| steven_191 |
 steven_191 Nearly there...
| Kickstart |
 Kickstart The Oracle
| hmmmnz |
 hmmmnz Super Spammer
| Kickstart |
| steven_191 |
| stinkwheel |
 Posted: 01:58 - 23 Feb 2011 Post subject: |
I've seen it done with an SU carb.
But the person who did it is one of those special people who shit like that seems to work for.
My last MZ had the best of both worlds. It had a 2-1 inlet manifold with a small slide carb and a large CV carb with no pilot circuit. It had a moderately complex throttle linkage that opened the slide carb initially then picked up the CV at 2/3 throttle position.
I would suggest that the effect you are describing is almost purely theoretical though. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Kickstart |
| steven_191 |
| Kickstart |
 Posted: 09:58 - 25 Feb 2011 Post subject: |
Yep, with a slide carb when you whack the throttle open wide at low speed the pressure drop through the carb becomes tiny, and it becomes lousy at drawing fuel out of the float bowl.
You can play around with the holes but it shouldn't affect the throttle response as the slide on a CV carb isn't the throttle. The slide is there to control the mixture. Enlarging the holes will change the speed the slide moves, probably making it move faster and having the mixture richer when you crack open the throttle. The strength of the spring determines how far it opens.
The last post was made 14 years, 355 days ago. Instead of replying here, would creating a new thread be more useful? |
