212
258mm
157mm
520-545mm
254mm
As you can see the width is quite wide and the interal width. But I can have the width taken down and make some appropriate sized tube to replace what's been taken off inside. This should put some strength back in but I'm not sure it'll even be needed.
Also its a bit shorter which will affect the handling/stability but I'll wait and see.
Yeah the chain is on the wrong side but if it don't work I'll flip it over and get a new shook mount welded on. Easy.
So yeah this could definitely work. The other option is to go for the previous model which if I remember is a very close match.
steven_191
PostPosted: 19:54 - 22 Mar 2011    Post subject: Reply with quote
Sorry that's the original arm measurements on the first bit and the new one underneath
steven_191
PostPosted: 19:58 - 22 Mar 2011    Post subject: Reply with quote
Also to stupidgit
Im pretty sure the carb has the be close to the engine. Either way I want to change the least amount possible so of I move the brace all I will change is the airbox and intake pipe. I'm thinking of doing an airbox from carbon fibre. Gonna look into these CF kits.
And the rear shock mount. If I go with this arm it will most likely be linked from swing arm to frame. No linkage.
Gazdaman
I did a trackday!!!
PostPosted: 21:16 - 22 Mar 2011    Post subject: Reply with quote
So it's too short, too wide, the chain's on the wrong side, and if you flip it upside down the shock mount's in the wrong place...
It sounds awesome.
Gaz
PostPosted: 22:18 - 22 Mar 2011    Post subject: Reply with quote
It sounds awesome.
Gaz
Chances are the majority of swing arms won't have the shock mount in the right place. It's all part of being a project.
Gazdaman
I did a trackday!!!
PostPosted: 22:22 - 22 Mar 2011    Post subject: Reply with quote
I'm well aware of that, but at least with the RS125 one it's a start! And from the photos it even lined up!
Gaz
PostPosted: 22:27 - 22 Mar 2011    Post subject: Reply with quote
Gaz
The Mito was linkage type suspension the RS bolted straight from the frame to swing-arm. There wasn't enough room to run a linkage or to mount the shock directly on the swing-arm.
Gazdaman
I did a trackday!!!
PostPosted: 22:59 - 22 Mar 2011    Post subject: Reply with quote
Fair enough, I didn't realise that.
As you were.
Gaz
steven_191
PostPosted: 00:54 - 23 Mar 2011    Post subject: Reply with quote
well the main problem was that the swing arm was so high that at full 'compression' when the arm and frame were in contact the bike was still about 5-6inches too high. i did cut a lump out of the arm with the idea of shaping it around the frame so it could drop but i wouldve had to remove most of the metal.
the pictures show the angle. thought i wrote it too....
steven_191
PostPosted: 01:02 - 23 Mar 2011    Post subject: Reply with quote
cbr 600 swing arm
the plan is, get it to fit, make sure its strong enough, probably flip it over, cut the mounts and bits off that i dont need and get a new shock mount sorted.
Damon
PostPosted: 09:16 - 23 Mar 2011    Post subject: Reply with quote
Will be interested to see how this goes Thumbs Up
steven_191
PostPosted: 18:19 - 24 Mar 2011    Post subject: Reply with quote
just a few parts off ebay for spares and oil changes.
kickstart that retails at £86
2 sets of oil filters
water pump and gaskets
thermostat and housing
a brand new drive sprocket
and a peg whatsit
not bad for £20 Laughing
The last post was made 15 years, 167 days ago. Instead of replying here, would creating a new thread be more useful?
Goto page 1, 2, 3, 4  Next
Page 1 of 4
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.43 - MySQL Queries: 13 - Page Size: 132.11 Kb
