| mrr1 |
 mrr1 Traffic Copper
 Posted: 22:09 - 27 Feb 2011 Post subject: spark plug cross threaded - URGENT ADVICE NEEDED |
right - here's my problem - bikes been missing a little when damp so I refitted HT leadto cap, whipped out plug, cleaned electrode and checked gap. Thought I'd check cylinder no 2 (bike is 2000 fazer 600 with 29k on clock). As I was putting spark plug back into cylinder 2 it felt a little stiff so I backed it back out, wound it in with fingers half a turn and then ratcheted it in (but being a feckwit ignored the fact that it was still stiffer than normal). Then noticed plug was at a crooked angle to the one on cylinder 1 and about 10mm higher. So I took the plug out again and, sure enough, leading edge on plug is now shiny and I've cut myself a new plug thread - major f******g bo**ocks"!!!!!!!!!!! Is this an engine out job now? I've got a tap & die set and a vacuum attachment that can get into the cylinder. The main problem is getting to the top of the engine - its a complete b@stard with all the harnesses and frame in the way.
Any advice greatly appreciated...... ____________________ TRX850, TDM900, ST1300, CB650SC Nighthawk, ragtop Saab, gym membership, messy divorce, large chested blonde fiance
Damn, I'm loving my midlife crisis. |
| N cee thirty |
 N cee thirty Banned
| Ed Case |
 Ed Case World Chat Champion
 Posted: 22:46 - 27 Feb 2011 Post subject: |
You're dead right, it's a tw@ of a job, I've got a Timecert in the plughole of my 250RSA but I had to take the head off to do it properly, I suspect you'll have to do something similar unless you can find a particularly adventurous mechanic. Tuff my mate !.  |
| Pete. |
 Pete. Super Spammer
 Posted: 22:53 - 27 Feb 2011 Post subject: |
You could run a tap down the thread. Another thing you could do is grind a fresh sparkplug thread with 3 or 4 flats on it to make the shape of a threadcutting tap and run that into the hole to clean up the first part of the threads that are crossed. Both methods depend heavily on the person doing the work knowing when they have got it right or wrong. Not much to lose by trying it but having someone good at dealing with such things on the spenner will vastly increase the chance of not having to pull the head off. ____________________ a.k.a 'Geri'
| mrr1 |
 mrr1 Traffic Copper
| Syris D Indomitable |
 Syris D Indomitable Nitrous Nuisance
| mrr1 |
 mrr1 Traffic Copper
| mrr1 |
 mrr1 Traffic Copper
| kestrel |
 kestrel Nearly there...
| Raffles |
 Raffles World Chat Champion
| Pete. |
 Pete. Super Spammer
 Posted: 11:48 - 28 Feb 2011 Post subject: |
I wouldn't take off the head, I'd have a crack at straightening the plug thread first then stuff a small tube up a hoover pipe to get any bits off the piston.
The CR8e standard Fazer plugs are fine thread, non-standard so don't go just buying a standard M10 tap and running it into the hole. ____________________ a.k.a 'Geri'
| mrr1 |
 mrr1 Traffic Copper
| mrr1 |
 mrr1 Traffic Copper
| deliriousthun... |
 deliriousthun... Spanner Monkey
| Pete. |
 Pete. Super Spammer
 Posted: 21:31 - 28 Feb 2011 Post subject: |
The early 911 heads were gasket sealed, later sealed with a special ring-type gasket. Didn't stop them blowing though and they ended-up welding the heads to the barrels during production for other models. ____________________ a.k.a 'Geri'
| mrr1 |
 mrr1 Traffic Copper
| ZRX61 |
 ZRX61 Victor Meldrew
| mrr1 |
 mrr1 Traffic Copper
| Pete. |
 Pete. Super Spammer
 Posted: 06:44 - 01 Mar 2011 Post subject: |
There should be no need for a timesert. You should have at a guess about 8 threads of engagement on the plug , you couldn't have wrecked more than the first couple or the plug would still be frozen in there. There's no chance of an ejected plug at speed and no chance of it firing into the tank if it did either - all the enegry will be soaked-up by the pluglead.
Running a tap down the hole would be enough. ____________________ a.k.a 'Geri'
| Stalk |
 Stalk Brolly Dolly
| DrDonnyBrago |
 DrDonnyBrago World Chat Champion
| deliriousthun... |
| chris-red |
| mrr1 |
 mrr1 Traffic Copper
| HD |
 HD World Chat Champion
The last post was made 15 years, 113 days ago. Instead of replying here, would creating a new thread be more useful? |
