seized pistons in caliper
1foggy
PostPosted: 23:35 - 25 Feb 2011    Post subject: seized pistons in caliper Reply with quote
Hi all took the calipers of the bike today to change discs and in both calipers the pistons that run on the outer side of the disc dont move and are flat to the bottom of the caliper any ideas on how to get them out to clean them so i can get them working again cheers
i thought of doing to get a screw driver on the in side of the piston to push it around to free it what do u think
900 blade RR wpb yx160
nsr_J22_FOXEYE
PostPosted: 23:49 - 25 Feb 2011    Post subject: Reply with quote
its been done before, and it works but be careful it you put the pad in first as the are quite malleable.
Never Ride Faster Than Your Angel Can Fly
1foggy
PostPosted: 23:59 - 25 Feb 2011    Post subject: Reply with quote
do u mean putting the screw driver in the piston to knock it round to release the piston or somrthing else m8 as i cant put the pads it till ive sorted the pistons m8
cheers
Ichy
PostPosted: 00:03 - 26 Feb 2011    Post subject: Reply with quote
Connecting an airline can help but be aware that if they are seized and it takes a bit of air pressure to release them then they piston can launch itself with a hell of a lot of force.
The easiest way by far is to leave it connected to the brake hose, clamp up the moving piston to stop it moving and then apply pressure at the lever. Keep pumping.
dna50
PostPosted: 01:41 - 26 Feb 2011    Post subject: Reply with quote
some people suggest put compressed air into the piston and they pop out but depends how bad they are. on my bike they were badly seized i had to use a parrafin heat gun on the back off the piston and then let it cool then sprayed wd40 in the gap after it had expanded and cooled. but yours should pop out if there not that bad with an airline if not compressed air
hsaeed
Scotsman37
PostPosted: 03:03 - 26 Feb 2011    Post subject: Reply with quote
Or a tool like this will help you do the job without scratching the hell out of your pistons
https://www.pvrdirect.co.uk/productinfo.aspx?catref=VS1806
https://www.pvrdirect.co.uk/netalogue/photos/Sealey/VS1806.jpg
BanditsHigh
Worse than a woman
PostPosted: 10:01 - 26 Feb 2011    Post subject: Reply with quote
As mentioned above, the easiest and safest method is to connect them back up and use the brake system to get the pistons out ... easy, no damage to pistons and you don't kill yourself (or anyone else) with a piston being flung across the room.
On twin sided calipers I usually put a spanner down the length of the caliper and then pump the brake lever until all the pistons hit the spanner ... on single sided calipers I pump one piston out and then hold it with a G-clamp and pump the other out ... once they are mostly out it's quite easy to remove them.
The reason your pistons are seized is due to corrosion building up at the back of the dust seal groove, this jams the seal against the piston stopping the piston retracting when the brake lever is released ... clean corrosion out and then refit seals and piston (replacing with new items when required).
Have fun Thumbs Up
serlant
PostPosted: 10:32 - 26 Feb 2011    Post subject: Reply with quote
Have fun Thumbs Up
This, I bought an old caliper on ebay with seized pistons as i'd damage one of mine, tried several things in the end put it on the bike, bled it and pumped them both out equally. with yours just clamp the good piston all the way in, then pump the siezed one out.
04 CBR1000RR, 1995 Husqvarna TE410, 1998 VTR1000(Sold), 1990 XJ600(sold), 1996 KH125(dead and sold)
cyberglass
PostPosted: 11:08 - 26 Feb 2011    Post subject: Reply with quote
this is what i do but with a spanner wrapped in a rag to stop any damage to the piston.
https://www.youtube.com/watch?v=mE-qitXDbuM
DL650 Vstrom 2004
DRZ400S 2003
Yamaha R1 2005
1foggy
PostPosted: 23:35 - 27 Feb 2011    Post subject: Reply with quote
sorted it thanks to alex h it was just the dust seals that were holding the pistons back just glad its done Very Happy
The last post was made 15 years, 113 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.28 Sec - Server Load: 2.44 - MySQL Queries: 13 - Page Size: 64.48 Kb
