 ..... Quote Me Happy
| virus |
 virus World Chat Champion
 Posted: 12:19 - 21 Feb 2011 Post subject: |
m8 has a 1.25 mm pitch gap, so you take 1.25 from 8 to get6.8 or thereabouts as you have done, drill carefully with a hand drill, then tap away with your m8 being careful not to get that in on an angle, you want to keep the tap square to the hole at all times otherwise you get a nasty thread with either a bolt sticking out at a jaunty angle, or it pinches on one side tighter than the other.
Its no massive job to do really, note taps come in 3s, start with the one with the finest point, and if the hole doesnt go all the way through then finish with the one with the squarest end to get thread right to the bottom.
Cheers
John ____________________ own: 81 xs1100g...
stinkwheel Well I just had my hands up a pigs fanny. Which makes your concerns pale into insignificance. |
| Suntan Sid |
| Bezzer |
 Bezzer World Chat Champion
| tatters |
 tatters Exxon Valdez
 Posted: 12:59 - 21 Feb 2011 Post subject: |
| Hetzer wrote: | | Joe wrote: |
Does the tap need any cutting fluid? |
Bit of WD40, unless you're tapping under power. And I use WD40 for that too, coz I is badass. |
Dont forget to back the tap out every other 2nd turn to clear away the swarf.
I,ve got the right drill bit and tap as well as a proper tapping wrench and cutting fluid if you want to borrow them.
I would,nt try and use the tap in a drill if l was you as it will most likey snap leaving a nice chuck of hardened steel in the hole. ____________________ Past:NRG50,AF1125(x2),NSR125RR,ZZR250,CX500,VFR400,KR1S,ZZR600(x2),CB400N,YZF1000(x2),KH125,Z200,FX400R,CBR954RR(x2)GPZ500S,GT550,VFR750F(x2),RD350N,XR650R,CBR600F,CB250,KDX250,YZF750R,CRM250,400EXC,KLR650,TTR600RE,DR350S,R100GSPD,RGV250,VMAX1200,DL650,KZ750 Present:G650XC,C12,CRF450X,1190ADV |
| MarJay |
 MarJay But it's British!
 Posted: 14:23 - 21 Feb 2011 Post subject: |
The No1 cause of snapping a tap is not starting it in line with the drilled hole. Next is using a blunt tap. Get it straight and that's half the job bone.
For tapping ally I use WD40 for steel I use normal engine oil in my oilcan. I have a can of rocol tapping lube which I save for important jobs and stainless. ____________________ a.k.a 'Geri'
 Posted: 14:44 - 21 Feb 2011 Post subject: |
| tatters wrote: | I,ve got the right drill bit and tap as well as a proper tapping wrench and cutting fluid if you want to borrow them.
Cheers, will probably take you up on that - I'll bring the chain tool if you want and you can ditch the split link?
| Hetzer wrote: | Gawd, I've realized how my post could have induced disaster. |
I don't need help inducing disaster
| MarJay wrote: | and I do 3/4 of a turn, then back off 1/4 of a turn each time. Takes a long time, but does the job. |
Cheers, slowly does it then.
| Pete. wrote: | The No1 cause of snapping a tap is not starting it in line with the drilled hole. Next is using a blunt tap. Get it straight and that's half the job bone. |
Stupid question, is there anyway to make sure it's going in straight other than by eye? |
| virus |
 Posted: 21:20 - 21 Feb 2011 Post subject: |
Could you not just go all the way through with a good quality nut and bolt?
Be a hell of a lot easier to get out again if you bend it. Fitting a bash plate implying it stands a good chance of getting bashed at some point. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Vincent |
 Vincent Banned
The last post was made 14 years, 346 days ago. Instead of replying here, would creating a new thread be more useful? |
