| lozza |
 lozza Nova Slayer
| N cee thirty |
 N cee thirty Banned
 Posted: 14:49 - 24 Feb 2011 Post subject: |
you shouldn't need to if you've sealed the exhaust manifold to the pipe properly with the gasket  ____________________ '00 Aprilia RS50 > '92 Honda CG > '99 Yamaha Fazer > '91 Yamaha RXS > '79 Suzuki X5 > 01' Honda Cg > 07' Honda Cg > 82' Kawasaki Z200 > suzuki gsxr 400 gk73a > honda vfr 400 NC30 Mod 2 Passed 09/06/2011
Jewlio Iglesias wrote: I actually did vote BNP once |
| lozza |
 lozza Nova Slayer
| DrDonnyBrago |
| lozza |
 lozza Nova Slayer
| fiery tupp |
 fiery tupp Trackday Trickster
| lozza |
 lozza Nova Slayer
| fiery tupp |
| lozza |
 lozza Nova Slayer
| DrDonnyBrago |
| neil. |
 neil. World Chat Champion
 Posted: 10:26 - 25 Feb 2011 Post subject: |
Copper grease all over the gasket before you fit it.  |
| lozza |
 lozza Nova Slayer
 Posted: 10:55 - 25 Feb 2011 Post subject: |
| Quote: | Didn't mean to confuse you, my comment concerned the type of exhaust paste you bought, you wouldn't be the first to assemble an exhaust with repair paste  but it seems you bought the right stuff anyway.
You shouldn't need paste around where the downpipe fits unless you have a crap seal. If you have a crap seal then a load of assembly paste is the bodge way of doing it, you'd be better off trying again to get a good seal with a new gasket. One place where you might need paste is around where other parts of the exhaust fit onto the downpipe(s) as these often come without gaskets and can leak. Assembly paste is designed to be brittle and come apart so that you can take the exhaust off afterwards.
I use copper grease to fit gaskets as whenever I have had to remove them they have been a pig to do but any grease will be fine just to hold the gaskets in place. When the grease burns off it wont leave a gap, 99% of it will have been forced out of the gap when you tightened down the downpipe collar anyway. |
thanks man, answered my question perfectly. |
 Posted: 13:08 - 25 Feb 2011 Post subject: |
If you have a new gasket, fit it with no paste. Make sure you get the old gasket out (and possibly the one that was in htere before it) because it can be hard to tell there's a squashed gasket still stuck in the pirt. The port face should be smooth, a stuck gasket will have annular rings and ridges.
If you find that the new gasket you have fitted still doesn't seal, get another and fit it with the paste on both sides. It does cure hard, and brittle, but when sandwiched between the gasket and exhaust parts as a thin filler it's well enough supported to stay in place and do it's job.
The main reason why an exhaust would not seal in the port with a new gasket is if it had been repaired by welding and sitting out of line.
The reason you see so many negative comments about exhaust paste is because people try to get by with using it to bodge a rusted exhaust. It doesn't last long there. ____________________ a.k.a 'Geri'
The last post was made 14 years, 357 days ago. Instead of replying here, would creating a new thread be more useful? |
