| Blackrandomap... |
 Blackrandomap... Scooby Slapper
 Posted: 23:21 - 26 Feb 2011 Post subject: Crappy clunky r6 gearbox. |
Is there anything i can do to stop the gearbox on my 2000 R6
Anything under 5k revs and changing gear is crap, noisy and clunky!
I understand its normal but there has to be some trick of the trade toi shut it up>?>
 ____________________ 1x 2001 Yamaha R6 1x 2000 Yamaha R6 !For Sale! £2500 1x 2003 Cbr600rr Racebike 1x 2004 Wr450 Sumo 1x 2001 Ktm520 Sumo |
| 0l0dom0l0 |
 0l0dom0l0 World Chat Champion
 Posted: 00:14 - 27 Feb 2011 Post subject: |
Give it a service. When was the last oil change?
Usual things to check, clutch cable adjustment, chain adjustment, and also gear linkage lubricated properly.
Should help. ____________________ CBT Passed: 30/08/2009, Theory Passed: 31/08/2010, Mod 1 Passed: 6/9/2010, Mod 2 Passed: 13/09/2010. Restriction ended 13/09/2012.
Bikes: 2007 Derbi GPR 50, 1998 Yamaha Fazer 600 (written off), 2002 Yamaha Fazer 600, 1994 CBR 600F, 2003 Triumph Daytona 600, Kawasaki ZX6R J1.....Current: 2006 Yamaha FZ6, 1998 Suzuki TL1000R and a Honda VFR 400 NC30. |
| The Tot |
 The Tot World Chat Champion
| MinhDinh |
 MinhDinh World Chat Champion
 Posted: 03:33 - 27 Feb 2011 Post subject: |
New oil, about 35 quid and chain lube or adjustment was fine for me.
The actual changing of an engine seems pretty much, I think that was because of second gear jumping out or something. This seem like a maintenance issue. ____________________ Hit the G spot.  |
| 0l0dom0l0 |
 Posted: 13:34 - 27 Feb 2011 Post subject: |
| Quote: | Have a look at X's/R6Luke or whatever he calls himself these days' thread on a gearbox change - Ben. (half-life) helped him out with the swap, but this required a donor engine |
| Quote: | I think that was because of second gear jumping out or something |
Min's right. The box's are solid apart from second gear. If yours is jumping out of second gear into a false neutral under hard acceleration then its a gearbox strip I'm afraid.
However I don't think that's the problem. Clunky gear changes are normal when something isn't happy. Check all the other stuff first! ____________________ CBT Passed: 30/08/2009, Theory Passed: 31/08/2010, Mod 1 Passed: 6/9/2010, Mod 2 Passed: 13/09/2010. Restriction ended 13/09/2012.
| 0ddball |
 0ddball World Chat Champion
| Blackrandomap... |
 Posted: 17:37 - 27 Feb 2011 Post subject: |
I did an oil change about 500 miles ago, on one occasion i accelerated hard in first and second didnt seem to exist it revved out and i looked like a donut, will check chain and sprockets later!
Not sure this is looking to good, ____________________ 1x 2001 Yamaha R6 1x 2000 Yamaha R6 !For Sale! £2500 1x 2003 Cbr600rr Racebike 1x 2004 Wr450 Sumo 1x 2001 Ktm520 Sumo |
| Blue_SV650S |
| Blackrandomap... |
 Posted: 18:35 - 27 Feb 2011 Post subject: |
I have only been riding the bike since i passed my test in january its only the last couple of outings its started to get annoying, i have ridden my friends r6, Same year etc his does seem a little smoother.
My bike seems to be 'more loose' if you get what i mean, but that could be because i have a gp can on mine and his is standard. it just feels and sounds more aggressive.
Its tricky because i just dont have the experience behind me yet  ____________________ 1x 2001 Yamaha R6 1x 2000 Yamaha R6 !For Sale! £2500 1x 2003 Cbr600rr Racebike 1x 2004 Wr450 Sumo 1x 2001 Ktm520 Sumo |
| L4Isoside |
 L4Isoside World Chat Champion
| Blackrandomap... |
 Posted: 18:49 - 27 Feb 2011 Post subject: |
No, He has no license yet
Thats prob the best idea tho, Im sure i can find some one with experience to have a ride,
I just want to know if the gearbox is ok, If its clunky but fine i can get used to it. I could do with brushing up on my gear changes, A little more clutch perhaps? ____________________ 1x 2001 Yamaha R6 1x 2000 Yamaha R6 !For Sale! £2500 1x 2003 Cbr600rr Racebike 1x 2004 Wr450 Sumo 1x 2001 Ktm520 Sumo |
| MaybeGuy |
 MaybeGuy Super Spammer
 Posted: 18:51 - 27 Feb 2011 Post subject: |
the gearbox wont fail unless you're a retard that does power wheelies in first then mashes it into second on one wheel.
clutch in second or not at all
get over it, change gear properly, and adjust your clutch so the biting point isnt at the bar ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| Blue_SV650S |
 Posted: 19:05 - 27 Feb 2011 Post subject: |
... and ... as per usual, a non helpful, worthless, pointless post/reply by 'the pratt'!  ____________________ The purpose of life is to fight maturity.
| Blackrandomap... |
| 0l0dom0l0 |
 Posted: 20:43 - 27 Feb 2011 Post subject: |
For me, personally, its anywhere between 50-80% of the lever released. Not sure if there is a mechanical version though! ____________________ CBT Passed: 30/08/2009, Theory Passed: 31/08/2010, Mod 1 Passed: 6/9/2010, Mod 2 Passed: 13/09/2010. Restriction ended 13/09/2012.
| Ed Case |
 Ed Case World Chat Champion
| Blackrandomap... |
| craigT19 |
 craigT19 Jolly Green Giant
 Posted: 21:10 - 28 Feb 2011 Post subject: |
£10 says your chains to tight
R6's suffer real bad if your chains to tight, they use a rather small bearing for the output shaft and if the chains like a bow string the output shaft can actually pivot alittle on the bearing and puts extra pressure on the gear change.
Sit on the bike and see if you have much chain movment.. i know its school boy stuff but in my experience 90% of sports bike owners dont have a clue how to adjust there chain. ____________________ Bikes owned :- 2001 nsr125, 1999 zx6r, 2006 yzf-r1, 2009 xmax 250, 2012 yzf-r1, 2015 MT-07
Current bike : - 2016 MT-10
BCF member pops. sadly missed 1945-2003 |
| Blackrandomap... |
| Blackrandomap... |
| MaybeGuy |
 Posted: 10:04 - 01 Mar 2011 Post subject: |
why are you changing gear at 3k on a bike that doesnt make any sense of power till 8k? ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| chris-red |
| DrDonnyBrago |
| Blackrandomap... |
| woodyfjr |
 woodyfjr Scooby Slapper
The last post was made 15 years, 117 days ago. Instead of replying here, would creating a new thread be more useful? |
