| sweating bullets |
 sweating bullets L Plate Warrior
| Rogerborg |
 Rogerborg nimbA
 Posted: 17:01 - 20 Feb 2011 Post subject: Re: gpz 500s side stand switch |
Well, you've only got two choices. Take it off and see if the bike runs. If so, job done. If not, join the wires. Job done either way.
It's not part of the MOT or (AFAICR) any C&U Regulations. I removed the switch on my 125 from new before I ever rode it, as they're notorious for failing on that model.
The thing is, they're very simple switches. If you want to retain yours, you should be able to strip it down and give it a good clean up yourself. A basic £5 multimeter will be enough to find any point of failure. ____________________ Biking is 1/20th as dangerous as horse riding.
| Scotsman37 |
 Scotsman37 World Chat Champion
 Posted: 17:41 - 20 Feb 2011 Post subject: |
If you're happy you can trust yourself to:
a) Not ride away with the stand down.
and
b) Not press the starter while in gear with the clutch out.
Pull the block connector off the clutch switch. Insert a bit of bent paperclip between the two terminals that do not have a light green wire attached. Reconnect the block connector.
This will bypass the entire safety interlock system. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Rogerborg |
 Rogerborg nimbA
 Posted: 19:48 - 20 Feb 2011 Post subject: |
| stinkwheel wrote: | If you're happy you can trust yourself to:
and
b) Not press the starter while in gear with the clutch out. |
Much as the Pilgrims must have done.
Fair point, it might depend on what you're used to. I made a conscious decision to ditch the switch on my first bike so that I'd never have a chance to get used to relying on it. I've never pulled away with the stand down, and always assume that the bike is in gear, i.e. pull in the clutch before starting, then let it out carefully. I'd rather have good habits plus an occasional safety net than to rely on the net being there. ____________________ Biking is 1/20th as dangerous as horse riding.
| sweating bullets |
The last post was made 15 years, 134 days ago. Instead of replying here, would creating a new thread be more useful? |
