Anyone know Programming?
 Topic moved: from Random Banter to The Geek Zone by G (26 Feb 2011 - 12:42)
blurredman
PostPosted: 14:55 - 24 Feb 2011    Post subject: Anyone know Programming? Reply with quote
Nothing was asked here,
This thread does not exist.
It is a glitch in the Matrix.
angryjonny
PostPosted: 15:44 - 24 Feb 2011    Post subject: Reply with quote
No idea of Python (except the dead parrot sketch) so these are general "developer" type questions:
This is probably not the root of your problem, but surely the line "text_file.write(v)" is going to write the number of attempts into your file, not the IP address.
Also - don't you need to specify the path to your file, not just the filename - how does your app know where to put it?
Have you tried creating the file manually and seeing if anything gets appended to it - the file() function might be expecting the file to already exist.
I also have no idea if you're using the split function correctly - if so it works differently to how it does in VB.
Like I said - not a python programmer - just a once-upon-a-time software developer.
PostPosted: 15:46 - 24 Feb 2011    Post subject: Reply with quote
Can't help you with your problem, but I do see the irony of using Python to create a spam-blocking script Very Happy
https://www.youtube.com/watch?v=anwy2MPT5RE
ncrn
PostPosted: 15:58 - 24 Feb 2011    Post subject: Reply with quote
It looks like you are opening your text file within the for loop. This means every time you run through the loop you create a new file.
Try this instead;
Code:
text_file = file('blacklistips.txt', 'wt')
for ip in [k for k,v in ips.iteritems() if v >= 13]:
     text_file.write(v)
text_file.close()
Note the indentation, so that you close the file AFTER the for loop. Also I'm not seeing how v gets loaded with anything useful.
blurredman
PostPosted: 16:05 - 24 Feb 2011    Post subject: Reply with quote
Nothing I tells ye!
The999Kid
PostPosted: 21:46 - 25 Feb 2011    Post subject: Re: Anyone know Python? Reply with quote
https://images.icanhascheezburger.com/completestore/2008/11/18/128714980171785075.jpg
yuri2085
PostPosted: 21:49 - 25 Feb 2011    Post subject: Reply with quote
The problem with that sketch is that the first two items listed don't contain any spam.
blurredman
PostPosted: 23:59 - 25 Feb 2011    Post subject: Reply with quote
hehehe Laughing
Im-a-Ridah
PostPosted: 09:16 - 26 Feb 2011    Post subject: Reply with quote
I only do J2SE, C and Matlab Thumbs Up
Frost
PostPosted: 09:52 - 26 Feb 2011    Post subject: Reply with quote
I fucking hate Matlab. Every fucker uses it and it warps their perception od what is possible and how long it will take. They seem to think that because it's a single matlab command it's going to be equally easy to make run real time in C in a microcontroller or something. Worse still they'll call some complex function repeatedly to calculate something then when it runs like shit they say "Well it'll run more efficient in C". No It'll run more efficient if you actually code it properly!
I love Python as it's programming but without all the crap. C is nice for the mad speed Smile
ncrn
PostPosted: 11:04 - 26 Feb 2011    Post subject: Reply with quote
I think you need to pay for it, but you can use matlab to generate C code, which if you do some clever wrapping you can dump into a micro controller, and jobs done then. It won't be nearly as efficient as if you spent time considering it and coding it in C by hand, but its a lot quicker to prototype Very Happy.
I found with python its programming but awkwardly, the biggest pain I find is with arrays, I wish they behaved like C arrays it'd be so much easier for me to comprehend Laughing.
PostPosted: 11:36 - 26 Feb 2011    Post subject: Reply with quote
When you find yourself asking "Now, which region of the platter will be under the write head when this instruction gets executed", then you're programming.
https://static.eventful.com/images/block250/I0-001/003/306/384-8.jpeg
panrider_uk
PostPosted: 13:55 - 26 Feb 2011    Post subject: Reply with quote
When you have to worry about that you're behind the times - get a solid state disc drive Smile
Mark
PostPosted: 23:00 - 26 Feb 2011    Post subject: Reply with quote
https://static.flickr.com/87/240803829_9212773615_o.png
I'm two for three - where did I put those suspenders?
The last post was made 15 years, 199 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.55 - MySQL Queries: 16 - Page Size: 88.03 Kb
