bitch of rear wheel bearings!
kingsknight
PostPosted: 19:37 - 19 Feb 2011    Post subject: bitch of rear wheel bearings! Reply with quote
Brought a set of new wheel bearings for my XR for both wheels. Is there a special way you are mean to remove the old bearings as I cannot remove them for the life of me.
Hammer and force doesn't seem to be doing the job!
Any advice? Thanks guys
TS50 (sold) NS125F (sold) NSR125R-K (write off after 2 crashes) CG125 (nicked) XR125L-3 (Sold )-: ) DR125SM '11 (sold yay) XL125V '12 (In love with this bike) XT600E '04 (fun on the dirt)
PostPosted: 20:03 - 19 Feb 2011    Post subject: Reply with quote
Clicky
PostPosted: 20:29 - 19 Feb 2011    Post subject: Reply with quote
Some bikes have a circlip holding them in. If there is one, it's not always obvious and you'll wear out your hammer before you get them out unless you remove it.
weasley
PostPosted: 23:38 - 19 Feb 2011    Post subject: Reply with quote
I have spent the better part of today stripping the wheel bearings and steering head bearings out of my KDX, so I sympathise! On mine, there was a circlip on one side of each wheel. There was also a tube running between the bearings, inside the hub, in which the axle runs - this, at first, was so closely fitted to each bearing that the whole lot looked like one unit, however with a bit of persuasion the tube could be moved enough to get a drift onto the bearing. Once it had had a couple of taps the tube then fell loose (still inside the hub) giving full access to the inside edge of the bearing to get a decent drift on it.
They do take more smacking than feels right, just make sure to work around the bearing.
kingsknight
PostPosted: 02:02 - 20 Feb 2011    Post subject: Reply with quote
thanks guys, I'll have another go on Monday. I think it could be just needing some heat to get them out like in that video. I don't think this bike has a circlip keeping them in.
tahrey
PostPosted: 17:40 - 17 Mar 2011    Post subject: Reply with quote
ms51ves3 wrote:
Is it "just" as simple as that, then? Except maybe dragging a circlip or two out if my wheel happens to have them?
I mean it looks like a job I actually have the tools for, for once. Hammer? check. Screwdriver? yep. Medium-large socket bit? oh yeah. Socket extension? Loads of em. Bits of wood? Swimming in the things. Blowtorch? No... but I know someone I can borrow one from for a couple hours, and have done so before.
(It's relevant because being able to change bearings if needs be is going to be the decider on me buying a particular ebay wheel, or a different one ... one is more expensive and has known-good bearings, the other is a lot cheaper (far more so than a bearing kit) and may well be alright but the seller can't guarantee it. Which really means "yeah, they're probably knackered".)
The Artist
PostPosted: 17:41 - 17 Mar 2011    Post subject: Reply with quote
You could try taking the bearing out and taking it to a bearing specialist.
LeanIt
PostPosted: 19:54 - 17 Mar 2011    Post subject: Reply with quote
Make sure you're hitting the bearing and not the wheel, on some bikes it's not immediately obvious, but they do need a good whack moving around the bearing hitting opposite sides as you go.
Put your new bearings in the freezer the night before you fit them and they'll drop straight in without needing to use a drift Thumbs Up
Life is like a shit sandwich. The more bread you have, the less shit you eat.
The last post was made 15 years, 180 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.42 - MySQL Queries: 13 - Page Size: 61.11 Kb
