| blinky |
 blinky Nitrous Nuisance
 Posted: 18:46 - 22 Feb 2011 Post subject: *bleed kit advice please* |
wasnt sure if i should post this in here or general bike chat but.....
working on my brakes last night, quite tired, and i let one of the pistons slip out for a sec, thus geting squirted with br fluid in the face ...levers dead... so due a bleed....
im hunting for a cheap brake bleed kit asap. dont want to pay silly money for one but how much should i be looking to pay? wherebouts? or could i make one?
local car garage tomorrow, under a fiver possible?
mind, this is my first time ever il be bleeding brakes, so any ideas mucho appreciato!  ____________________ Better to ask forgiveness than permission!
Oh i miss my first love, the lovely lil CG!
Rouser 135 2012... Enfield 25... Hornet 600 2002... CG125 2000 |
| Scotsman37 |
 Scotsman37 World Chat Champion
| stirlinggaz |
 stirlinggaz World Chat Champion
| Oldie |
 Oldie Brolly Dolly
| fiery tupp |
 fiery tupp Trackday Trickster
| neatbik |
 neatbik World Chat Champion
| blinky |
 Posted: 18:23 - 23 Feb 2011 Post subject: |
a tenner and having to wait a week isnt really all that great in my books. i'll check out the fishing shop tomorrow.
cheers  ____________________ Better to ask forgiveness than permission!
| jay12329 |
 jay12329 Dr. Evil
 Posted: 18:35 - 23 Feb 2011 Post subject: |
| cb1rocket |
 cb1rocket World Chat Champion
| The Tot |
 The Tot World Chat Champion
 Posted: 20:27 - 23 Feb 2011 Post subject: |
I pilfered the ingredients for my brake bleed kit from work.
It's pretty much a 60 ml syringe with araldite at the end and fitted with various sections of flexible transparent pipe.
I used it to bleed the system through. Beauty of it was that all I had to do was keep the reservoir topped up and see clean fluid being pulled through.
I can technically use it to reverse bleed the system, but my lever is at mid span and it's ROCK hard!
Be resourceful. Ideally you want a big syringe so that you don't have to continuously keep opening and closing the nipple.
So ingredients.. Pharmacy for a 60ml syringe - probably 2 quid. Relevant section of 5mm tubing... don't know, I suppose you can just cut a section off from somewhere and nick it?
https://a7.sphotos.ak.fbcdn.net/hphotos-ak-snc6/181994_10150154910450712_500990711_8148841_6694365_n.jpg ____________________ The Tot 2019 Z1000SX - 2007 R1
Never argue with autism |
| skatefreak |
 skatefreak World Chat Champion
| Scotsman37 |
| cb1rocket |
 Posted: 22:30 - 23 Feb 2011 Post subject: |
very good i must say, works like a charm, just reverse bleed as you normally would on a single but one at a time.
When the air is in the system it get push upwards and out, and sometimes into the other brake line of the other caliper. So when you do the other side, you just effectly push the air upwards and out of the system. Its easier to push air uppwards than downward!
Air is less dense than liquid  |
| blinky |
 Posted: 23:23 - 23 Feb 2011 Post subject: |
ah crud, so i have to do both calipers?
i was just trying to solve the problem of one sticking and squeeking.
| Scotsman37 |
| blinky |
| blinky |
 Posted: 23:46 - 23 Feb 2011 Post subject: |
...over a few hours?
how long should this take? surely no longer than an hour ish? ____________________ Better to ask forgiveness than permission!
| Scotsman37 |
| totalllama82 |
 totalllama82 Crazy Courier
| Scotsman37 |
| blinky |
| cb1rocket |
 Posted: 15:45 - 24 Feb 2011 Post subject: |
one lot of the bleeding tool does both calipers. If the system is totally empty, then bleed the fluid up from the caliper nipple.
1) setup syringe and suck in the brake oil, have a bucket of water nearby for emeergency, it eats paint!
2) open the reservoir cap, place rads around it.
3) open the nipple on the brake caliper side your working on, keep the other shut off/close.
4) stick tubing over the nipple and push syringe to release oil, if running low of oil in the syringe then close off the nipple while still pushing to prevent air getting in.
5) Repeat step 3 & 4 until fluid can just be seen coming through from the top.
Repeat step 3 - 4 for otherside.
Then squeeze lever until resistance can be felt.
Replace reservoir cap and clean up any spillage, then bungee the lever on over night - job done  |
| blinky |
 Posted: 22:26 - 24 Feb 2011 Post subject: |
heres one i made earlier....
...best i can do for now. wasnt a 100% successful, as theyre a bit spongey still, but a massive improvement than before, so its good for now!
i just opened and closed the sump to let the fluid out and kept topping up the reservoir til i got (i thought) all bubbles out.
couldnt get hold of a syringe yet, but will do soon for a future bleed
thanks again chaps ____________________ Better to ask forgiveness than permission!
| Scotsman37 |
| blinky |
 Posted: 23:44 - 24 Feb 2011 Post subject: |
nope, i'll get that when i get the syringe for next time. hopefully i'll get all the bubbles out next time, when i do it properly
i just opened anbd closed the nipple with my fingers, whilst squeezing the lever intermittently, untill the liquid was bubble-clear.
tried to do it by just pinching the tube inbetween lever squeezes, but it didnt work so effectively as at the actual nipple.
*oh and forgot to mention, i actually only did a few squeezes/bleeds on the other side, as i didnt see any bubbles at all. whether thats good or bad i dont know, but i had sucked a lot of fluid through on the right side caliper, so figured i'd sucked alot of the air out from the other (left) side?! and so left it as it was.
rode the bike to the shops earlier to see how the brakes felt, and ye, like i said, they are still a bit spongey, but still a massive improvement from before. thats my fault tho, as i guess i rushed it a bit  ____________________ Better to ask forgiveness than permission!
The last post was made 14 years, 348 days ago. Instead of replying here, would creating a new thread be more useful? |
