YAMAHA DT LC TRAILS BIKE REV PROBLEMS CAN ANYBOD HELP
jasonDT
PostPosted: 19:58 - 22 Feb 2011    Post subject: YAMAHA DT LC TRAILS BIKE REV PROBLEMS CAN ANYBOD HELP Reply with quote
hi to you all
can anybody help me ive just bought myself a YAMAHA DT LC year 1986 in great condition for the year but ive got a problem with the engine i can get the rev counter to stay at 1500rpm but when i rev the engine it revs ok but wont return back to 1500rpm it stays at 3000rpm until i turn the screw on the carb then the revs go down again ive got to do this everytime i rev the bike ive been told it could be the carb as ive been told its to big for the engine its for a 250cc yamaha but im not sure the car is a mic the engine starts well but this problem is bugging me can anybody please help me cheers jay
hi to all and thanks for your help
yen_powell
PostPosted: 20:20 - 22 Feb 2011    Post subject: Reply with quote
When I've seen this behaviour before it's been because the rubber manifold between the carb and engine was perished or not sealing properly, leading to the engine revving sometimes on it's own as extra air gets drawn in.
If it's perished you can check by spraying WD40 onto and around the rubber when the engines running and seeing if the revs rise as it's drawn in.
XT1200Z and a DR350 in bits
fiery tupp
PostPosted: 20:23 - 22 Feb 2011    Post subject: Reply with quote
It could be just the cable needing oiling , or renewing ?
If you can't fix it with a hammer , use your head .
jasonDT
PostPosted: 21:16 - 22 Feb 2011    Post subject: Reply with quote
ive looked at all pipes and they look fine i will try the wd40 trick though if its not this dose it seem mayor or something silly i bought the bike with two spare engines but dont no if they run i was going to try another engine someone said that the engine needs a compleat strip down i havent a clue
jasonDT
PostPosted: 21:21 - 22 Feb 2011    Post subject: Reply with quote
hi ive tryed all cables and they seem all ok
HD
PostPosted: 22:50 - 22 Feb 2011    Post subject: Reply with quote
Maybe something is sticking inside the carb? And when you turn the screw it jumps back down? Throttle slide or needle?
Strip down your carb, clean it up and put it back in. Failing that buy a new carb for the correct engine Laughing
jasonDT
PostPosted: 19:17 - 23 Feb 2011    Post subject: Reply with quote
hi my son came up today and he done the fairy liquid test he sprayed all the pipes to see if any air was being sucked in but nothing he sprayed the other side of the engine why running and the bottom of the head was sucking air in, as it sucked the water he sprayed on it the engine died son took head of re newed head gasket when he done the work we went in for a cuppa came back out to the bike and tryed to start it it took quite a few kicks but started in the end and reving at 1500revs carb still needs setting up but lest its not drawing air in sounds great now we did find that its got a bigger head and piston in it so its been played with before fingers crossed its going to be ok now thank you for you help
jay
jasonDT
PostPosted: 19:19 - 23 Feb 2011    Post subject: Re: YAMAHA DT LC TRAILS BIKE REV PROBLEMS CAN ANYBOD HELP Reply with quote
jasonDT wrote:
hi to you all
jay
thanks for the help you gave me but my son done this as follows.
The last post was made 14 years, 335 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.39 - MySQL Queries: 13 - Page Size: 58.17 Kb
