Nuclear bombs
t121anf
PostPosted: 23:28 - 25 Feb 2011    Post subject: Nuclear bombs Reply with quote
Just watch "sum of all fears" and the bomb just went off and now it's rescue time, why are they such winds after a nuclear bomb
Syris D Indomitable
PostPosted: 00:06 - 26 Feb 2011    Post subject: Reply with quote
I might download that my self.
It's the movement of air.
The high temperatures and radiation cause gas to move outward radially in a thin, dense shell called "the hydrodynamic front." The front acts like a piston that pushes against and compresses the surrounding medium to make a spherically expanding shock wave.
The blast wind may exceed one thousand km/h
Two distinct, simultaneous phenomena are associated with the blast wave in air:
* Static overpressure, i.e., the sharp increase in pressure exerted by the shock wave. The overpressure at any given point is directly proportional to the density of the air in the wave.
* Dynamic pressures, i.e., drag exerted by the blast winds required to form the blast wave. These winds push, tumble and tear objects.
https://en.wikipedia.org/wiki/Effects_of_nuclear_explosions#Blast_damage
SoND
PostPosted: 00:09 - 26 Feb 2011    Post subject: Re: Nuclear bombs Reply with quote
Turbulence
JonB
Afraid of Mileage
PostPosted: 08:39 - 26 Feb 2011    Post subject: Reply with quote
If you can, look for a 1984 docu-drama called "Threads".
Nothing fancy and Hollywood about it, but it still scares the hell out of me!
yen_powell
PostPosted: 10:46 - 26 Feb 2011    Post subject: Re: Nuclear bombs Reply with quote
Fear!
XT1200Z and a DR350 in bits
el_oso
PostPosted: 22:46 - 27 Feb 2011    Post subject: Reply with quote
an explosion is a rapid expansion of volume due to the rapid increase of temperature. for the volume to expand it must displace something else. i.e the air. hence massive wind
Duke 390
Car: Jeep Wrangler 4.0L
SlimRick
PostPosted: 09:01 - 28 Feb 2011    Post subject: Reply with quote
+1 - watched it the other week, an awesome piece of work!
ajbsmirnoff
PostPosted: 14:19 - 28 Feb 2011    Post subject: Reply with quote
I believe theres an initial outward blast, but the hot fireball causes air to rise quickly drawing massive winds inwards towards the blast area.
these show stuff going one way then the other.
https://www.youtube.com/watch?v=RqyBzXYZPoM&feature=related
Probably a repost but the raptronic photos of nuclear blasts look weird
https://simplethinking.com/home/rapatronic_photographs.htm
Duck and cover !
Also - Threads is available on DVD, and its well scary. Worth a watch
Neorion
PostPosted: 16:04 - 28 Feb 2011    Post subject: Reply with quote
Is this the one where they lose contact with bombers? All done in black and white?
If its is then yes scary.
VFR FI 2000- Shiney Red Thing
"some things man was never meant to know, for everything else there's Google"
ajbsmirnoff
PostPosted: 20:50 - 28 Feb 2011    Post subject: Reply with quote
I think that was Dr Strangelove. With Peter Sellers. Also a good film.
Slacker24seve...
PostPosted: 21:55 - 28 Feb 2011    Post subject: Reply with quote
I'll remember that for next time I get bollocked for farting.
Banger rallies are ace
t121anf
PostPosted: 22:17 - 28 Feb 2011    Post subject: Reply with quote
i understood that as the bomb exploded the air would be pushed out and then sucked back into the vacuum left, however the finds shown in the film seem to continue sometime after the explosion.
is this hollywood or fact?
tatters
Exxon Valdez
PostPosted: 22:32 - 28 Feb 2011    Post subject: Reply with quote
Air is pushed out by the force the explosion but you also get cold air being sucked in and pushed up which creates the mushroom cloud.
craigT19
Jolly Green Giant
PostPosted: 22:45 - 28 Feb 2011    Post subject: Reply with quote
depends on the size of the bomb, the super heated air rises and swirls causing its own weather system, this is often storm like.
If my memory of history serves me the french experiments in the french ploysimmin islands use to cause there own weather systems, heavy rain, tropical storms etc.
Think of cadles on a birthday cake, then you blow them out you force the smoke to move, once you have stopped blowing the smoke doesnt stabalise, it rolls back on it self and keeps blowing around.
So a nuke going off will cause a massive low pressure causing air to be sucked into the blast zone as said above, this will continue to swirl for some time after the blast untill the air sorts itself out.
Bikes owned :- 2001 nsr125, 1999 zx6r, 2006 yzf-r1, 2009 xmax 250, 2012 yzf-r1, 2015 MT-07
Current bike : - 2016 MT-10
Crying or Very sad BCF member pops. sadly missed Crying or Very sad 1945-2003
ajbsmirnoff
https://en.wikipedia.org/wiki/Mushroom_cloud
The last post was made 15 years, 198 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.59 - MySQL Queries: 13 - Page Size: 85.41 Kb
