Headlight ajustment failure..
skatefreak
PostPosted: 23:03 - 20 Feb 2011    Post subject: Headlight ajustment failure.. Reply with quote
Hey,
So trying to ajust the headlights an as i turn the bolts they headlights drop down a little but then it clicks and they go back up...
They dont make it down far enough to be safe (dont quiet light the road) and are likely to blind oncomming traffic...
The only headlight i have found on flea bay is 150 bucks (are they having a laugh ?!?).
Whats the chances i could get this thing open and have a look see inside?
Any thoughts would be much appreciated.
Best regards
-Jvr
Noxious89123
PostPosted: 23:56 - 20 Feb 2011    Post subject: Reply with quote
How are you judging that it's aimed too high? The headlight on both bikes I've had seemed to be aimed quite high, but lit the road quite well, and has always passed it's MOT. They have a clever machine to test the headlight beam aim + pattern.
skatefreak
PostPosted: 01:25 - 21 Feb 2011    Post subject: Reply with quote
3.8m away from a flat wall,
lights should not go higher than the headlight on the bike (what i'v read in a number of places online).
It's not just that it's to high (their not exactly very bright) but they dont iluminate the ground (like they used to)...
Looks like i'm going to have to try get the unit open Neutral
They do move, just not far enough down.
Best regards
-Jvr
iooi
PostPosted: 10:35 - 21 Feb 2011    Post subject: Re: Headlight ajustment failure.. Reply with quote
skatefreak wrote:
Hey,
So trying to adjust the headlights an as i turn the bolts they headlights drop down a little but then it clicks and they go back up...
-Jvr
Then you have reached the end of the adjustment. That would point to something else being the problem and not the light.
Maybe a broken/bent bracket somewhere.
Maybe the bulb is loose/not fixed properly in its mounting.
Opening the unit would be the last thing I would do and I would doub't that it solve the issue.
skatefreak
PostPosted: 11:06 - 21 Feb 2011    Post subject: Reply with quote
Hey,
cheers for the input, very usefull!
I shall get onto it again this arvo.
Best regards.
-Jvr
PostPosted: 11:15 - 21 Feb 2011    Post subject: Reply with quote
I agree with iooi. However in addition is the headlight standard or have you fitted an HID kit?
With a lot of headlights it is very easy to have a bulb not seated quite right and land up with it pointing at the stars.
The last post was made 15 years, 138 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 2.8 - MySQL Queries: 13 - Page Size: 50.1 Kb
