Water tank on NSR 125
craigie b
Citizen Smith
PostPosted: 10:51 - 12 Aug 2004    Post subject: Water tank on NSR 125 Reply with quote
Hi,
After a thread about maintenance on an nsr I got told that there is a water tank that needs filling for cooling something or the other.
THing is I opened my NSR up yesterday and could see only 3 tanks, one on the right was for 2 stroke oil, one in the center with a label on the cap saying 'do not remove when hot' and one directly left of this one with coolant written on the cap. Now I opened both and was not sure which one needed water since they both seemed to be filled with water type liquid (tinged blue I think). lol without actually tasting the stuff I wasn't sure which one needed water or what bot the tanks are for. Can anyone help?
Craig
fuzz
PostPosted: 10:54 - 12 Aug 2004    Post subject: Reply with quote
If the level of the tank with the blue liquid in with the rubber cap is at or below the lower level mark, you need to top this up with a mixture of water and anti freeze. I think it's 50-50, but don't quote me on that!
craigie b
Citizen Smith
PostPosted: 10:56 - 12 Aug 2004    Post subject: Reply with quote
So I was right not to taste it? Very Happy Any idea to the middle tank and its use?
fuzz
PostPosted: 11:04 - 12 Aug 2004    Post subject: Reply with quote
The middle tank is the radiator. If your engine is running hot, remove the cap and fill with water/anti-freeze mix and make sure al the air is out. Then check the expansion tank (the one on the left)
PostPosted: 14:11 - 12 Aug 2004    Post subject: Reply with quote
The radiator should be checked as part of routine servicing. The cap that says 'do not remove when hot' is the radiator filler cap. As the label suggests, do not remove this when the engine is hot or you will scald yourself on the high pressure steam that comes flying out of it. This should be brim-full of coolant (water and anti-freeze mixed according to the label on the bottle) always use anti-freeze in there as it stops your radiator corroding.
The other is the expansion bottle for if the pressure in the radiator gets too high. Coolant moves into the bottle at high pressures (so when you are thrashing the bike) and it flows back as it cools and contracts. This is to stop your radiator exploding, it should be filled to between the Max and Min marks on the bottle.
Tasting the coolant is a good way of telling if it has antifreeze in it. Ethylene Glycol (antifreeze) tastes sweet but is poisonous, dipping your finger in then licking it will do no harm though, you'd actually have to drink the stuff to be effected by it.
I have a bad habit of tasting random fluids that drip out of my bike to see what they are. I have stopped doing it now because the last time it turned out to be battery acid Sick
Fallen Angel
Franny the Nanny
PostPosted: 14:15 - 12 Aug 2004    Post subject: Reply with quote
Thinking
Laughing Laughing LMAO Laughing Laughing
I laughed out loud there in the office and everyone turned around!! Shhh!
I have an asshole tolerance level of -10 Twisted Evil
Mr. Green Dance! Mr. Green www.cliqueyclanmcc.co.uk Mr. Green Dance! Mr. Green
www.bebo.com/fallenangelfran
McJamweasel
BCF Junkie
Oh dear. Laughing
PostPosted: 04:33 - 13 Aug 2004    Post subject: Reply with quote
In my defence, that is the quickest way to identify what is dripping out of your bike.
Coolant = sweet
oil = Tasteless and oily
petrol = well, kind of petrolly, and makes your lips sting slightly.
Battery acid = the strongest vinegar you ever tasted x100
Anything else I count as safe to ignore as it is not coming from the inside of the engine Wink
I suppose the better way to do it would be to follow the pipe that said fluid is dripping from and see where it goes, but my supermoto has a cluster of about five drain hoses from various places sticking out the bottom, dipping your finger in the drip and tasting it is a lot quicker but a little like russian roulette.
craigie b
Citizen Smith
PostPosted: 14:16 - 13 Aug 2004    Post subject: Reply with quote
Cheers for the advice stinky. By the way when I first noticed the pipes dangling out of my NSR my initial thought was fuck, someone been syphoning my bike so I tried to pull them out. Doh! Didn't pull to hard mind so there still intact. felt like a right gimp
The last post was made 21 years, 324 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.69 - MySQL Queries: 13 - Page Size: 65.5 Kb
