honda c90 wont go into gear
Alex_
PostPosted: 22:18 - 20 Feb 2011    Post subject: honda c90 wont go into gear Reply with quote
hi i have a c90 engine i purchased together with another same engine, when i try put it into a gear the lever wont move whatsoever, unfortunately it never came with a kickstart lever so cant try kick it over
worse case it being seized but is there anything else worth checking over?
cheers
fiery tupp
PostPosted: 22:25 - 20 Feb 2011    Post subject: Reply with quote
You should be able to take the dynamo cover off & turn it over with a socket to see if it is free & maybe work the gears doing so Neutral
If you can't fix it with a hammer , use your head .
dragstaar
PostPosted: 10:32 - 21 Feb 2011    Post subject: Reply with quote
is the gear lever clear? If its a bent lever you might find that its bent against something
hellbound
PostPosted: 12:41 - 21 Feb 2011    Post subject: Reply with quote
I have a whole C90 if it helps...
they can be a bitch to put in and out of gear without the engine running due to the CV clutch mechanism not doing anything when it isn't spinning.
May you always see the road rising up to meet you and your enemies defeated in the mirror behind.
Alex_
PostPosted: 12:46 - 21 Feb 2011    Post subject: Reply with quote
god knows how long its been sitting, just the other goes it gear ok. im not looking at it today as its snowing like hell in scotland
ill try it with the socket first if it turns then ill take it from there
cheers Smile
Alex_
PostPosted: 16:19 - 21 Feb 2011    Post subject: Reply with quote
decided to try it, the sprocket was a little stiff but after a few spins it moves good now
as for the engine this spis good as well, but still no gears?
looks like i'll have to take the clutch casing off and have a poke about to see if anythings bent etc
thanks
garth
PostPosted: 18:06 - 21 Feb 2011    Post subject: Reply with quote
There's a spacer under the RHS cover, that looks the same either way. It isn't. If you put it in backwards you get no gears. I know this because I've done it twice in a row and then got very stroppy.
The last post was made 14 years, 343 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.04 Sec - Server Load: 0.22 - MySQL Queries: 13 - Page Size: 50.58 Kb
