Heat
PostPosted: 15:15 - 23 Feb 2011    Post subject: Heat Reply with quote
What do you use in the garage to apply heat to something?
I'm looking for something cheap, I was thinking about one of those cooking blow torches.
Paxovasa
PostPosted: 15:18 - 23 Feb 2011    Post subject: Reply with quote
Oxyacetylene at my mates garage Razz
I have also used one of these:
https://www.tooled-up.com/ProdImage/GAZPT2000KIT.jpg
DrDonnyBrago
PostPosted: 15:38 - 23 Feb 2011    Post subject: Reply with quote
What do you want to apply heat to?
If for example you are trying to get studs out of a head for then a small cooking torch wont be up to it, the heat just gets sapped away too quickly by the aluminium of the head (been there done that Embarassed ). Haven't had much success with anything less than oxyacetylene on studs.
If you are trying to heat up very small areas, do heat shrinking etc then a wee butane cooking torch might be ok. A propane torch will be better (DIY blowtorches etc) for stuck/seized stuff and used in conjunction with freeze and release spray you would have more luck. For general wide area heating at highish temperatures an electric heat gun might be more suitable.
fiery tupp
PostPosted: 16:02 - 23 Feb 2011    Post subject: Reply with quote
I just call the mother in law Neutral
If you can't fix it with a hammer , use your head .
The last post was made 14 years, 327 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.34 - MySQL Queries: 13 - Page Size: 39.17 Kb
