| Nemo |
 Nemo Could Be A Chat Bot
| kentpunkster |
 kentpunkster Two Stroke Sniffer
 Posted: 12:38 - 21 Feb 2011 Post subject: |
Gentle heat and put a socket on nut and give a few taps with a hammer...  |
| Kickstart |
 Kickstart The Oracle
| Scotsman37 |
 Scotsman37 World Chat Champion
| chris-red |
| Nemo |
 Posted: 13:39 - 21 Feb 2011 Post subject: |
I've only just got the bike, and I'm assuming it works in the same manner as all the others, lefty loosey righty tighty....
The sump plug doesn't face down like some bike's, it faces outwards on the left hand side, which makes it a little easier, but not too much. ____________________ Previously owned: Kawasaki KH125, Suzuki GP125, Suzuki GX 125, Honda CB125 TDC '83, Honda ntv 600, Kawasaki ER5, Kawasaki ZZR600, Aprilia RSV 1000 Mille
Now own: Ducati 848 evo |
| Kickstart |
| Nemo |
 Posted: 14:21 - 21 Feb 2011 Post subject: |
Hmmm, might get a new one then, even if it turns out okay a new one won't do any harm, and will make it easier in the future.
Cheers guys  ____________________ Previously owned: Kawasaki KH125, Suzuki GP125, Suzuki GX 125, Honda CB125 TDC '83, Honda ntv 600, Kawasaki ER5, Kawasaki ZZR600, Aprilia RSV 1000 Mille
| chris-red |
| Nemo |
| Pete. |
 Pete. Super Spammer
 Posted: 14:30 - 21 Feb 2011 Post subject: |
It's actually probably just bloody tight. What size socket does it use? ____________________ a.k.a 'Geri'
| Nemo |
| chris-red |
| Nemo |
| chris-red |
| Pete. |
 Pete. Super Spammer
| kramdra |
 kramdra World Chat Champion
 Posted: 16:40 - 21 Feb 2011 Post subject: |
Waterpump plyers. They are very good on rounded bolts, but wont move everything. Example:
https://www.screwfix.com/cats/A335533/Hand-Tools/Pliers-Cutters/Water-Pump-Pliers
OR use a cold chisel and hammer.
Hit it in the direction you want to turn. This should move anything. If it doesnt work, you need a bigger hammer
| Pete. |
 Pete. Super Spammer
| chris-red |
 Posted: 17:00 - 21 Feb 2011 Post subject: |
Mole grips would be better, but the best thing I have found for rounded bolts is the adjustable spring wrench I have (don't know there proper name) it grips on the bolt then as you turn it the grip gets tighter.
Aside from that the op hasn't mention anything about the bolt being rounded, just tight. ____________________ Well, you know what they say. If you want to save the world, you have to push a few old ladies down the stairs.
WANTED:- Fujinon (Fuji) M42 (Screw on) lenses, let me know if you have anything. |
| stinkwheel |
 Posted: 21:49 - 21 Feb 2011 Post subject: |
It's not outwith the realms of possability that someone has already stripped it or cross threaded it then put it back in with threadlock. Anything is possible on a bike of that age.
As such, some direct heat might not be a bad idea.
An air (or battery) impact wrench is an even better idea if you have access to one. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| jimspeed |
 jimspeed World Chat Champion
 Posted: 22:24 - 21 Feb 2011 Post subject: |
fair chance of it being already damaged if it is that tight, are there any other holes you could use to drain the oil, try warming the bike up nice and hot,
or use one of these of you can get it in anywhere
https://www.pelapumps.co.uk/
we use them at work and they are very good.
 ____________________ Hyosung cruise 125(passed test on, sold) Kawasaki el 252 (better than expected but sold on) Kawasaki GPZ500S first "big"bike.(sold) ZZR600 E5..Z750 2007,ER5, currently on a 2008 Enfield bullet electra x and loving it..
,"Alpha-9: Is there any correlation between dyno rod and dyno kits?" |
| whitedevil |
 whitedevil World Chat Champion
| chris-red |
| ClockworkJesu... |
 ClockworkJesu... Nitrous Nuisance
 Posted: 00:01 - 22 Feb 2011 Post subject: |
My sump-plug was damned tight, too.
Got a socket on it with a nice long breaker-bar over the ratchet and just applied smooth, gentle force.
It'll go "BANG" and come off. Nothing survives the breaker-bar.
Thats my two-cents, anyway.
Just remember, don't do it back up murder tight.  |
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 01:05 - 22 Feb 2011 Post subject: |
Sump plug on Left-Hand-Side under the mag-cover, you are trying to undo the right bolt, aren't you?
But, first off get new copper compression washer, before you start, if you haven't already. If it's that tight probably squashed to heck and wont seal when you refit.
Its awkward to get at, and with limited clerance, you are probably going to foul the casing or floor to get a decent swing on a long bar.
If its tight, six sided socket, beg, borrow, steal.... double hex or wall-drive only grip on points, so you are putting more pressure on the metal. Wall drive are 'OK'. but straight six side is the best defence its an all-round close fit on the hex.
SHORT extension to get breaker past cases, and you want to have the handle pointing at rear wheel to turn anti-clockwise, lifting from the floor, to apply even force in controlled manner.
Its a light bike, so you may want to get some-one to sit on it and hold it down so you can get more purchase on it.
AND you want to support the head of the breaker so you are ONLY turning, not bending the socket & extension on the head.
Thats basic technique.
Cases are alloy, plug/bolt is steel.
This MAY not be brutal mechanics or stripped or crossed threads, could simply be that previouse owner followed advice to warm engine before draining old oil..... in which case, hot alloy case, would expand more than steel sump plug, come out easy..... small steel plug then cools more than big chunk of alloy..... oil finished coming out, owner puts plug back in.
Its loose so he does it pretty tight, THEN engine cools down, shrinking round the plug!
So, get motor good and hot, then apply controlled force.
Try impact driver, if still stiff.
If no effect..... give up.
Are you gong to do the strainer?
If so, messy, BUT, leave plug in, crack primary case off, let oil come out that side.
May be able to inspect plug from inside for damage, ans with long taper punch, lightly tap on the end to help rattle it a little loose.
Alternatively, & safer.....
ride it round to a garage with air tools, new plug & washer & small bottle of oil in pocket and ask them to loosen it off with air impact driver.... spare plug oil & washer for if they take it ALL the way out, rather than just loose! ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
The last post was made 14 years, 336 days ago. Instead of replying here, would creating a new thread be more useful? |
